Old 19-11-2013, 08:13 PM   #31
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: au timming chain cover removal
My 'how to' stopped my leaks but I wasn't losing anything like 2 litres in 2 weeks. It is a bugger, I was thinking to run some chalk lines in different places to see if I could track were most of the leak was coming from before I found Whoosa how to. You might need to try that at different heights etc to see where your is coming from.
Good luck
UK
Old 19-11-2013, 09:47 PM   #32
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Keep in mind that the cam sensor has an o ring on it as well. It will look like a crank seal gone bad. But that amount of oil, may well be the tensioner if the leak is around the front of the engine.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2013, 12:04 PM   #33
Rfordsfun
Thanks all, is timing cover top of tensioner plug and side,right between block and tensioner port, hell of a place! 10 times cleaning and siliconing, fed up sheesh, about to put old engine in! did tensioner Oring, thread tape, silicone vct idler pouring out of their? How does that work ? Odd. Slathered with gasket goo, lol if not working might try metal putty, or remove and fix properly jus my luck ! Should of done it prior! Word from the not so wise 4 litres of oil in my local spots, let alone my drive way <- fords new symbol
Rfordsfun is offline   Reply With Quote Multi-Quote with this Post
