Old 15-05-2009, 11:17 AM   #31
Kariharnett
Lil Henry
Kariharnett's Avatar
Originally Posted by Piotr
In mine I find going 3rd-4th and then Reverse does the trick
So really your pushing your clutch in selecting third and fourth then reverse???!??!?!?
Lets say it takes 3 - 4 seconds to do that menouvre, at the same time you have your clutch in to do that........ wouldnt you think to just push your clutch in for 3 seconds to save wear and tear on having to unnesesary wear on the gear box?
Kariharnett is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2009, 11:22 AM   #32
Candyman2
Zetec 09 5 DR in Vision
Originally Posted by pitpal
Gave them a demo on it including leaving the clutch down for 2-3 secs in which they told me that i shouldnt have to do this.
Hopefully, the stories about Ford service techs are not true in this case because if they say we shouldn't have to do it then it should be fixable ...
Will look forward to what they can do for you and I'll see what they can sort out at our service tomorrow.
Candyman2 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2009, 12:46 PM   #33
Piotr
Non-Regular Member
Id hate to see how slow your gear shifts are. The process is alot quicker than 3 seconds.
The gearbox would get no wear and tear from those movements
2005 Renault Sport Megane 225
Old 15-05-2009, 06:51 PM   #34
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Another suggestion is, if the car is parked and you have to reverse out of your spot, select reverse prior to starting the car. No crunch then.
Old 16-05-2009, 04:56 PM   #35
Candyman2
Well, they dumped the gearbox oil and refilled it.
Gotta say, it is better.
I got the oil and filter change as well (supplied a fully synthetic I bought).
I was rather surprised how carbonised the old oil was after just 3,000km.
Was suggested the fuel economy should improve (seemed to be running rich) - they did the usual safety check, checked the ECU and error codes - all good.
Didn't apply the USB update - they said it already had the update done. Maybe it came in the software update the Germans emailed over.
They did a pretty good job I must admit. Goes against the horror stories that seemed to be around about Ford Service Depts.
I declined the wash and vacuum ofcourse.
All done in an hour and a half.
Old 16-05-2009, 09:28 PM   #36
pitpal
pitpal's Avatar
Why the gearbox oil after only 3000kms?
pitpal is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2009, 09:35 PM   #37
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Originally Posted by greenfoam
Ford ran the T5 almost forever and they struggle to get into reverse on Holdens, it's the same box so surely they do the same on the Falcons.
Reverse is fine. Notchy from 2 to 3 and be a pain in 1st.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2009, 10:24 PM   #38
Candyman2
By request - to solve the reverse issue. Which is seems to have done.
Old 17-05-2009, 02:11 AM   #39
greenfoam
Candyman what oil did you get put in it (the gearbox)
greenfoam is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2009, 06:28 AM   #40
Candyman2
Redline MT90 was used. Not sure what was in there before, the Ford guys didn't know either.
Old 17-05-2009, 08:05 AM   #41
Candyman2
Oh and they didn't know what to do about the carpet in the footwell. They were going to screw it to the rubber firewall lining but I told them not to bother.
Got home and I used some 3M industrial strength double sided tape (wiped both surfaces with meths) and stuck it down with that.
We walked up to the dealers yard while we were waiting- sheesh they have a few Fiestas on the yard. We counted 6 incl white, black, vision, silver and 2 of them were Zetecs !
That blue dash is a bit of an eyeful and I still can't get used to the purple dash either.
Kinda like the funky seat design in the LX's though
Old 17-05-2009, 11:04 AM   #42
greenfoam
The girl that works at the local dealer here still doesn't have her Squeeze Zetec that she ordered in Feb as far as I know
Old 19-05-2009, 12:31 PM   #43
KREEPIBUGGA
KREEPIBUGGA's Avatar
I get the same thing with our WQ LX 1.6 manual.
I'd go with waiting for 3 seconds. Works for me - my fiancee just slams it :S
When we told Ford about it, they told us all manual Fiestas do it.
wish I had a Transit
KREEPIBUGGA is offline   Reply With Quote Multi-Quote with this Post
