Old 18-12-2005, 07:02 PM   #1
Mark351
Built Ford Tough
Mark351's Avatar
Default *argh*
I've removed my premium stereo a few times over the years - last time was to refit the modicoated strip above the passenger airbag about 18 months ago.
Since then the two vents at the top of the centre facia have developed an annoying rattle, so today I attempted the get the stereo out again with the old two bits of coat hanger wire bent into shape trick so I could fix said rattle. To my endless frustration, I could not get the stinkin thing to move out. For all I know I've now busted the lugs on the frame and I won't be able to get the bastard out easily. I also managed to break the flap on the cassette player (do not try to reef the stereo out using the cassette player opening...), which is probably one of the $2 parts you can't get on it's own... grr.
Anyhoo, if anyone has done the removal thing lately, any hints on getting this sucker out? If even the proper Ford tools don't work, what are my options?
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2005, 07:59 PM   #2
chief
FTF Club Moderator
chief's Avatar
I went to Ford to change my CD Player with tape to 6 stack cd player and changed it over for me for free.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2005, 08:04 PM   #3
Mark351
Built Ford Tough
Mark351's Avatar
That's good of them, but I'm not sure that solves my problem though.
Old 18-12-2005, 08:18 PM   #4
stiddy
stiddy's Avatar
go to a Car audio place and buy the 'keys' or borrow them just to get the deck loose...
or try some long skinny nails.. <---- its what i used and it worked for me
stiddy is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2005, 08:43 PM   #5
HLC
Audi S3
when i was getting mine out. i rammed the wires in til they clicked or whatever. then with one hand i pulled them together, or pushed a part, i cant remember which it is. and i reached with my other hand under the ash tray, and fount the back of the stereo, and pushed it out.
HLC is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2005, 09:37 PM   #6
Baboon_AU
Baboon_AU's Avatar
HLC, your method seems the go, this is what i would do to get mine out
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2005, 10:31 PM   #7
GlennBA
GlennBA's Avatar
lol i tore the face off mine.. i ended up having to pull it apart while it was still inside the dash to get the piece of crap out.. :(
Ahh well.. consequently i have a better system now
My advice on getting it out? TNT.. lots of it.. :evil_laug
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 01:38 AM   #8
clontarf_x
Your problem sounds identical to mine. Just head to your nearest car audio place and they should take it out for ya. Alternatively, I got a butter knife and pryed between the exterior of the deck and the fascia, until I could feel the bracket (tehre is only one, its on the left hand side) and just pushed it outwards and the deck almost shot out at me.
if that doesnt work, have fun.... previous to my knife escapades I managed to scratch the absolute s-hite out of my fascia.
- Shane
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 01:23 PM   #9
V8falcons
V8falcons's Avatar
Yep this job sux abit if you dont have the tools ,I wanted to change my xr6 6 stack for my single CD in my wagon and had the wagon one out using the old coathanger method in a flash,but for the life of me couldnt get the Xr6 one out,(maybe it didnt want to go?) so the 6 stack went with the ute when i sold it.My coat hanger peices were just a U shape but ,I cut a groove in the end to grip on the clips which I worked out from removing the first one.
the hardest part is getting a grip to pull it out.
Im replacing mine with an aftermarket stereo shortly so I wont be looking forward to this.
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 08:46 PM   #10
couz^man
couz^man's Avatar
should be able to get some Blaupunt stereo keys (from some where that stocks the brand) in it if the keys are bent at the end straighten them
couz^man is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 09:00 PM   #11
HLC
Audi S3
coathangers are cheaper though *shrug*
Old 19-12-2005, 09:06 PM   #12
Mark351
Built Ford Tough
Mark351's Avatar
Yes, but as I've explained in my first post, I used coat hangers. Also, I've actually got the stereo out before, only this time it's not coming out...
Old 19-12-2005, 09:23 PM   #13
couz^man
couz^man's Avatar
yeah coat hangers work in some cases but i think in DeathXR's case he might have to bite the bullet and get some blaupunk keys cause they have little taps on the end that grab the bracket
Old 19-12-2005, 10:37 PM   #14
peterban
AULTD
peterban's Avatar
With the bent coat hangers or the tools you have to push them outwards, the left towards the left door and the right towards the right door, sometimes you can get one side to move and the other side sticks but with a little bit of patience they come out in the end.
It is a good idea to have someone else push the stereo from the back while you are using the coat hangers as they don't have the grip bits on the end like the tools have.
Good luck
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 10:48 PM   #15
Peuty
Afterburner + skids =
Peuty's Avatar
Man, thats EXACTLY what happened me.
Oo\===/oO
Old 21-12-2005, 07:18 AM   #16
Mechan1k
Mechan1k's Avatar
One word = CROWBAR
Old 21-12-2005, 09:12 PM   #17
Peuty
Peuty's Avatar
I used a flat head screwdriver for mine.
Oo\===/oO
