Old 01-06-2008, 05:33 PM   #31
ohzone
Dent Removal
ohzone's Avatar
Originally Posted by scrivens
Think it may have been mentioned earlier in this thread, but what the tool sellers etc don't tell you is that the tools have to be moved outwards to depress the internal clips from their locking position in the mount to allow the unit to slide forward. Just pressing them in and pulling doesn't work as the clips haven't been depressed - that "click" is just the end of the tool clicking into the slot. Push them in, then with your thumbs hooked in the tools and pulling each one out towards the doors, pull both your hands towards your body. I've done a few and have never had a problem.
Exactly right Mate! tried it this way and it was out in about 10 seconds, oh and you are definitely best to "just" insert the tool ends in the clips rather than pushing them in a long way :sm_headba
ohzone is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2009, 03:44 PM   #32
ECOJET
ECOJET's Avatar
agreed again
I purchased the tool off a seller on ebay for $10 shipped. After trying to make dodgy tools with drill bits, allen keys and coathangers with no luck, this tool went in and, following the technique above, got the radio out in 5 seconds!
ECOJET is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2009, 08:53 PM   #33
aye you
The Origional, The Best
aye you's Avatar
someone's been thread mining....
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2009, 06:22 PM   #34
Trav89
I cut a clotheshanger up, worked a treat.
Trav89 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2009, 09:23 PM   #35
blue95
Same here, just roughly followed the dimensions on the diagram.
blue95 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2009, 06:35 PM   #36
Bodza
Thank you for all those posts! It worked well for me (not 5 seconds but eventually!) and was able to remove the radio from my car. Great directions and advice that was easy to follow. Much appreciated.
Bodza is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2011, 08:02 PM   #37
Agent007au
Default Re: au radio removal
Thanks heaps for the info guys. I tried to remove my player several months back but gave up after a few hours. This time I followed the instructions above to make my own tools from a wire coathanger. It finally came out after a couple of minutes. You definitely pull the tool hard outwards towards the side doors then pull the whole unit out out. You can do it by yourself but need to use some effort here. lol
Now I'm going to fiddle with it and clean it to see if it will play my original CD's consistently again.....instead of having to bash the front of it to get it to play or eject a CD. lol Wish me luck!
Agent007au is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2011, 10:09 PM   #38
ronwest
All Bran = Regular Member
Hey, welcome to the forums.
Sometimes the old posts are the most valuable
You'll need more than luck to get it working properly... a miracle would be more likely, lol.
Old 07-11-2011, 06:24 PM   #39
fordfreak22
I used a coat hanger myself, took a little bit of time but it came out. Those tools on ebay would be a lot quicker.
fordfreak22 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2011, 09:45 AM   #40
turquoise
I broke one of the clips when removing the tape deck, she was stuck nice and good. Screw driver and a pair of pliers soon sorted it out tho, I think it's called 'destructive removal'!
AUI XL Ute in Fleet White
Country VIC
turquoise is offline   Reply With Quote Multi-Quote with this Post
