18-03-2005, 02:53 PM | #1 | ||
Occasional V8 user...
OK, I'm going to remove the stock front blinkers from the Fairmont and install some clears...Having a brief look last night suggests that the headlights also have to be removed to do this. Is this correct? Are there any particular gotchas in doing this R & R (such as hidden screws/bolts tabs etc)?
Sorry if it's been canvassed before (probably ad nauseum, knowing my luck!)...If it has, a link to a howto or similar thread would be handy. |
18-03-2005, 03:10 PM | #2 | ||
yeah take the whole headlight out. Should be 4 or so 8 mm plugs holding the lot in plus the 2 plugs for the indicator and headlight. Take it out and 3 phillips head scrrews hold the indicator onto the headlight.
2 bolts above the headlight into the chassis, 1 behind holding it down in front of battery and airbox and also 1 on the inside near the side of the radiator. The last is the hardest to get to but still fairly simple. Hope that helps. Dan
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
18-03-2005, 03:38 PM | #3 | ||
V8 Ghia & BF2 XR6 + Wagon
The side bolts are the bitch.
4 bolts per light. Just remove a total of 8 small bolts, (dont forget to unplug the lights & indicator) Then pull the light out, unscrew amber indicator, replace with clear. Sounds easy. (for me it involves removing the front bar.. grrrrr)
Windsor now harmonically balanced for EARTHQUAKE free driving!: |
18-03-2005, 08:44 PM | #4 | ||
Thanks very much guys...Your advice worked a treat!
(Easiest mod I've done to a car yet!) Again, thanks! |
