Old 14-08-2009, 09:23 PM   #31
JC
JC's Avatar
Originally Posted by RG
I interpreted it as "Pull the battery terminals off every 2 months or so, that should help with your fuel consumption issues"
The ECU doesn't "lose it's tune" as you say but rather it learns your bad habits over time. A Reset will fix this issue.
Since when did you know how to translate gobbledygook? You did well to get that out of the original!
Ford Performance Club ACT
Old 14-08-2009, 09:30 PM   #32
RG
Back to Le Frenchy
RG's Avatar
I am quite fluent in "drunken post" JC.
Old 14-08-2009, 09:51 PM   #33
XR6Runner
Sling Shot
This thread made my day! So much gold and classic!
XR6Runner is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2009, 07:37 PM   #34
JC
JC's Avatar
Thass gerd ti neoooo.
Old 15-08-2009, 08:28 PM   #35
RG
Back to Le Frenchy
RG's Avatar
Yes it is good to know isn't it.
Old 23-08-2009, 03:24 AM   #36
frd906
ok i have changed the o2 sensor and still using it, so today i commence operation, change my cataylic converter as mine is stuffed, so no more baggin me about it being hollow
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2009, 03:26 AM   #37
frd906
im putting in a smaller cat, which is a high flow one
Old 23-08-2009, 06:44 AM   #38
The Monty
Just slidin'
The Monty's Avatar
Fuel consumption can be just associated with the way you drive. If I flog my car, Ill get 250k's to the tank around town. Get it on a highway and Ill see 600.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 23-08-2009, 08:02 AM   #39
frd906
not really, i was still getting 500 to 600 to a tank of fuel, but latly is starting to use it a bit
Old 23-08-2009, 08:13 AM   #40
frd906
i dont want to start no but, i have a ecu in melbourne at the moment, its being wiped of all factory codes and all reinstalled with a chip, but i will be getting it flashed to a manual as i will be going manual very very soon, sick of auto
but i think my ecu is startig to lose its mind,
quick question, does premium unleaded spouse to stink out of the exhuast pipe
Old 23-08-2009, 09:45 AM   #41
DJM83
Barra Turbo > V8
DJM83's Avatar
What does it smell like? My TE will smell a little bit upon start up as it runs rich when its cold, but after that its fine. What fuel do you run?
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2009, 10:03 AM   #42
JC
JC's Avatar
If it smells, it's a sure sign your cat is stuffed (which you already know). Why use premium? You're only pouring money down the drain, as the AU ECUs only need normal ULP and don't adjust if you put a higher rated fuel in.
If you are getting 400 to 450km around town, that's about standard for the good old ford I6.
Old 23-08-2009, 10:23 AM   #43
frd906
doesnt the o2 sensor change the fuel and air mixture to adjust it self, i vary between unleaded fuel and premium fuel,
and yes i am doing OPERATION CHANGE MY CAT, TODAY
Old 23-08-2009, 12:00 PM   #44
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
Originally Posted by POELWYK
pull the pat turms off every 2 months or so that sould fix it and stop it from happing
wow what drugs was i takeing when i typed that ^^ -_- lol
yeah it was ment to be
thanks Rg for working out what i was trying to say
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2009, 12:02 PM   #45
frd906
just did that recently but its still using it, pulled the o2 sensor out last night, was all good, so i cleaned i up, ran the car with out it hooked on for a bit, then i connected it back together she seems to run lot better, but i am changing my cat today
Old 23-08-2009, 01:32 PM   #46
DJM83
Barra Turbo > V8
DJM83's Avatar
It it recommended that i use 95RON+ in my TE though.
Old 23-08-2009, 05:26 PM   #47
JC
JC's Avatar
I wasn't aware they made a TE with an I6 in it. The "Synergy" V8 (200kw jobbie) and the 200kw and the T3 motors all need Premium, but premium in a car that doesn't have a tune, nor the capability to adjust for the RON rating of PULP, just isn't required.
The only benefit in running the higher octane fuels in the I6 is that most of those fuels have cleaning additives that standard ULP doesn't (at least Vortex 94 & 98 does, not sure about Shell, mobil etc) which helps keep the injection system clean.
A lot of European and some Japanese 90's and early 00's model cars recommend to run on PULP, but will run on ULP as they drop the tune a bit and retard the timing for the lower grade fuel (mostly to cope with the standard of US fuels). The good old I6 falcon (at least up to AU3) does not do the opposite.
You can tell your self that you'll get an extra 50km per tank, and more throttle response etc on PULP, but it's all in your head.
Old 23-08-2009, 05:50 PM   #48
DJM83
Barra Turbo > V8
DJM83's Avatar
I wasn't aware they made a TE with an I6 in it. The "Synergy" V8 (200kw jobbie) and the 220kw and the T3 motors all need Premium, but premium in a car that doesn't have a tune, nor the capability to adjust for the RON rating of PULP, just isn't required.
Fixed that up for you.
No need to get shirty i was just making a valid point. You did say AU ECU's not I6 ECU's.
Old 23-08-2009, 07:19 PM   #49
JC
JC's Avatar
Thanks - hit the wrong number twice! That wasn't shirty, that was sarcasm, and I said AU ECU in relation to I6.
Anyway, the point's been made, up to the OP wether he listens or not, but as I'm not his mate, and we all know how much his mate knows, this might all be over water off a ducks back.
Old 23-08-2009, 07:20 PM   #50
frd906
what do you mean?
Old 23-08-2009, 07:28 PM   #51
DJM83
Barra Turbo > V8
DJM83's Avatar
Anyway that clears the confusion lets move on
Old 23-08-2009, 07:30 PM   #52
frd906
will post updates on my mysterious fuel comsumption,
Old 25-08-2009, 12:37 PM   #53
frd906
ok good news, back to normal
i pulled the o2 sensor out, cleaned it up put it back in but left it un connected, ran car for bout half hour, then reconnected it back up and left it again,
and it has finally re set it self and im getting my usual 300 k out of half a tank so its all good thank god
Old 25-08-2009, 12:43 PM   #54
frd906
but still have to change my cat
Old 25-08-2009, 01:51 PM   #55
blueoval
Critical Thinker
blueoval's Avatar
go metal core cat rather than ceramic.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2009, 01:58 PM   #56
burnz
VFII SS UTE
burnz's Avatar
does the i6 still run "map" sensor, not maf.
if so check vacuum hose for crack's/split.
GO SOUTHS
Old 26-08-2009, 08:54 AM   #57
torana04
yeh matt go a metal cat. better then the ceramic
torana04 is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2009, 08:58 AM   #58
frd906
metal high flow cat + new pipe + fitted, is about 250 bucks fitted, this a good deal or not?
or do i just cut and weld a temporay cat in its place for now till i have the money to get it done properly
Old 27-08-2009, 03:50 PM   #59
frd906
ok car is going in tommoro, for new high flow cat + pipe+ gaskets, bolts and flanges, plus labour for 300 bucks, so will make a new exhuaust video tommoro
Old 28-08-2009, 10:05 AM   #60
frd906
well i have just come back from my exhuast shop, they put the car on the hoist and found my exhuast bolts on the head are lose, and the flange which connects my cat to my exhuast system has blown the gasket out and is leaking, but my cat is not stuffed, cat is still in perfect condition
so for all you guys who kept telling me i am polluting the air, well i have just proved you wrong
