Old 17-03-2005, 07:02 PM   #1
AdzT3-146
own the road
AdzT3-146's Avatar
Default Small Steering Complaint
Recently while driving sometimes my car's steering seems to sometimes favour the right while driving. also my car seems to jump about on the road a little, both of these things usually occur over 60 km/h. Any ideas?
T3 TE50 #146
Originally Posted by UNR8D
Id rather date a goat with syphilous then drive a maloo.
AdzT3-146 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2005, 07:07 PM   #2
svo347
AFF's 1st DM.......
svo347's Avatar
Are your shocks leaking oil???
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2005, 07:10 PM   #3
AdzT3-146
own the road
AdzT3-146's Avatar
No, not as far as i know, and how do i find that out?
T3 TE50 #146
Old 17-03-2005, 07:15 PM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
push around on the cars body , if its springy the shocks are u/s, also have a look for oil weepage from the shocky rod.
13.21 @107.7mph
Old 17-03-2005, 07:18 PM   #5
Racecraft
they call me Tibbo
Racecraft's Avatar
could be a worn tie rod end, or a worn lower steering shaft
When still and with the car not running, how much play is there left to right in the steering wheel before it actually starts to turn the wheels?
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2005, 07:23 PM   #6
AdzT3-146
own the road
AdzT3-146's Avatar
Racecreaft, i just checked it out and it's very stiff, not much movement goin on.
svo 347- it's a bit springy when you push it around.
T3 TE50 #146
Old 17-03-2005, 07:27 PM   #7
Racecraft
they call me Tibbo
Racecraft's Avatar
ok so chances are its not a steering problem but a geometery issue, Like svo 347 said look into shockies or even something as simple as rotating your tyres..
How low is it? My EL with superlows and 17" jumped everywhere until I fitted the castor/camber kit
Old 17-03-2005, 07:30 PM   #8
AdzT3-146
own the road
AdzT3-146's Avatar
It's pretty low, a can just touches the muffler, and it sits a bit lower at the front. i had a cambor castor kit fitted about 2 months ago but that was put on when i had my old 15's on the car.
T3 TE50 #146
Old 17-03-2005, 09:05 PM   #9
FRDXR6
FRDXR6's Avatar
Maybe just a wheel alignment is needed?
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2005, 10:19 PM   #10
AdzT3-146
own the road
AdzT3-146's Avatar
Yeh i thought maybe that too, but i thought i'd pose the question and hopefully i could get some useful advice.
T3 TE50 #146
Old 17-03-2005, 10:43 PM   #11
Sox
RIP...
Sox's Avatar
Sounds like an alignment is needed, very likely have too much negative camber.
Rick.
Oval Everywhere...
Old 17-03-2005, 10:45 PM   #12
InitialD
Low and Loud
InitialD's Avatar
My EA does what your describing but its due to the Tierod ends being worn.
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2005, 10:49 PM   #13
AdzT3-146
own the road
AdzT3-146's Avatar
When they installed the kit they put negative cambor on.
T3 TE50 #146
Old 17-03-2005, 11:16 PM   #14
Sox
RIP...
Sox's Avatar
You don't want any more than 0.5 degree negative camber, all it does is make them wander all over the place.
Give it more caster instead.
My XH had zero camber, and 8 degrees positive castor.
Rick.
Oval Everywhere...
Old 17-03-2005, 11:21 PM   #15
trueblue
01 Falcon Ute
have you got your car checked out since you got your rims and suspention fitted. Maybe a wheel alinement or your camber is out.?
AUII FALCON UTE 2001
WTD mags to suit AU Falcon ute, AU XR rims or BA 18" xr rims. PM ME
trueblue is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2005, 11:42 PM   #16
Sundeep
Sundeep's Avatar
I think it's the 17's bro. When I had them on my car they were tramlining all over the shop, especially when I hit bumps or braked.
An alignment should fix the problem, otherwise get the tyres replaced.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2005, 04:22 PM   #17
AdzT3-146
own the road
AdzT3-146's Avatar
I think i'll get it checked out after easter, don't have the time or money before then.
T3 TE50 #146
