Old 21-12-2005, 11:14 PM   #1
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
Default help installing new tfi modual
hey guys
cars playing up just stopeed dead and made a weird pop noise and it blew the rocker cover gasket out ,i asume that was the pop
the car wont fire
theres no spark at the coil or dizzy
so i think it might be the tfi modual
so want to know do you have to pull the dizzy out
or can you just undo the bolt and move it to the side
cheers jarrod
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2005, 12:38 AM   #2
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Blowing the rocker cover gasket out sounds a bit strange. It would be worth having another coil on hand to try as well, these go just as often as the TFI module.
To change the TFI module, take of the intake duct, idle control solenoid etc to give a bit better access. Mark the position of the dizzy so you can rotate it back to the correct timing. There is a bolt behind the dizzy that clamps it to prevent it rotating, loosen that off. It may be easier to rotate the dizzy if you remove the distributor cap. Unplug the TFI module. Using a stubby phillips head screwdriver you can remove the 4 screws holding the TFI module to the dizzy. Apply the heat sink compound to the new module, position and screw it on. Attach/plug in all the rest in reverse order.
outback_ute is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2005, 10:15 AM   #3
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
i changed the coil as well
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
Old 22-12-2005, 10:17 AM   #4
Walkinshaw
Two > One
Walkinshaw's Avatar
Are you on LPG?? Sounds like an LPG backfire
Old 22-12-2005, 10:32 AM   #5
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
nope not on lpg
i just did the head and cam ,was running great before it ,so maybe i didnt do the rocker cover up tight enuf
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
Old 23-12-2005, 02:02 AM   #6
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
ok i turfed the tfi modual and got a whole new dizzy
whats the go with changing one of these ,anything special i need to know ??
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
Old 23-12-2005, 08:46 PM   #7
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
ok im stuffed if i know whats wrong if it
ive changed the coil,smart lock modual,new complete dizzy,check fuses, has any one got any ideas whats wrong with it ????
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
Old 23-12-2005, 08:54 PM   #8
snypereb
[EBGLT]
snypereb's Avatar
Whats a tfi modual?
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 08:58 PM   #9
stockstandard
Can you turn the engine over and see the rotor turning? Might be something more mechanical than electrical.
Originally Posted by casper
Yeah, the car is ugly, I can live with that.
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 09:55 PM   #10
ebxr8240
Performance moderator
ebxr8240's Avatar
YES does it have compression? Is cam turning with engine rotation? Maybe timing chain is suspect? AS in jumped tooth or broken..When key is turned on does fuel pump opperate?? Checl all battery connections are good both earth & possitive..When was fuel filter last changed ??
Daily driver GTE FG..
Old 24-12-2005, 12:37 AM   #11
EDXR6T
Originally Posted by snypereb
Whats a tfi modual?
it's the grey colured solinode on the side of you'r dizzy man
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2005, 08:42 AM   #12
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
i havnt check the compression yet ,the chain hasnt snapped ,no idea if its jumped a tooth or anything ,fuel pump is new and working ,fuel filter is new ,batterys charged
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
