Old 04-03-2012, 01:39 PM   #1
MrEL
Sick Puppy
MrEL's Avatar
Default Removing mirror scalps?
Hi all
I have to remove a mirror scalp and paint it up for the missus's car so what is the best method to remove them without breaking them?
All the ones I have seen removed end up being broken so obviously there has to be a better way.
Cheers.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2012, 02:16 PM   #2
block58
block58's Avatar
Default Re: Removing mirror scalps?
There are 3 little clips holding them on from the other side of the mirror, so if you move the mirror around while shining a torch in there you should be able to see them, then just use a flat blade screw driver to unclip all 3 and it will pull away from the mirror.
block58 is offline   Reply With Quote Multi-Quote with this Post
