Old 10-01-2006, 06:56 PM   #61
-jjM-
-jjM-'s Avatar
....that sounds fed damo :S
-jjM- is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 07:00 PM   #62
naughtyfalcon
lack off fuel would do that,so start at the pump and work your way forward,it has to be something simple..or at least i hope it is.
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 07:47 PM   #63
efgiar
rofl copter
efgiar's Avatar
wow never heard a car start like that(try to start at least), its weird as.
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 07:48 PM   #64
galapogos01
eec tweaker
galapogos01's Avatar
sounds like compression to me. theres no resistance once the starter gets moving...
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 09:21 PM   #65
Damo
it deffinately has fuel at the rail. I'm gunna try another set of injectors tommorrow, do a compression test and move the dizzy around 1 tooth at a time. NZ has told me it should start even if the compression is very low.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 10:26 PM   #66
MacGyver
Before doing too much more stuffing around I would get a nice charged battery (or jumper) and do a compression check. As long as you have atleast 75psi the car should start, assuming everything else is OK. Now 75psi is crap and it means your engine is seriously shagged but it will run. You want at least 120psi+ on these engines with a variation of no more than 10%.
Next would be pull the injector rail and check to see if a nice strong mist of fuel is apparent when cranking the engine.
Now test ignition. Find TDC. You have a 50/50 chance of getting it right using the crank timing marks. Is the rotor pointing at number one spark lead. If not remove dizzy and rotate rotor 180 degrees and reinstall.
If you follow this then engine must start, assuming no catastrophic ECU or mechanical failure.
cheers
Scott
MacGyver is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 10:37 PM   #67
AUII_Forte
AUII_Forte's Avatar
Deffinately has NO compression at all. That's exactly how my EF sounded when I left the shims in with a standard cam. Take the rocker cover off and see if the cam is turning, if not the little dowel pin on the cam gear has stripped.....done that before as well!!
Don't stress too much, it's not lack of compression because the motor is slapped out, I'd be willing to put money on it being something to do with the valves/cam.
2003 Narooma Blue BA XR6 5spd Manual.
Pacemaker 4490 Extractors
2.5" Exhaust
High Flow Cat
SS Inductions "Growler" CAI
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
AUII_Forte is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 10:39 PM   #68
AUII_Forte
AUII_Forte's Avatar
After watching that vid again, it sounds like the cam isn't turning. It seems to be getting compressing on one or two cylinders, which would probably be the backfire type noise you're hearing.
My vote is the dowel in the cam gear is stripped.
2.5" Exhaust
High Flow Cat
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
Old 10-01-2006, 10:41 PM   #69
LUXO_8
windsor user
whip the rocker cover off and try and crank it.........
Old 10-01-2006, 10:54 PM   #70
Damo
well I changed the rocker rack in it but that's just bolts. Thanks for the suggestions guys, i'll pull the rocker cover off tommorrow and throw the battery from the EA in it. Where is this dowel that you speak of AUII_Forte ? at the back of the cam ?
Old 11-01-2006, 01:30 AM   #71
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
im assuming the bit that sticks into the cam gear at the front to ensure the cam turns with the chain?
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 02:24 AM   #72
ScoopED
Thumbs up for fossil fuel
ScoopED's Avatar
What I heard in that vid did not sound good at all. Definatly sounds like a lack of compression on a few cylinders. I dont think that it will be a fuel delivery related problem.
Have we ruled out the possibility of holes in the pistons?
Sorry if you have mentioned this already, but do you know the history of this motor.
It may be possible that the motor may have been run very lean and burnt through some of your slugs. Not a good scenario at all. But a possibility none the less. Do you have a borescope? or know someone who has one. It may be worth a look.
Deformation of the pistons may account for the resistance when trying to crank by hand.
Tho a more likely scenario is that some of your valves are staying open as someone has said previously. I hope that this is the case.
