12-01-2007, 01:24 PM | #31 | |||
Mopar/No Car
Shame on you, Ford! And to think Vic Bray is getting however many thousand horsepower out of a Hemi V8! To think that the Fabre cortina runs 200 mile down the 1/4 on a small block! Where's the GTP's in the VPW top 10, huh? Shame, Shame, Shame!
ColumnShift Media '72 Plymouth Scamp '80 Courier '13 Kawasaki ZX14-R '13 Berlina '92 Suzuki DR650 If you don't fight - You lose
12-01-2007, 01:26 PM | #32 | ||
under new management
It still amazes me at the level of debate that people will fire across the bows of car enthusists trying to get a reaction.
Go back to LS1.com and talk about body kits for your V6 VN!!
XW tarmac rally car, 3/4 race cam, NGK spark plugs |
12-01-2007, 01:27 PM | #33 | |||
The Grand Prix
Bright Green XP Coupe 9" 3.55 LSD, C10 and mild 302 Windsor Cruizing the roads 70's style
12-01-2007, 01:27 PM | #34 | |||
Mopar/No Car
12-01-2007, 01:36 PM | #35 | |||
12-01-2007, 01:38 PM | #36 | |||
Also by the way I have Simmons FR18s on my XW Hope your not offended Joke
12-01-2007, 01:40 PM | #37 | ||
I have a inline six in my old Ford D 1211 20ft beaver tail truck. Its 360 CID and produces 115 bhp at 2400 rpm. It lifts its 13 ton gross up hills no worries. Would a Barra engine do this? I think not.
Like its been said, depends on designed application. |
12-01-2007, 01:42 PM | #38 | |||
Mopar/No Car
The Western Suburbs Style Council
12-01-2007, 01:50 PM | #39 | |||
Oops, I slipped....
[edit] - bit more info - http://en.wikipedia.org/wiki/Chrysler_LA_engine
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
12-01-2007, 04:55 PM | #40 | ||
Back to the AU
Rather than just continuing with the slagging match, why don't we look at what makes these engines good and look at ways to improve the Falcon 6 accordingly. In this case, the TVR has a more favourable bore and stroke than the Falcon. For everyone's information, the TVR's bore and stroke are 96 and 92 mm respectively. Source. What would be interesting to know, from someone who's had the head off the falcon motor, is if there's any room left in the block to bore it out.
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU 2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth |
12-01-2007, 05:13 PM | #41 | ||
Bseries Moderator
The Question should be now how do i bolt the tvr head to my ford block ?
Long Live the Rugerspeed Primer Destroyer! Only those that attempt the absurd achieve the impossible. Serviced and maintained by Mascot Auto Repairs
12-01-2007, 05:21 PM | #42 | ||
I was just on the Nizpro Site and Simon seems to get some pretty good numbers and with good reliability for 5 to 20k.
Seems like conrods and oil pump gears are the critical factors. The block and head are well up to the task.
12-01-2007, 05:22 PM | #43 | ||
AU II XR8
havent heard from the maker of this thread yet?
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
12-01-2007, 05:28 PM | #44 | |||
Mopar/No Car
12-01-2007, 05:29 PM | #45 | |||
Nitrous Junkie
'97 Toyota Supra - 6spd, Tilton Triple Plate, Built 2J, T88H-38GK, HKS 272 Cams, Haltech E11V2 |
12-01-2007, 07:57 PM | #46 | |||
thoses cars are built specifically for power and speed not to go to the shops get back to reality spaceman besides a turbo ford 6 are making 450 plus rwkw at a cost of less than 10grand
XD with EL xr8 front 393 12.1 114mph on lpg: Sold
FG F6 Manual 366RWKW tuned by BLUE POWER |
13-01-2007, 01:10 AM | #47 | |||
Spr Jenkins
Secondly I did say the 8.3 litre Viper didn't I, I meant the 8 litre. hence putting together two 4 litres to make an 8 litre. Which was in the first model which did put out 400hp, This had a 7990cc engine putting out 298.3 kw. This was in 1994, it was in 1997 that it was uprated to 450 hp. The BF Falcon has 190kw, but doesn't the BA have 185kw. So while I was wrong in saying latest, you get the idea, and 5 kw isn't going to blow anyone's minds. We have both versions at work and I can't tell the difference. So now that that's out of the way. Moving right along. So yes, there is a valid point in saying that the most common ford straight six will be sold in the family car. Ford however does also do sports cars, Fpv does faster ones. What i'm saying is firstly if you can get that