Old 24-11-2005, 08:16 PM   #1
Grechie
Grechie's Avatar
Default Injectors Causing Problem
aii guyz, decided i needed new set of injectors since 2 were leaking n "hissing" wen car was on (air leak or something) so i got my friends EDXR6 ones (yes i know no difference but none the less, better/cleaner n perfect O rings then mine which were snapped)
i put a new set of injectors in from my friends EDXR6, hooked everything back up, car started not a problem, waited a bit (10 minutes or so playing with the ISC coz it needed lowering, found a good speed of 850rpm), turned it off all good, then i went to move it 15 minutes later, n it stalls
tried again, stalls
keeps stalling, have to hold the revs up even then wen i let go it stalls, then after holding the revs up for a bit, it idles fine, kool, turn it off, turn it back on, stalls, so we upped the idle again, stalled still, so took it for a drive, all good even @ traffic lights no hunting nothing, no spluttering nothing, come home turn it off, start up again, nearly stalls, but idles fine after nearly stalling, , really peeing me off,!!! the first time we started it , we had it started for awhile n it was perfectly fine, nothing wrong, the engine wasnt tampered with in the mean time wen it was left off, wot could it be? its getting me angry that the first start wen all 6 were in, the idled perfect, n stayed on didnt do nothing till the next time we started it and it couldnt hold idle
- Grechie
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2005, 08:36 PM   #2
PULLY6
PULLY6's Avatar
Have you reset your ECU? The ECU is the source of - and solution to - most problems in a Falcon I'm finding...
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust
PULLY6 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2005, 08:40 PM   #3
Jason[98.EL]
Jason[98.EL]'s Avatar
take it for a drive about 15 ta 20 ks should reset it all
this should fix it
no longer have a ford but a ford man at heart
R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN
[SIGPIC][/SIGPIC]
Jason[98.EL] is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2005, 03:54 AM   #4
Grechie
Grechie's Avatar
hey thanks pully6 and heljas, it seems to have fixed it self i THINK just driving around i think its sorted itself out..see how it goes tommorow
KPM Street Fighter
PCMTec
