Old 03-08-2006, 09:39 PM   #1
boodek
Ferret
Default AU3 - slow warm-up
Hi all, it seems from previous questions that the AU3 takes longer to warm up due to a bleed hole in the thermostat, which allows the radiator to warm slowly before the thermostat opens thus preventing damage to the plastic header tanks. Unfortunately this has the side effect of the car using a truckload more fuel as it warms up which is the period that the car is driven most. So, armed with all this knowledge, is there a workaround to get the car to warm up quickly (as my work BA ute does, for example) while preventing potential radiator damage? I'm sick of using 16-17 litres/100km!
boodek is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2006, 06:04 PM   #2
sbcb
BA Xr8
sbcb's Avatar
Ouch, my AU2 had the radiator mod done by ford as you described to prevent damage but uses about 14-15lt/100km with all cold town usage, 10lt/100km open road cruise. Try talking to a couple of radiator specilatists, might be able to install a better setup which might pay for itself, else email one of the sponsors that do the flash tuner and see if they can lean out that cold rich runnning period.
Ultimately it probably comes down to how long you plan to keep the car, is any outlay cost going to pay for itself? or will it be traded/sold within the next year or so?
sbcb is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2006, 06:23 PM   #3
howesy
howesy's Avatar
Cant remember how it was with the std one in but shortly after I got it new I changed the thermostat for an aftermarket 170 degree F unit Which and it don't run too cold and gets to temp in about two K's
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2006, 10:00 PM   #4
boodek
Ferret
Howesy, can you remember any more details? This is the sort of info I'm after.
Old 05-08-2006, 12:26 PM   #5
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
How long roughly is it taking to warm up ? , just makes me wonder if im in the same boat with my auII , mine seems to take about 10 to 15 mins worth of driving to warm it up / which mainly pee's me off in the morning because its freezing cold in the car and the heater blows cold air until the engine has warmed up ! - which by this time i'm already usually at my destination.
Is yours taking around this long to warm up ? , shorter time? , longer time ? , i'de like to hear how long it should usualy take for the auII xr6 vct to warm up . cheers.
:eclipsee_
Old 05-08-2006, 12:38 PM   #6
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Location: on my p.c now with internet! ok i'll still use works internet too.
Mine only take about 5min of driving to be warn & the heater blowing nice hot air.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2006, 01:15 PM   #7
f6 typhoon
yeah mine is the same as xr6vct-2000 i have a 2001 model au forte it actually takes about 15 min and in that time i am just at work so would this type of start stop hurt the motor in anyway cause i plan to keep the car for a while
f6 typhoon is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2006, 04:31 PM   #8
boodek
Ferret
It generally takes 10-15 minutes to warm up - the temp gauge needle reaches to just under the 'O' in NORMAL when at operating temperature.
Old 05-08-2006, 05:06 PM   #9
XR6-VCT-2000
Fantastic Plastic
sounds like i'm in the same boat then, now you have me wondering too if something can be done about it . cheers .
:eclipsee_
Old 05-08-2006, 05:14 PM   #10
howesy
howesy's Avatar
Mine was a Dayco unit. they only make in 3 temperature ranges now. 160 degree(DT14C) 180degree(DT14A) and 195 degree(DT14B).
And before anyone tells you a 160 dgree thermostat is too cold, they were standard fitment to some earlier model Windsors.
Old 05-08-2006, 07:31 PM   #11
peterban
AULTD
peterban's Avatar
My AU2 V8 has auto climate control and it takes about 3 km before the heater starts and blows out warm air.
What I do notice is that on cold morning even when up to normal operating temp it still leaves a vapour cloud when taking off from the lights.
It does run on gas so I don't know whether this is normal or not!!!!
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2006, 09:24 PM   #12
AUXRVIII
Fit a brass radiator the replace the thermostat. The hole wasn't drilled to protect the plastic tanks, it was to protect the aluminium core.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2006, 11:14 AM   #13
99FalconS
99FalconS
99FalconS's Avatar
Mine takes about five minutes to warm up not sure what thermostate it has. I have heard about them having the hole drilled in them i hope mine is ok you have me thinking.
99FalconS is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2006, 06:42 PM   #14
GTWHOA
Just cruisin
GTWHOA's Avatar
I let mine warm up for 5 mins or so in the morning but it still takes bout 10km of driving to warm it up. i might try unpluging the fans tomorro morning for the 5 min warm up and see what happens. I never use the heater in the morning because the engine runs cooler when the heater tap is open.
___________________
BA LTD 5.4
GTWHOA is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2006, 07:53 PM   #15
private9
www.TUFFCARPARTS.com
private9's Avatar
My AU3 takes about the same time as well, now he's got us all wondering!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2006, 12:02 AM   #16
XR6-VCT-2000
Fantastic Plastic
Ok , I just though i would mention the following !, after reading this thread and having the same sorta problems with my auII xr6 vct taking so long to warm up...
I have been so busy latelly and haven't had time to give my car some TLC ... I decided this afternoon to check all the fluid levels.
My powersteering fluid was low and also my coolant level was nearlly down to minimum.
I topped up both the powersteering fluid and the coolant. Since topping these up i noticed today that my car actually warmed up quicker than usual !!!! ( with more coolant ! .. strange ! ) , and also the heater blows out warm air now even when the car is cold !.
So it seems , even though you would think / i though anyways ( old school thinking , which im still working my way out of ! ) that coolant would make the stuff cooler and take even longer for the heater to warm up ( it would with a an old school 302/351 anyways ) , but is seemed to make my car run cooler but also made my heater work propperlly again before the car even heats up . strange .. lol .. but hey it worked , im ok now .. cheers
I also noticed that my car is kicking back gears much better up hill etc etc .
:eclipsee_
