Old 02-07-2009, 01:05 PM   #31
james22
With da Warlords
james22's Avatar
Originally Posted by SLO AU XR8
which fuse is that which you pulled, in the engine bay or interior? as my AU has no ABS and the Thermo's don't work
Fuse No. 7 - ABS & Cooling Fans / 10amp (red) - Interior box
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 02-07-2009, 01:09 PM   #32
james22
With da Warlords
james22's Avatar
Originally Posted by BLUEPRINT
JAMES!!! What did you do to my heads??!!! damn, now i need to get alloy ones now! :( which i may have had to do with a stroker at any rate...
Sounds like your block might be unharmed aleast, which is a good thing... and this means that we can build strokers together... i'll give you a call up soon my friend...
Yeah block and internals look ok, i think i might have got away with the heads too. (shave and should be good) But i have definitely fried piston rings. Stayed up all night last night pulling it apart. Don't really want to do anymore, because i'm unsure where to sort of go from here.
Should i just pull the entire engine out, and send it away to autotech or something? or take it to a local grease monkey for a freshen up, (new rings, gaskets etc) or what the hell do i do..... I'm so dissapointed right now lol
Windsor Warlords
AU III XR-8220
Old 02-07-2009, 01:15 PM   #33
InfernoSR
Sales Representative
InfernoSR's Avatar
There is a local engine builder here that can help you out... he's a good friend of mine and will look after you and do your spanner work.
Old 02-07-2009, 01:25 PM   #34
ten[A]cio[U]s
ten[A]cio[U]s's Avatar
Far out that sucks james, all from a fuse!!
Daily: AU Forte Wagon
Project: AU Fairmont - Wants to be turbo
The Family Car: 2009 G6E Turbo
Future fun: 1968 Ford Galaxie 500
ten[A]cio[U]s is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2009, 01:28 PM   #35
james22
With da Warlords
james22's Avatar
Not wrong there mate lol. Good excuse for more powah!!!! though lol :
Getting the money together though is another thing :-(
Windsor Warlords
AU III XR-8220
Old 02-07-2009, 03:20 PM   #36
InfernoSR
InfernoSR's Avatar
I understand that all to well... seeing i am now in a much lower paying job right now...
and you can never have enough excuses for more power! :
Old 06-07-2009, 08:40 AM   #37
james22
With da Warlords
james22's Avatar
Well over the last couple of days i have noticed a pool of oil forming under the car. It must have been bloody hot, because it appears to have cooked the oil filter sealing ring. Other than that, not a whole lot to report.
Gotta play the waiting and saving game now.
Windsor Warlords
AU III XR-8220
Old 06-07-2009, 10:51 AM   #38
james22
With da Warlords
james22's Avatar
So i'm starting to lean towards just selling it or trading it. A nice BA-BF F6 Typhoon I think
Windsor Warlords
AU III XR-8220
Old 06-07-2009, 10:53 AM   #39
RG
Back to Le Frenchy
RG's Avatar
Don't do that, maybe find a second hand engine to go in.
You'll lose too much cash selling a broken car.
Old 06-07-2009, 10:59 AM   #40
james22
With da Warlords
james22's Avatar
I don;t think a dealer would even pick it. Starts and runs fines, no noticable loss of power. No leaks, other than the oilfilter and drop out of the rear main. Doesnt appear to be losing coolant, but not 100% sure on that.
So if i fixed a few things, I may be able to trade it... I really don't know what I want to do, but either way I can't justify spending 10-15k building a engine that will still get beaten by a stock f6 lol
Windsor Warlords
AU III XR-8220
Old 06-07-2009, 11:01 AM   #41
RG
Back to Le Frenchy
RG's Avatar
10-15k rebuild and you wouldn't get done by a stock F6, trust me.
A 220kw engine with decent k's can be had for $2800 from intake to exhaust.
Old 06-07-2009, 11:03 AM   #42
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Well if a dealer can't pick it, do it. Sounds like the car to you now is a liability not an asset, so if i were you i'd move on from my problems.
Old 06-07-2009, 11:03 AM   #43
james22
With da Warlords
james22's Avatar
I'll keep pulling it apart, till I work out exactly what needs to be done.
If it is still in reasonably good nic (mechanically) I'll replace the rings, gaskets, seals etc - effectively refresh it instead of rebuilding and then sell or trade it I think
Windsor Warlords
AU III XR-8220
Old 06-07-2009, 11:06 AM   #44
james22
With da Warlords
james22's Avatar
That also sounds like a very viablse option. That sounds cheaper than re-freshening my existing would it not?
