Old 21-10-2010, 07:24 PM   #1
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Service Spanner
Just a quick question.. and yes I did the usual searches
the service spanner that appears on the dash on the S1 Au does it disappear the same as the EF ? From memory, key to acc. and hold the speedometer button in. if not how so please
Thanks in advance Whoosha
Originally Posted by Riksta
Old 21-10-2010, 08:17 PM   #2
GK
Walking with God
GK's Avatar
Thumbs up
That's it. Accessorites on, then hold in the button for a bit, until it beeps.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 21-10-2010, 08:25 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
Ta George Been a while and old age is setting in Its on a mates car and I didnt want to make something else happen
Old 21-10-2010, 08:51 PM   #4
JK EX CHASER
Formally kotevski22
JK EX CHASER's Avatar
Ignition on hold until it beeps about 15 seconds.
JK EX CHASER is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2010, 12:43 AM   #5
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Yep that's what the owner's manual says, ignition on (engine off) hold reset until it beeps.
AMB is online now   Reply With Quote Multi-Quote with this Post
Old 23-10-2010, 02:43 PM   #6
GasoLane
Former BTIKD
GasoLane's Avatar
Ya got that right !
Oh dear...You can hear the conversation now "Of course I serviced ya car. The little spanner thing has gone innit?..."
Old 07-08-2012, 03:44 PM   #7
brett7777
brett7777's Avatar
Default Re: Service Spanner
Just tried it on my Dad's AU & it didnt work. No beep. And spanner light is still on.
Current:
Toyota JZX90 Mark II Tourer V 1JZ-GTE
Nissan Fairlady 350Z
Nissan Skyline 370GT Coupe
Previous:
FPV BF F6 Typhoon #202
BF XR6 Rebel
Founder of BA & BF FORD FALCON FACEBOOK GROUP
brett7777 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 07:03 PM   #8
GK
Walking with God
GK's Avatar
Are you sure the key was turned to the accessories only?
Sounds silly I know, but worth checking.
GK
Now gone!
On LPG
Old 07-08-2012, 07:29 PM   #9
brett7777
brett7777's Avatar
Tried it on acc, & on the next setting. neither worked.
Current:
Previous:
BF XR6 Rebel
Old 07-08-2012, 07:45 PM   #10
foxtrot3
foxtrot3's Avatar
Hi. From the "injectronics" web site for the AU
As with the EF and EL Falcons, the AU Falcon has a small light in the shape of a spanner that illuminates in the lower left hand corner of the dash panel when the vehicle is due for next service. The procedure to remove the service light and reset it for the next service interval is simple and Injectronics recommend to follow this procedure:
Turn ignition on (don't start engine)
Hold down the reset shaft for between 11 and 13 seconds
An audible beep will be heard after the shaft has been released to indicate that the command has been received and the light should go out.
Note: If the button is held down too long or not long enough, the spanner light will not clear.
Cheers MD
HI
I'M MICHAEL
Old 07-08-2012, 09:02 PM   #11
smally289
growing up is optional
smally289's Avatar
For some reason, the AU's seem to be time sensitive. EF/EL's you can hold the button in and wait for the beep before releasing it. AU's you have to release it before it beeps , try 12 or 13 seconds, may take a few tries to get it to work.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 09:26 PM   #12
AMB
Turn it on so that all the dash warning lights are on, don't start it. Hold the button in until it resets.
Old 08-08-2012, 08:12 AM   #13
wombat30x
And of course don't forget to do the service this light is reminding you to do..
wombat30x is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2012, 10:57 AM   #14
smally289
smally289's Avatar
Isn't it ironic that such a 'modern' car uses an open ended spanner for a service indicator?
Old 08-08-2012, 12:04 PM   #15
keno49
Hello once again,
I must be sending my messages to the wrong section so I will try again.
I need a 90mm air flow sensor to fit on my EB2 5lt with an upgraded AU series 3 XR8 heads,cam & exploerer manifold. The only place on the net is from the USA . Herrod Austrlia don;t have them anymore. If I get one from there do they wire straight into my conversion.Any help please Thanks from keno49
keno49 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2012, 01:51 PM   #16
AMB
Originally Posted by keno49
Hello once again,
Yeh you posted in a few different areas, and the last one is in a specific section (ECU and Engine Management), which may not get much attention. This is the wrong place too, your car is not an AU and it has nothing to do with service spanner. Stick to the main sections and if you need help
start your own thread. In your case probably best in the Post Classic XD to EL section here:
http://www.fordforums.com.au/forumdisplay.php?f=29
Use a good title such as "EB2 5lt 90mm air flow sensor needed"
Old 08-08-2012, 03:10 PM   #17
brett7777
brett7777's Avatar
Cheers MD
there's no beep. light stays on.
Current:
Previous:
BF XR6 Rebel
Old 08-08-2012, 03:32 PM   #18
GK
Walking with God
GK's Avatar
Question Re: Service Spanner
This is quite puzzling.
In my Series 1 Futura, I have the key on accessories, and simply hold the button in until it beeps. The icon disappears as it beeps.
I don't count or anything. I just keep the button depressed until the beep.
GK
Now gone!
On LPG
Old 08-08-2012, 04:26 PM   #19
BHDOGS
Broken reset button?
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2012, 05:03 PM   #20
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Just to clarify brett77777 that this is the orange spanner not the S in a circle
Old 08-08-2012, 05:41 PM   #21
smally289
smally289's Avatar
Try releasing the button at different times. Try 10 seconds first, increasing the time by 1 second until it works. Some of the early build AUs can be a PITA to reset.
Old 08-08-2012, 06:45 PM   #22
dieseltrain79
Series 1 ghia . Tried lots , only thing that worked was ...
Turn ignition to Acc . Hold button for 12 seconds ( using stopwatch on iPhone ) . Release button , spanner gone with audible beep
Simply holding it never worked until it left .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2012, 10:21 PM   #23
mik
mik's Avatar
is the spanner service reminder thing a feature on series 2 models?
Old 08-08-2012, 10:40 PM   #24
smally289
smally289's Avatar
Nope, Ford deleted it.
Old 09-08-2012, 12:18 PM   #25
mik
mik's Avatar
ok , thanks Smally351.
