24-12-2009, 08:48 AM | #61 | |||
Treasure your balls?
Meteorite T3 TS50 ESS |
24-12-2009, 09:55 AM | #62 | ||
First time Falconless
02 AU3 SR bought in Feb 08 with 30,000km on it. Daily driver that has just ticked over at 67,500km. Still feels like new. Was floored when I checked the logbook and found that it took the previous owner 2 years to do nearly 8,000km!!!
Absolutely perfect (touch wood) and apart from a new battery and the usual consumables/fluids etc I have only replaced parts on her for the purposes of modding.
2008 FG G6E Previous:- 2012 Fiesta Metal | 2001 AU2 XR6 | 1994 EF Fairmont | 2010 FG XR50 Ute | 2006 BF Typhoon | 2002 AU3 SR |
24-12-2009, 08:23 PM | #63 | ||
Club Moderator
I bought mine in march this year. 2002 TS50 15800, it now has 19600 on it. No major problems.
24-12-2009, 08:52 PM | #64 | ||
ROCKING THE EL FUTURA
au11futura 2000 161 though on the clock, just today made it from Adelaide to coober pedy 847km's i think on one tank paid 60ish to fill in adelaide.
very very very happy.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
24-12-2009, 11:05 PM | #65 | ||
NEED MORE CASH *** ***S!
AU 1999 forte wagon. Tickford dual fuel.
Ex Premier taxi, 1,240,000 odd clicks. New hose pack, heater tap, (no heater core flow, hose eventually srung a leak from blockage of rust mud that also blocked LPG converter water lines) Reco Steering rack, (main shaft seal went) Series 2 lower arms/spindles/swaybar/SB mounts/BF xr6 slotted rotors/callipers (Kept chewing rotors), New bearings all wheels, (just so i didnt have to do it later, slight noise from rear right) Replaced interior to series 1 xr6 seats/ four door power windows/carpet/cargo carpet/dash. (grey inyl and manual window didnt do it for me and got the loat minus motors/regs for $50 in prime condition) Needs a new engine, sump gasket leaking, and bottom end making a knocking noise on low revs, but it still goes good. Have put 40,000 on it in 18 months. |
24-12-2009, 11:25 PM | #66 | ||
AFF Whore
Just hit 170xxx in my AU 1998 fairmont ghia,
vct motor still hauls like buggery, however drinks like a fish. Had it just under a year, when I got it the odometer was sitting on 152xxx k's Replaced rear hub and axle and abs module, apart from that just regular service stuff. |
25-12-2009, 02:14 AM | #67 | ||
[ 5L ]
brought mine 3 years ago, with 86,000km's on the clock. now at 171,000 daily driver/weekend cruiser.
broken engine mount bolts, one gearbox, diff is clunky, feels abit loose with hard gear changes, replaced the suspension at around 130,000. end of the day it gets driven it is what it was meant for and has given me alot of good times over the years. and i expect another few good years out of it. and i would still jump in it now and drive it anywhere as it is.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
25-12-2009, 03:02 AM | #68 | |||
eer ah I mean 285000K, havent looked at the odo in a while and thought Id check it after I posted this the other day. Mine has a slight bottom end rattle at idle,but until it lets go in a big way i wont be touching it,and may replace it with a 220kw 5 ltr,leaving it on gas,and my roof linnings caving in in the rear cargo area,so that will be replaced. Id have to say this is the best most reliable car ive had and Ive had over 30 cars now,better than the wifes territory as well
T2 TE50 no:154 Narooma blue AU2 XR8 ute XR4 fiesta |
25-12-2009, 10:33 AM | #69 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
26-12-2009, 04:20 PM | #70 | ||
Audi S3
got mine in August 05 with 92 000 on it.
just ticked over 200 000 the other day. and everything rattles. at least with the sub cranked. :
26-12-2009, 05:12 PM | #71 | |||
Flairs - Truckers Delight
26-12-2009, 05:15 PM | #72 | |||
i think i gotta turn the volume dow. lol
26-12-2009, 05:55 PM | #73 | ||
WAGONE
series 2 wagon old motor had 210 on it, new motor has 96.