Best of luck
Mike
God created F-trucks so that you could put their engines into E series.
1992 EB Fairmont
351cu in Windsor Roller Cam
Valve Body "Shift Kitted" BTR 4spd Auto
Hi Tek Headers Tri Y
Twin 2.25 into Single 2.5in
17in x 8in BA XR8 Copies
235x45x17 Nankang NSII
Ultra Low King springs
Whiteline 30mm Swaybar
Nolathane box section trailing arms
Slotted DBA front rotors
Yella Terra roller rockers
ScoopED is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 03:45 PM   #73
Bobman
Regulator
Bobman's Avatar
Damo have you mucked around the the dizzy anymore?
My ea sounded like that (slow cranks) but it was all timing related..............
Hope you get it sorted, you got enough helpers?
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 07:56 PM   #74
Damo
had a nother play around with it today. Pulled the fuel rail off and had mum crank it, fuel ИИИИed out of the reg but not the injectors. :S Something arked under the manifol too and the was smoke and ИИИИ and a big bang. :O
So i'm gunna pull the manifold off and check everything under enith it, change the fuel rail and injectors with a spare on i have. Also pulled the rocker cover off and the cam is deffiantely turning over and the dowel on the cam gear is fine.
Old 11-01-2006, 08:03 PM   #75
naughtyfalcon
so it not getting any fuel at all aye,,that will do it.
2000 AU Wagon
Old 11-01-2006, 09:08 PM   #76
Au2falcons
Winter all year round
If you are not getting fuel out of the injectors check to see if the fuel hoses are the right way around. Fuel supply from pump goes into the rail, return hooks up to the regulator. It's a stupid thing but i've seen it happen before.
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it.
Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC
Au2falcons is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 10:39 PM   #77
Damo
fuel lines are deffinately the right way around. Was one of the first things I checked. Hopefully once it's back together tommorrow i'll give it another shot and it might fire up.
I'm picking up another block tommorrow anyways, it's an EB block with AU crank, rods and piston, i'll send my head off for a clean up and bolt it to this. I still think i'll be able to get this 3.9 started but if not the 4.0 will go in and should be good as new.
Old 11-01-2006, 11:37 PM   #78
Bobman
Regulator
Bobman's Avatar
Good luck... hope it goes well.
Sorry I didn't really catch on lately though - did the 4litre give up ? (ie since like 3 months ago) lol
Regards
Bobby
Current Cars:
Previous Cars:
Old 11-01-2006, 11:42 PM   #79
Damo
haha yeah the 4 litre blew a big chunk out of the timing case. It blew a fair bit of smoke anyway and wasn't worth repairing so a new motor was the best bet. If you look at my first post in this thread Bobby, there's a link to the thread when it blew.
I'm just glad I never sold my EA or else i'd be up ИИИИ creek without a paddle. I love my EA!!! <3
Old 12-01-2006, 01:13 AM   #80
Bobman
Regulator
Bobman's Avatar
Ain't that right, I miss my EA these days........... mainly because it was fully loaded with goodies, stereo, lsdlippery.. and MANUAL
Hmm, yeah you mentioned it was smokey.. its a good feeling when you get a new engine, if it works
Regards
Bobby
Current Cars:
Previous Cars:
Old 12-01-2006, 06:34 PM   #81
LUXO_8
windsor user
any luck today damo???
Old 12-01-2006, 06:45 PM   #82
Damo
nah, just picked up the new block.
I'm gunna finish puttin the manifold back on soon, couldn't find anything out of place down there. Hopefully these other injectors will get it going. I don't like my chances though.
Old 12-01-2006, 07:35 PM   #83
Sundeep
Sundeep's Avatar
Damn you got some bad luck Damo! Wish I could help ya mate.
Is your new block Hus's one? I don't like the chances of having compression in that one either :S
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 12:12 PM   #84
naughtyfalcon
so it still not running
2000 AU Wagon