sort of performance out of this size engine, why can't we have a reliable 230 kw NA XR6. Then imagine what you could do with the turbo/ supercharged version. TVR's aren't kit cars, they come factory built with factory warrantys even though they may not have the reliability of a taxi. If a small group of people at a minor sports car maker can do this, why can't Ford with a much bigger budget and much more people do better. Now I know it will cost to buy a TVR engine than a Ford engine but i'm guessing most of that can be explained by build volumes. I'm sure if Ford put their minds to it they could come up with a reliable, cheap, mass produced 230kw na 4 litre. If not they could always do what is happening in the US and sell it aftermarket like the Cammer engine. While the TVR is also a lot more expensive than a XR6, how much do you think an XR6/XR6 Turbo would cost if they were being produced in the same build volumes, I'm not saying it would be as much as a TVR but it wouldn't be cheap. So yeah while the TVR Sagaris is roughly $124,000AUD or $50,000 GBP at current exchange rate , a 6 litre Vauxhall Monaro starts from $92,000 AUD. The same car in Australia was roughly 55 to 60K. I don't believe this is taxes or tarrifs because don't other shared products sell at roughly the same price after conversion? So if this is true and all cars are roughly a third more expensive over there, a TVR here should cost roughly $82,000 if it was made by an Australian company. Last edited by sprjenkins; 13-01-2007 at 01:32 AM. |
13-01-2007, 01:13 AM | #48 | ||
Spr Jenkins
P.S. Another site, thanks to Hot XR6, that says the TVR is 400 hp http://www.conceptcarz.com/vehicle/z7960/default.aspx
13-01-2007, 01:23 AM | #49 | ||
In regards to a 230kw NA XR6 down the track, Holden's 3.6L V6 has gained 30kw with the addition of direct injection, the 2008 Caddy CTS gets this engine, so expect to appear in the next Commodore (VF).
I imagine the Falcon 6 with Direct Injection would gain a similar amount, lets hope the next model Falcon gets it.
13-01-2007, 01:26 AM | #50 | ||
TVR's are the dodgiest peices of crap this side of a gen3.Talk about build quality. I think 190kw in a taxi is something pretty exceptional. If european & japanese cars are so good, why couldn't Germany and Japan win a war?? The same reason you can wax an Enzo or GTR in a falcon with half the money spent. Australia builds the best bang for buck cars on the planet. So go on buddy enjoy your VW Golf or Toyota Prius safe in the knowledge that your getting 7 litres to the 100k.
13-01-2007, 01:35 AM | #51 | |||
Spr Jenkins
In fact you can buy a worked road legal GTR with rego and roadworthy in brisvegas for $17,500 so sorry bud you only got $8750 now to kick my ****, lol. http://www.carpoint.com.au/used-car/...d/2276074.aspx Last edited by sprjenkins; 13-01-2007 at 01:47 AM. |
13-01-2007, 01:45 AM | #52 | ||
We could take it to a 1/4 mile instead and I'll spend half the money as I said which I figure would be around the 50k mark (decent R34 GTR being 100k) and I will wipe the floor with your yellow crap.
13-01-2007, 01:47 AM | #53 | ||
Spr Jenkins
lol as I said in my edit bud, my GTR is only costing me $17,500
13-01-2007, 01:48 AM | #54 | ||
Better yet mate, what car do you drive? Mines all aussie, if you do practice what you preach and have a jap/euro car maybe we can put our money where our mouths are.
13-01-2007, 01:53 AM | #55 | ||
Spr Jenkins
Well I tell you what, if you practice what you preach, than give me twice what your cars worth and your on, i'll even drive all the way from melbourne lol
13-01-2007, 01:56 AM | #56 | |||
13-01-2007, 01:56 AM | #57 | ||
Spr Jenkins
BTW If your cars the one you got in your AVATAR the engine was designed originally in America even if they did make it a 5.4 here. Now I do drive a falcon and i like it alot. The point I was making is that it would be nice if they could extract a bit more power out of the factory straight 6 for the high performance models
13-01-2007, 01:57 AM | #58 | ||
No worries bud, we'll see how eurotrash handles 48 degree heat.
13-01-2007, 01:57 AM | #59 | ||
Spr Jenkins
I was at the last ford forums nationals
13-01-2007, 01:58 AM | #60 | |||
Spr Jenkins