Did the front main seal on the old motor i think thats cos it sat in water for a couple of days tho. Knocking noise in the front poss ball joint ect, and power steer rack also has a pop/ clunk sound when turning the wheel when stopped in some position. apart from that just the usual service and maintanence items
Car Builds: EF Turbo Track Hack AU II XR6 sedan AU XR Sportsman Wagon AU Falcon.com page |
26-12-2009, 07:43 PM | #74 | |||
I haven't cracked 51,000 yet.
AU2 XR6 VCT...
Powered by Vortech : T1 TE50 #094 : |
27-12-2009, 03:17 PM | #75 | ||
In a Ford..at last!
Series II Fairmont
purchased with 142,000kms, now with 164,000kms roughly. Replaced; radiator, 4 tyres, handbrake shoe needed to be replaced and front brake pads. So far going pretty good |
29-12-2009, 05:11 PM | #76 | |||
The Beast: '05 E60 BMW M5 - 5L V10 Goodness! Daily/Project: '92 EBII Fairmont 5L Build Old Rides: '01 AUII XR6 '97 EL GLi '90 EA S-Pack |
29-12-2009, 05:36 PM | #77 | |||
29-12-2009, 10:36 PM | #78 | ||
Wow. Respect. Can we have some engine bay pics?
30-12-2009, 09:22 AM | #79 | ||
bought at 190,000 2 years ago, now on 243,000. few rattles etc. but still starts first go and has been very trouble free.
30-12-2009, 12:08 PM | #80 | ||
Me AU's cheap and clean.
bought mine with 100,011 3 years ago now sitting on 147,000. Only changed the steering rack, shocks and the odd bits and pieces here and there.
THE MIGHTY MANLY WARRINGAH SEA EAGLES Daily - 2013 SR5 Hilux Toy - 2000 AUII Falcon Toy - 2010 Kawasaki ZX10-R Her's - 2017 Camry SX |
30-12-2009, 01:11 PM | #81 | ||
XA GT
I have a series 1 XR6, bought it 6 years ago with 88,000km and now has 156,000km. At 88,000km I had the bonnet and bumper painted because of stone chips and replaced the exhaust, no other problems.
I also have a series 3 wagon, bought it a year and a half ago with 192,000km, now has 206,000km but currently needs front hub bearings.
--------------------------------------------------- XA GT, 6.848sec 1/8 mile @ 101.68mph |
30-12-2009, 01:15 PM | #82 | |||
Back to Le Frenchy
Bought mine in Sept 06 with 78k on it. It now has 150 odd with none at all since June :
30-12-2009, 01:40 PM | #83 | ||
best mates AU ex cab has 690,000ks and still going
shoulda been burned 689,999ks ago its straight gas wether that makes a difference |
30-12-2009, 08:10 PM | #84 | ||
When I bought my 99 Wagon in feb 04 it had 90000 and now 230000 it needs a good service and transmission leak fixed |
30-12-2009, 08:27 PM | #85 | ||
99 ex cab victorian 859000. we will make a 1000000.still going strong
31-12-2009, 01:26 AM | #86 | ||
460hp + manual = fun
02 au3 xr8 ute. bought it at 115k now at 117k. and the 6 stack has died lol. thats bout it so far.
BA XR6 turbo, blood orange, 6 speed , mal wood option 3+ clutch, fg gt style 19's , xr8 bonnet, no spoiler , de-badged , sunroof , leather , premo, fpv wheel, plazmaman 1100hp cooler, plazmaman hot + cold side piping and intake, x force exhaust, 460 rwhp and more.... |
31-12-2009, 11:01 AM | #87 | ||
Had it from new, done 225,000 no major issues, no leaks no knocking no problems - paintowrk looks like crap which is why it is now garaged and about to be pulled apart for a facelift.
Thinking of fitting turbo and sports exhaust and looking for advice on which ones to fit. I really love this car............... |
31-12-2009, 03:10 PM | #88 | |||
as i need to get mine done too |
02-01-2010, 06:05 PM | #89 | ||
Smile
310000 kms
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
02-01-2010, 09:03 PM | #90 | |||
Just slidin'
$16.99. Used a hoist, 4 bolts to undo tailshaft, slips out, bit of a stuff around getting out the seal, slip the new one in, tappa tappa tappa, slide the tailshaft in, do it up, top up fluid and your done.
MD Mondeo - For the family
