23-12-2005, 01:17 PM | #1 | ||
5.SPEED
I have a question about installing the 'passive crossover network' (PCN) which is square box thing.
Can I just connect the pioneers to the orginial wireing and use the 'passive crossover network' which is already in the car. Or do i need to put the new one in somewhere. The falcons already use splits so it must have one of these PCN box's. Please help |
23-12-2005, 01:19 PM | #2 | ||
hibernating
to get best results it would be best to use the new crossovers and also run new speaker wires
23-12-2005, 01:21 PM | #3 | ||
5.SPEED
Ok then. Well where are the orginal crossovers located as i will replace them with the new ones
23-12-2005, 01:33 PM | #4 | ||
Posts: n/a
there is no original crossovers in the ED, they just had an resistor or something on the tweeter speaker. you are probably better off amping the splits anyway so run new cable as well...
23-12-2005, 01:52 PM | #5 | ||
5.SPEED
where whould be the recommended area for placing/hiding the crossovers.
23-12-2005, 01:56 PM | #6 | ||
hibernating
wherever you want... i have mine behind the side kick panels... other options i've seen inside the doors, or up under the dash
23-12-2005, 01:57 PM | #7 | ||
Posts: n/a
i put mine behind the kick panels, one behind my ECU on the passenger side and one behind all the wires on the drivers side
23-12-2005, 02:23 PM | #8 | ||
5.SPEED
so i have to go out and buy addition speaker wire?
