Old 08-07-2007, 11:17 AM   #31
jjj
jjj's Avatar
Originally Posted by fairmont1998
The one advantage I can see with such a massive surface area is it'd take much longer to get dirty enough to affect the airflow.
Yep exactly what i thought as well, will be less cleaning and re-oiling and still allow high flow intake via the conical filter. God damn it makes my K&N panel filter look small where you work out the total filtering surface area.
It's a TORQUE MONSTER...............................
jjj is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2007, 11:23 AM   #32
sexr6tasy
so fitting this bigger pod filter has given you more performance then your 2.5 exhaust did? time for some dyno runs once its all set up i think
sexr6tasy is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2007, 11:23 AM   #33
mcflux
mcflux's Avatar
Sounds great that you can get so much of a difference from simply swapping a pod. Did you take a "before" dyno run showing tractive effort? Because it would be great to see the "after" dyno results and compare the differences.
Old 08-07-2007, 11:34 AM   #34
jjj
jjj's Avatar
Not putting it on a dyno, whats the point of verifying something that has already given me a good gain. If forum readers want to do this mod then it is up to them, i am not glorifying this mod i am just saying that on my low km engine and vgc auto box. I have received good gains by fitting a conical filter that has a larger surface area than the stock paper or K&N panel filter available for the EL 6cyl Falcon factory airbox.
But once again it's a TORQUE MONSTER!!!!!!!!!!!!!!!!!!!!!!!!!!
Cheers..
Old 08-07-2007, 11:51 AM   #35
jjj
jjj's Avatar
Here are the dimensions of the conical filter.......
RE-0810 Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 6 in (152 mm)
Flange Inside Diameter: 3 in (76 mm)
Flange Length: 1.75 in (44 mm)
Flange Type: Centered
Height: 9 in (229 mm)
Top Outside Diameter: 4.625 in (117 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Re-Oiling Amount: 1.92 oz (57 ml)
Flanges: 1
Inner Wire: No
Weight: 2 lb (0.9 kg)
Product Box Length: 11 in (279 mm)
Product Box Width: 6.5 in (165 mm)
Product Box Height: 6.5 in (165 mm)
cheers.....
Old 08-07-2007, 12:45 PM   #36
sexr6tasy
right
Old 08-07-2007, 01:00 PM   #37
FPVWEPN
Team Urinal Cake Racing
FPVWEPN's Avatar
lol TORQUE MONSTER!!!!! hahahha probrably the extra induction noise your hearing.
Oh also go drive around on a hot day and see hoe much heat soak you get :P
FPVWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2007, 06:31 PM   #38
Muscle_Inc
GT= The Gamble,The Legend
Muscle_Inc's Avatar
Seemingly having a larger surface pod filter benefits your car being a 6 cylinder, would there be advantages for the v8 windsors then?
Fred Gibson -Dump the clutch from a standing start, you could wheelspin the car with smoke bellowing of the car 1st, 2nd gear and wouldnt stop until 3rd gear.
Howard Marsden -They were at time rated supposedly as the fastest 4 door production car in the world.
Bill Bourke - Part of the GT that changed the auto industry of australia, i would say one word, exciting it added excitement to the industry.
-GTHO P3
Muscle_Inc is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2007, 06:31 PM   #39
mcflux
mcflux's Avatar
Originally Posted by jjj
i am not glorifying this mod ...
Ahh, weren't you the bloke who glorified a K&N filter (the one you just tossed out?) because after fitting it your car went like a CUT SNAKE!!!!one!!!eleventyone!!1 ?
Anyway, it's good to know that people get satisfaction from modifying their cars, no matter what the mod is. I think I'd display a similar reaction if I slotted a 514 between the rails, but good on you for your enthusiasm.
PS, I'm not a fan of that flange diameter. Nor the length.
Old 08-07-2007, 07:41 PM   #40
RG
Back to Le Frenchy
RG's Avatar
Yup, got one in mine.
Old 08-07-2007, 08:43 PM   #41
xr8 5.0
ED xr8 5.0l
xr8 5.0's Avatar
I picked up about .15 of sec in the 1/4 when i went to a bigger pod and a home made alloy/ply heat shield here is a pic.
ED xr8, STD 5.0l short block
AFR165 alloy heads
11.92 @ 113.5mph N/A
10.98 @ 122.2mph 100hp nos
377 RWHP @ 5900rpm N/A
No longer bottle fed, now with boost
9.67 @ 144 mph on 22psi
xr8 5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2007, 09:04 PM   #42
Grechie
Grechie's Avatar
looks nice
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 11:34 AM   #43
devilracer_01
Sleeping Beast
Mmmmmmmmmm Im almost convinced to go ahead with the pod filter rather than a K&N or BMC filter for the standard air box.
devilracer_01 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 04:27 PM   #44
[Tonko]
What's green is gold
[Tonko]'s Avatar
Ahahahahahaha!
Thanks, i needed that...
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 04:39 PM   #45
Sundeep
Sundeep's Avatar
If your car responds well to small modifications like that maybe you should try some hardcore stuff it'll run 12's easy NA.
Nah kidding, I reckon the difference you feel is in throttle response.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 04:40 PM   #46
raised by monkeys
raised by monkeys's Avatar
Originally Posted by CaRtZ
the $30 hose is cheaper than having a s/s pipe bent up... i've checked it out at a few local engineering companies. starts at about $60-70 (labour + materials)
dude! i had a 3" mandrel bent pipe for my ef, $40, $40 pod.
it has a bit better response and looks way better than that black of a pipe that closes round to about 1 1/2"
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 05:30 PM   #47
devilracer_01
Sleeping Beast
Good to see a member on here from my hometown
Old 09-07-2007, 06:08 PM   #48
Psycho Chicken
Psycho Chicken's Avatar
I'd change the spark plugs, they can give good power increases as well.
Old 09-07-2007, 09:45 PM   #49
mcflux
mcflux's Avatar
Don't forget the leads Rob-dog
Old 09-07-2007, 10:01 PM   #50
devilracer_01
Sleeping Beast
Any brand of platinum leads do the job???
Old 09-07-2007, 10:16 PM   #51
mcflux
mcflux's Avatar
Flange leads are the best brand. They're large bore, pink coloured. Bursons sell them.
Old 09-07-2007, 11:09 PM   #52
Stevo
Flange leads come in multiple different fittings too. Loose, Mid, and Tight
Heritage Green EL Ghia
Black AUII XR8 Ute
Stevo is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2007, 08:27 AM   #53
mcflux
mcflux's Avatar
Some of them last for a lot more kms than lesser brands. There's a niche brand, I've forgotten their name but the code number for the leads is BU77-53CK5. They come with extra hardy plug sockets. The leads are brown.
