05-01-2014, 05:51 PM | #31 | |||
05-01-2014, 05:53 PM | #32 | |||
VFII SS UTE
if bundy distillers setup their own sevos, a different thread would emerge.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
05-01-2014, 05:56 PM | #33 | |||
They hav'nt because the consumers don't like it...... Supply and demand! |
05-01-2014, 05:59 PM | #34 | ||
82 united servo's within 50 klms of Melbourne, have no idea about Caltex ones, yep stuff all around Melbourne
05-01-2014, 06:02 PM | #35 | |||
I work for myself, not a LPG supplier, we install LPG kits from several suppliers, we also modify and tune cars for ethanol based fuels as well, there is different ways to go about running cars, we are not one eyed just to believe in one, but what suits one customer may not suit another.
05-01-2014, 06:03 PM | #36 | ||
Have you considered the demand is not there because people are not aware of any of the benefits?
Not to mention I vaguely recall quite a while back there was all the scaremongering going on about damaging the cars fuel system and what not. It is widely used in countries such as Brazil and the US. |
05-01-2014, 06:05 PM | #37 | ||
High ethanol fuels can damage some fuel systems and the corrosive properties can cause rubbish to break free from the insides of the fuel tank and lines and cause fuel filter issues if not regularly replaced initially, some call this the cleaning properties
05-01-2014, 06:08 PM | #38 | ||
Thailand Specials
I've been using United 100 in my Falcon, has ethanol content, would that be cleaning inside the fuel system?
05-01-2014, 06:08 PM | #39 | |||
VFII SS UTE
oil companies loose money selling ethanol, not make money.
05-01-2014, 06:11 PM | #40 | |||
E10 is not even worth bothering with! |
05-01-2014, 06:20 PM | #41 | |||
Member
If you want to talk about products that didn't work, let's talk about Ford's Ecoboost and EcoLPI which failed miserably in the market. They were distinct models that did not sell, unlike Commodores that feature the E85 compatibility across the range regardless of whether people choose to use it or not. |
05-01-2014, 06:28 PM | #42 | ||
05-01-2014, 06:28 PM | #43 | |||
I wish there were more pumps and more suppliers than just Caltex who won't provide a guranteed ethanol percentage and United who around here are largely look like run down private servos. |
05-01-2014, 06:33 PM | #44 | ||
Thailand Specials
05-01-2014, 06:37 PM | #45 | |||
I think the whole idea is flawed considering how much energy goes into growing/producing the fuel before it even gets to the pumps. At least LPG/LNG comes naturally from producing petrol/diesel. |
05-01-2014, 06:39 PM | #46 | ||
05-01-2014, 07:06 PM | #47 | |||
Thailand Specials
I don't really bother about how much fuel costs, I always go to the same few servos, for the Falcon its United in Sunbury and for my other cars the local Shell servo in town. $75 to fill the Focus with diesel $100-$110 usually for the Falcon $150+ for the Ambo None of our petrol cars get 91 anymore, the local servo only sells 91 or 98 so they get 98, the new Caltex has everything except E85 but they're a bunch of tossers so we don't use them and their diesel makes my Focus run like crap compared to the Shell one. Last edited by Franco Cozzo; 05-01-2014 at 07:14 PM. |
05-01-2014, 07:31 PM | #48 | |||
05-01-2014, 07:45 PM | #49 | ||
E10 fuel has various octane ratings, any ethanol content will result in slightly more fuel use due to it's stoich value, the lower the ethanol content then the closer it will be to unleaded fuel.
There is no power benefit unless tuned for it
05-01-2014, 07:56 PM | #50 | ||
AU II XR8
What a shemozzle
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
05-01-2014, 08:06 PM | #51 | |||
Trev
But then again I did use to run my first car on Avgas when there were only two servos in Perth with a bowser, fill the Charger and four jerry cans in the boot each time, lol. 200 thou off the top of the TRW forged flat top pistons just to get valve to piston clearance (.517 lift) after I stroked it (from 3.31 to 3.58 - 360 crank with turned down journals in 318 block with 30 thou over took it to 355), compression ratio was a little high :-)
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) Last edited by mcnews; 05-01-2014 at 08:16 PM. |
05-01-2014, 08:07 PM | #52 | |||
05-01-2014, 08:07 PM | #53 | ||
At what temp does ethanol burn as opposed to usual unleaded petrol?
I mean we have heat rated plugs for a reason and they are there to burn regular fuel not this rubbish, so if it burns hotter than regular wouldn't it cause internal damage? Sent from my iPhone using Tapatalk
When a car gets past you, you just want to go after them, you want to chase them down, you want to pass them. It's primal. But then there's another side to it, where you just completely forget about all the other cars on the track, and you feel like you're in another world. It's just you, at one with the road and the car. Eric Bana |
05-01-2014, 08:08 PM | #54 | ||
05-01-2014, 08:42 PM | #55 | |||
What I am talking about is the full strength E85 that was supposed to take the world over.....That's 85% Ethanol fuel per every litre. It has been a flop and it is overwhelmingly obvious because the servos ar'nt changing all of there 91,95,98 pumps to E85 are they??? Why? Because the manufacturers cannot see the benefits of making cars that run this type of fuel! |
05-01-2014, 08:44 PM | #56 | ||
Member
Absolutely. Every petrol engine in the range is E85 ready, from 3.0 Evoke to 6.0 SS.
You can browse their recommended fuels in the spec sheets here: http://www.holden.com.au/cars/commod...specifications |
3 users like this post: |
05-01-2014, 08:49 PM | #57 | |||
It's a flop? why? because you have not noticed any bowsers or know of very many cars running it Every new United servo is putting in E85 bowsers, they must think it is a flop. LPG was real popular years ago wasn't it, took a long time before bowsers were fitted to most servo's
05-01-2014, 08:59 PM | #59 | ||
another misconception, good power can be made from LPG and cheaper to run per tank, but many people have no idea and live in the past and make comments like it's only good for BBQ's but that's getting off track now
05-01-2014, 09:19 PM | #60 | |||
VFII SS UTE
in brazil there is no petrol just ethanol/biodiesel, so oil company's don't rule the roost.
