Old 06-10-2012, 02:20 PM   #1
T.M
T.M's Avatar
Default Whiteline rear sway bar issue
Hi all,
Just took delivery of my 22mm non adjustable rear sway bar for my 2008 LT TDCi.
Went to install it this morning and noticed that the standard sway bar links bolting points are 'horizontal' whereas the whiteline one is 'vertical' if that makes sense.
I'll try explain that again if it didnt make sense, on the original the bolt runs straight up and down through the sway bar, meaning I need different links which weren't included?
Anyone know what the story is here?
T.M is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2012, 04:31 PM   #2
overl0ad
Default Re: Whiteline rear sway bar issue
should be ok if you've got the whiteline endlinks.
overl0ad is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2012, 05:07 PM   #3
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
This has been covered in another thread a while back, you will need to purchase the correct links
http://www.fordforums.com.au/showthr...1341780&page=2
Go to the sixth post down the page
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2012, 05:27 PM   #4
T.M
T.M's Avatar
Yea sweet, guess I assumed when it said it would fit an LT that it would come with everything one would need to fit it.
Cheers Russ
Old 06-10-2012, 05:35 PM   #5
T.M
T.M's Avatar
Can the links be bought from the whiteline website because I can't see any other than the quite pricey adjustable links
Old 06-10-2012, 05:46 PM   #6
overl0ad
just wondering...
other than whiteline, who else does decent sway bars and end links for the focus?
this is the first non jap car i've owned...
Old 06-10-2012, 09:44 PM   #7
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Originally Posted by overl0ad
just wondering...
I think LS/LT genuine ones from Ford are the ones we need.
Old 16-10-2012, 09:52 PM   #8
overl0ad
Sorry... LS/LT? aren't those previous focus models?
i'm hoping to get advice along the lines of "buy "insert band name here"...
or something like: the OEMs are XXmm Front and XX mm rear, so for a balanced upgrade go with the YYmm and YYmm...
Old 16-10-2012, 09:56 PM   #9
Franco Cozzo
Thailand Specials
Yeah apparently they have the right rear swaybar links to suit the whiteline 22mm rear sway bar. As the holes for the 22mm rear sway bar come out on the sides and the factory sway bar and links have one hole in the middle of the end of the bar.
I've got the bar but can't put it on the car because the links are different.
Old 16-10-2012, 10:04 PM   #10
overl0ad
i can't work out for the life of me why they use such long endlinks...
just makes it the weakest link. and i personally don't like the whiteline endlinks.
Old 16-10-2012, 10:12 PM   #11
Franco Cozzo
Thailand Specials
I have them and my mechanic said he couldn't use them, so I'm probably going to go to Ford and get the other ones I need.
