Old 07-07-2006, 04:48 PM   #1
RMCprime
EF XR6 5spd
Default speaker mounting
Does any one know what the maximum mounting depth for speakers in doors of an ef falcon.
Im looking at some 6-1/2 splits and they specs say the mounting depth is 70mm.
do you reckon they will fit.
RMCprime is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 08:05 PM   #2
bArNsY
bArNsY's Avatar
where about in the door?
the greatest width would most likely be benieth the window handle.
Pull ypur door trip off and find out.
I had trouble fitting 6"s in my old XD cos alot of speaker magnets where to large.
once you get the door trip off and measure the depth, then you can go to the store and check the dimensions (found on the boxes) and go from there
hope this helps
The Old:
1993 ED Fairmont
1994 ED Futura Classic Manual,
2004 BA MkII XR6 Turbo
2009 G6E Turbo (277.2rwkw @ Tuned at Bullet Performance Racing)
2007 Audi S5 4.2L V8 manual (Supersprint exhaust, MMI 3G+ retrofit)
The New: 2015 SZ MkII Territory Titanium Petrol RWD (With Sync 3 Upgrade)
Other Road Toys
Silver Surfer
2014 S-Works Roubaix SL4 road bike with Roval Rapide CLX 40 wheelset
The Adventurer!
2023 TREK Domane SL 7 AXS Gen 4
bArNsY is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 09:02 PM   #3
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
if you are putting them in the factory holes i would of thought they would fit as the originals would be close to that depth.
Remove one of your existing speakers and take it with you to compare at the shop.
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 12:02 AM   #4
ROOSTA
DFDFDF
ROOSTA's Avatar
hey mate.. my speakers are 65mm deep and they just scrub the window.. so if ya wanted to fit the new speakers you would prob just need to run a small 6 mm mdf ring spacer pretty easy solution.. other issue is cuttin out the hole for the 6.5"..
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
