'06 Ford Territory Turbo
I'm at the final stage of getting the car ready for its roadworthy. There's just a couple of final issues left over.
1. My fuel guage is reading constantly at 0-15kms of fuel. 2. I have no brake lights; I have park lights but no brake lights what so ever. I checked the filament on the tail light bulbs and they're both fine and the spoiler and parcel shelf lights don't come on either. I've checked my interior fuses, but they're all good. 3. Can't get the tamperproof torx screws out of the steering wheel. I've got tamperproof sets, but the pin on the screws are too large for my sets to work. Is there a Ford version? 4. Whilst I had the wheels off, I noticed this on the diff. I'll replace it during the wheek, but am a little curious as to what this line is for. ![]() ![]()
Travisty's Ford Territory Turbo Project Car History - No crashes, just a lot of shitboxes... 1988 EA Ford | Sept 2007 - Apr 2008 1995 EF Ford | Apr 2008 - Oct 2008 1998 AU Ford Forte | Oct 2008 - Mar 2011 1996 EL Ford Fairmont Ghia | Mar 2011 - Sept 2012 1999 AU Ford Sports Pack | Oct 2012 - Dec 2014 2003 AU Ford S3 XR6 | Sept 2014 - Apr 2018 2005 Ford Territory Ghia | Apr 2018 - Aug 2023 2006 Ford Territory Turbo Ghia | Aug 2023 - Now |
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Hose from diff is just a breather, cut it off and push it back in
![]() Tail lights / brake light I would first test the switch in the foot well above the brake pedal to see if it is getting power, if it is short it out and check lights again ,if it has power and still don't work and the tail light plugs/ globe holders are the original white ( ? ) ones piff them for the BA ones which are a tougher plastic . the rest not sure ![]()
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Rob
yea for number 2 id check the brake pedal switch thing in the footwell.
At Winton my mates EF brakes were not working so we couldn't pass scrutineering, we popped in mine and sure enough they worked.
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
When in doubt, GAS IT!!
1 - Sounds like your fuel gauge sender in the tank has died.
2 - Brake pedal switch. 3 - Sounds like you got a poorly cast bit if it won't fit, they should all fit. I bought a generic set on Ebay and it fit just fine. Drill out your torx bit till it does fit. 4 - Diff breather.
Got Ghia?
Did the AU1 have those stupid 5 point torx over the usual 6?
If so, you can grind a bit out of the middle of a flat head screw drivers bit and use that. You will probably brake the bit though, I broke 3 getting the 2 screws out. Needless to say, they just have regular bolts in them now!
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold ![]() 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
the AU had a 5 point torx screw on the steering wheel pad they are hard but not impossible to find . I got a set from autopro
[SIGPIC][/SIGPIC]
Bursons have them in a little $20 kit with a few other sizes included.
#8 | |||
sounds like the set I got from autopro
[SIGPIC][/SIGPIC]
Flairs - Truckers Delight
I borrowed the torx tool from a mate and while I had them off I cut a groove in each so now it can be undone by a flathead screwdriver.
