Old 21-03-2005, 01:31 AM   #1
InitialD
Low and Loud
InitialD's Avatar
Default EA Ghia cluster into GL
Hey guys
As the CBF factor was high today with fitting the ghia wiring looms, etc I thought id put the ghia cluster into my car as ive sold my spack cluster.
Now Finally everything is working after 4hours of work (stupid "BATTERY (12+) Wire, without it wouldnt power LCD up :gren: )
Only problem im having is with the LCD backlighting. There are 2 wires (positive and negative) that power it. Now If I connect these to the Ignition wiring, the LCD powers up when the car is on, but I cannot ajust the brightness of it as it is way too bright at night.
If I wire the backlight into the Interior Lighting loom, the brightness can be ajusted but will only comeon when the parkers or headlights are on??
anyone got a thought on what to do?
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2005, 08:37 AM   #2
EA2BA
PM me if you want
EA2BA's Avatar
BEM = you should have come got the GHIA BEM :p
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2005, 08:41 AM   #3
dansedgli
dansedgli's Avatar
he has the BEM from my EB, will that work?
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2005, 10:03 AM   #4
spope
spope's Avatar
Yeah, you need to wire the lcd illumination into the Ghia BEM and use a ghia headlamp switch. Very easy to wire up... IIRC it is the white/black wire which is the lcd brightness.
Then it will be illuminated normally, and adjustable with the parkers.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2005, 11:06 AM   #5
niko
likes falcon's
niko's Avatar
theres a fader thing on the intirior light switch which is apart of the headlight switch, and that controls your brightness
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2005, 12:51 PM   #6
InitialD
Low and Loud
InitialD's Avatar
Ive worked out the backlighting, but NOW MY SPEEDO DOESNT WORK!!!!!
Ive connected the two speedo wires to the right places as per the Ford factory manual says, but it still shows 0kph all the time
HELP? anyone who has converted theres, Is there any extra wires for the LCD to work that i may have missed?
