#61 | |||
Limited supply
#62 | |||
*barks incessantly
The middle back seat really wasn't built for a lady with a big booty btw. That's my real-world review of whatever type of hybrid camry I was in. |
#63 | |||
Limited supply
#64 | ||
The Bore and stroke dimensions of the good old Falcon 250cubic inch, then 4.1 crossflow, and then 4.0 SOHC and DOHC VCT is very well suited to running LPG.
I was in an FG Falcon taxi on my way to new job the other week and one of the first things I asked him was how many K's the Falcon had done? Indian driver (indian accent).....Oh 750,000k's original engine he said lol......'very good car the Ford Falcon'. EcoLPi's are even better.......Comp ratio, camshafts and ignition timing are all factory tuned to suit cheap as LPG.........Been seeing quite a few around Melbourne lately which makes sense as the system is so reliable. Love the way Broadmeadows got around the LPG priming ADR with the door switch. By the time you put your belt on and put the key in the systems ready to start! The Barra DOHC VCT 4.0 engine is one awesome, versatile, and reliable engine and i'll drive my BF wagon until the wheels fall off. ![]() |
4 users like this post: |
#65 | |||
15 years ago, there used to be many E-series in wreckers up here with "F*&^%d Head Gasket" scrawled across the screen in paint pen. You could always tell the ones that were cactus, as the wreckers left the engines in them. If the head was any good, it was out & sold within minutes of the car landing in their yard. Many a P-plater has proven the durability of the 3800 V6 in the same era Commodores too..... And Falcons are not immune to clear coat peel either - just like headlining failure - same suppliers, same issues. Even the locally assembled Camry has headlining issues at the same age as they develop in local Fords & Holdens. Seems you're a little too one-eyed to take an objective view of things. BTW - I expect to get 600,000km+ out of my FG (I'm past 1/3 of the way there) but we also got 485,000 out of a VS V6, without touching the engine, bar a water pump, and accessory drive pulleys. My AU2 company car was falling apart at 170K with oil leaks from the rocker cover, head gasket, and catastrophic transmission issues. It was not from abuse, and even the Ford dealer confirmed it. But do I use that example to say all AUs are crap, and all VSs are great? |
#66 | ||||||
Regulator
Nowadays you will find E series end up at wreckers for the exact reasons I gave. Unfortunately resale is not strong for the older Falcons, while older Commodores are worth much more. Quote:
Not one eyed, just have over a decade of experience within the taxi industry and 16 years in the automotive repair sector to know what works and what doesn't (including Commodores). Quote:
The issues with Commodore engines end up being an engine out repair. Even replacing the thermostat involves removing the transmission on Alloytecs. That said, I know someone with an Alloytec at over 300,000 on the same engine, but highway kms. An isolated example, but a good one.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
#67 | ||
*barks incessantly
As much as I prefer Falcons, VS Commodores were pretty reliable. I have seen first-hand an ecotech v6 overheated to the point that the radiator cap exploded, then a new cap and some water were put back in the radiator and it drove 100kms+ home and never had any problems.
It was off the end of the "H" on the temp gauge and had been stuck in traffic for like 15 minutes or longer. Pretty amazing tbh. I don't know whether a similar vintage Falcon would have survived. Btw, that's what happens when you don't plug the thermo fans back in after switching radiators... |
#68 | ||||
Just because a steel head gasket "cured" the E-series woes, doesn't change the fact that thousands of them (particularly EA-ED) went for scrap because they weren't worth fixing, and even now I'm seeing the odd EL in yards with the same fatal failure - so it's still happening. But you'll ignore that point by saying "that was 15 years ago" while at the same time proudly sprouting 16 years "experience" ![]() |
#69 | |||
Regulator
Took the oil cap off and a lovely amount of smoke came out due to the heat. Bit of water top-up, good as gold to get me home each time. In fact that would have to be the most neglected engine I've ever had the pleasure of owning that wouldn't die. No coolant, no head gasket concern. Feels bad having to scrap it as I couldn't kill it no matter how hard I tried. --- Now, back to the topic as this is a Ford forum, not a Holden forum. Saw a 2006 BF MkII Falcon sedan taxi stop outside my place tonight to give way to a neighbour's caravan back-in. Couldn't believe it, as these were taken off the road over 5 years ago and never before had this particular model been silver as a cab before here. ![]()
#70 | ||
*barks incessantly
Yeah mate, I love my Barra.
#71 | |||