It would have to cost at least $2000 to buy all new gaskets, head bolts and machining. Then labour to reassemble...
So this may be cheaper?
Where have u seen an engine for $2800?
Windsor Warlords
AU III XR-8220
Last edited by james22; 06-07-2009 at 11:26 AM. Reason: forgot a 0 - i wish it were 200 lol
Old 06-07-2009, 11:09 AM   #45
RG
Back to Le Frenchy
RG's Avatar
It would have to cost at least $200 to buy all new gaskets, head bolts and machining. Then labour to reassemble...
I'll send you the details of the bloke if you want.
Old 06-07-2009, 11:16 AM   #46
InfernoSR
InfernoSR's Avatar
Dont you dare sell it... unless its to me... cheap... lol!
Old 06-07-2009, 11:29 AM   #47
james22
With da Warlords
james22's Avatar
How much does everyone think, it would cost to re-condition the engine?
New headgaskets, machine heads, replace piston rings, new head bolts etc, whatever is required in this case? + Labour?
$4000 or so??
Windsor Warlords
AU III XR-8220
Old 06-07-2009, 11:31 AM   #48
RG
Back to Le Frenchy
RG's Avatar
$4000 or so??
Sounds about right, try to do as much of the spanner work as you can though if you are confident enough.
Old 06-07-2009, 04:35 PM   #49
SIKSIX
Its gone V
SIKSIX's Avatar
Try doing a leakdown test to find out if its head or block issues.
SIKSIX is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2009, 02:30 PM   #50
james22
With da Warlords
james22's Avatar
Well I've found another car to replace my XR I believe. Just gotta wait for the finance and stuff to go through. We will see how it pans out...
http://www.carsales.com.au/used-cars...s=5&__Qpb=true
sorry for the hell of a link lol
Windsor Warlords
AU III XR-8220
Old 13-07-2009, 02:41 PM   #51
RG
Back to Le Frenchy
RG's Avatar
Big girl....
Old 13-07-2009, 02:52 PM   #52
b2tf
not here much anymore
b2tf's Avatar
the new one wont sound anything like the AU......
Sorry to hear mate but I have only one word to say:
IDIOT
Sorry just had to get that out.:
2024 F150 XLT
Old 13-07-2009, 03:21 PM   #53
james22
With da Warlords
james22's Avatar
lol they are offering 9000 to 10k trade.... that helped sway the decision alot. and thats even unregistered lol
Windsor Warlords
AU III XR-8220
Old 13-07-2009, 03:22 PM   #54
RG
Back to Le Frenchy
RG's Avatar
Ouch.
Old 13-07-2009, 03:28 PM   #55
james22
With da Warlords
james22's Avatar
yeah but everyone else was only offering 6000- to 7000, so i'm alot happier with 10.
For 6 - 7k, i'd keep it
Windsor Warlords
AU III XR-8220
Old 13-07-2009, 04:10 PM   #56
InfernoSR
InfernoSR's Avatar
when do you want me over to swap out some of the parts for stock ones? lol
Old 13-07-2009, 05:06 PM   #57
james22
With da Warlords
james22's Avatar
Sorry mate... Part of the reason he offered me another 3000 - 4000 was for the presentation of the car. He originally offered 6 to 7 thousand. But when he seen the photo's and mod list, he straight away upped it to 10k, without even seeing the car.
He is willing to give 11k if its in as good condition as it looks in the photos.
I asked him if I removed some stuff etc, but he wants it like it is or he'll give me less.
He's got photos of all the gear, and a list. Polished manifold, Silicone hoses, scuff plates, steering wheel, shifter the whole lot.
Sorry man, but its not worth losing so much money taking it all off.... I did try though :-(
I feel bad now lol.
So for all the B-series freaks lol, how does this one look? I obviously like it, or I wouldn't have paid the deposit already. But what does everyone think, (except for my v8 friends lol - enough flaming already hehehe)
Windsor Warlords
AU III XR-8220
Old 13-07-2009, 05:19 PM   #58
The Monty
Just slidin'
The Monty's Avatar
Youll be back. They always come back...
MD Mondeo - For the family
NP Pajero - For the adventure
Old 13-07-2009, 05:25 PM   #59
Peuty
Afterburner + skids =
Peuty's Avatar
Hmmm, that's gay.
Oo\===/oO
Old 13-07-2009, 05:39 PM   #60
GK
Walking with God
GK's Avatar
I'm glad you've got a deal that you're pleased with.
It's sad to be losing another AUvian, but eventually most of us will move to a newer model sooner or later. Some of us will be able to keep their AU and get another, but for most of us, finances won't really allow that.
All the best with it, I hope your finances come through.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
