01-03-2005, 05:08 PM | #1 | ||
What would a car do if the timing was too far advanced?
Would this make it run rich? Thanx. Is it different for different cars? Thank you. |
01-03-2005, 05:13 PM | #2 | ||
PM me if you want
It would PING (pre-ignite), means trying to send the piston backwards, not good and will kill the motor. wont cause it to run rich that i know of.
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
01-03-2005, 05:42 PM | #3 | ||
GT4.
What you need to do is tune it to run on the best fuel you can. BP Ultimate or Optimax. You'd tune it so that with a tank of optimax or Ultimate the timing is advanced as afar as that it will just not ping and you leave it at that, as this is the furthurest you can put it.
With the engine tuned in this way it means that you can no longer use shit fuel, if you do, an octopus will come out of your exhaust and decapitite you. yeah nasty, i know. -Dan |
01-03-2005, 09:22 PM | #4 | ||
Thanx alot, bit scared of that octopus tho, but its not pinging or anything, some times its a bit "harsh" on start up.. Might bring it back jus a little bit.. Thanx alot.
02-03-2005, 03:26 PM | #5 | ||
Just get a timing light and roughly work out the degrees on your balancer... Make sure your balancer aint out though
02-03-2005, 03:27 PM | #6 | |||
