30-12-2010, 06:57 PM | #61 | |||
mate thats all been thought of, most systems dont activate if thats the case, and its been in production for over 10 years now with no worries... give it a few years and it'll be the norm on most cars remember these cars are designed to be stop start, its not like your shutting it off and re startring a normal car every time.... the engines are designed with this in mind and fire instantly, belt driven starters can crank all day long and not burn out, alternators that are much more powerful and larger capacity batteries than the 2xAAs in your current car... just interested to see how its done on a turbo car, that said like i mentioned the system isnt always in operation unless the car thinks its right, so if you have been flogging it or the engine is too cold etc... it wont shut off |
30-12-2010, 07:05 PM | #62 | |||
It's not as though the motor companies went out and just put a kill switch on an unchanged car. most of these stop/start vehicles re start the engine when battery is below a certain level or when you touch throttle/ release foot brake. |
30-12-2010, 08:50 PM | #63 | |||
Bring on EPAS, StopStart, electric water pump and between them there might be 15-20% fuel saving. BMW have smart regenerative alternator charging which charges ad required or to add engine braking downhills. That saves a few percent too. Add all this and mid 7s economy is achievable from our Barra 6.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
31-12-2010, 12:08 AM | #64 | ||
let it burn
I havent read much on it, but how much is to do with the US eco laws and the requirement to meet an average of ?? mpg across the manufacturers range? If the US has to invest to meet requirements there, you can bet they will be trying to recoup it here if possible.
31-12-2010, 01:20 AM | #65 | |||
Every time you switch off the engine on the city/urban stops, about 16-17 times, it saves about 5-10% of the fuel and manufacturers get better fuel economy numbers. The same would be true if you're stuck in stop/go peak hour traffic to and from work. |
31-12-2010, 02:48 PM | #67 | |||
Regulator
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
31-12-2010, 05:44 PM | #68 | ||||||
But lets look at the tech individually. * Stop start tech wont kick in under cold start conditions. It is one of the parameters. But once warm, will provide significant stop-start benefits. * The electric steering would still help. * The electric water pump which can greatly reduce warmup time and therefore fueling requirements and lower parasitic drag. * Automatic / smart regenerative recharging would still be applicable. Quote:
31-12-2010, 08:02 PM | #69 | ||
Isnt the boot floor on the VE sedan plastic/composit to account for a range of spare wheel options?
02-01-2011, 03:41 PM | #70 | |||
Peter Car
They are not saying it is definate, just potentially available if they want to use it. I don't think it will be available initially in Falcon, maybe down the track it may be. |
03-01-2011, 10:02 PM | #71 | |||
Oo\===/oO
This is interesting, ford just need to advertise it, get public awareness out there! The falcon isn't dying, its getting smarter, greener, safer.
07-01-2011, 12:26 PM | #72 | |||
IWCMOGTVM Club Supporter
http://www.caradvice.com.au/97145/no...ord-australia/
Daniel |
07-01-2011, 01:52 PM | #73 | ||
Peter Car
Why did he write that stop/start requires direct injection, and Ford don't have that, when he wrote earlier that the Ecoboost 4 is direct injection and going into the Falcon?
Seems like a contradiction. Ford would be flat out getting the Falcon engineered for Ecoboost, stop/start will probabaly come later down the track it seems. |
08-01-2011, 03:39 AM | #74 | ||
Compulsive Hobbiest
The caradvice article is full of contradictions and some ignorance. More on that later.
I am surprised it took until post #66 for someone to reference a Ford news release about the technology. Here is a very important part from that release... Ford's global Auto Start-Stop technology is smooth, quiet and seamless, and it requires no changes to the driver's behavior. In city driving when the vehicle is stopped, the engine restarts the instant the driver's foot leaves the brake pedal. When the engine is off, all of the vehicle's accessories function normally. "For the driver, Ford Auto Start-Stop provides extra fuel efficiency without inconvenience, as it works completely automatically," said Barb Samardzich, Ford vice president of Powertrain engineering. "And, just like in our hybrid vehicles, the heater, and air conditioner work as normal so drivers will not sacrifice comfort." Do you think Ford will sell you a vehicle where the AC will cut out on you in stopped traffic on a sweltering day? Lose heat in the winter? I have been following this at Ford as my knee-jerk reaction is to reject it. As I read more into it (Ford internal publications) I have warmed up to it. It's nothing like you would expect. The reason you need a direct injected engine for this is because of the technique for restarting the engine. First let me make clear, the engine starts when you release the brake, not when you step on the accelerator. When the engine comes to a stop in this mode it stops with a cylinder on the compression stroke near TDC. When you release the brake the injector shoots fuel into that cylinder so that when the spark plug is fired the engine starts immediately. Your starter will not be cranking like you are used to. Have you seen the top of an EcoBoost engine piston? It has a pocket in it with a channel going to the side of the piston. This channel is for the fuel injector to shoot fuel into at specific times. When the engine is cold the injector only shoots in 1/2 of the amount of fuel needed to run the engine on the intake stroke. This fuel is spread through out the cylinder. On the compression stroke the rest of the fuel charge is shot into the cylinder when the piston nears TDC, but through that channel in the piston to the pocket in the center. That pocket is centered with the sparkplug and now has a "rich" fuel mixture around the tip of the sparkplug for "cold starting." THAT is how high tech this engine is. This way no "additional fuel" is required for cold operation. With Start-Stop the piston is near TDC and fuel is shot into that channel to the pocket in the center for a near-instantaneous starting of the engine. Ford has been praised by many automotive magazines for their hybrid's ability to kick in the engine almost imperceptively with this technology. It has been stated many times that Ford does this better than anyone else. I don't know if the electric pump to circulate coolant while stopped only runs while the engine is off. I would expect so to ensure longevity of the motor for the pump but I have not read anything about that either way. Back to the caradvice article: I don't know if Ford officially has plans for this in the Falcon but I cannot see why not. The EcoBoost I-4 will have it and the Falcon will get this engine, so why not? The article states the engine is restarted when the driver re-engages the accelerator. That is incorrect. Ford states in their press releases (if a journalist reads them) that the engine is restarted when the brake pedal is released. "Another reason why Ford cannot add Auto Start-Stop to its local line-up is that, in order to achieve acceptably fast re-starts in traffic, the system requires direct-injection engines – which are currently few and far between in Australia." Funny, he was talking about the EcoBoost version of the Falcon only, which is a direct injected engine that is coming to the Falcon. Now he's complaining that there aren't too many direct injected engines. Ok, well, wait until they are supposed to be there! Ford said "It's coming!" He makes it sound like there will be no direct injected engines in Australia. He might as well say "I don't think they are going to build a 5.0L Falcon because there aren't many 5.0L engines in Austraila." The reporter also states that the stop-start technology "... will be added to the Fusion Hybrid, Escape Hybrid and Lincoln MKZ Hybrid in North America this year." Then in the next sentence states "More than 170,000 Ford hybrid vehicles have already been fitted with a similar system in North America since 2004." Well, he obviously does not know, and did not look into, the fact that the very cars he mentioned ARE the cars that already have that technology. This guy has his head up his ***. Steve
My Filmmaking Career Website Latest Project: Musclin' My XB Interceptor project Wife's 1966 Mustang My Artworks and Creative Projects Site Oil Paintings, Airbrushing, Metal Sculpture, Custom Cars, Replica Movie Props, Videos, and more! |
08-01-2011, 08:33 AM | #75 | ||
SiX_iN_a_RoW
Thanks for clearing a few things up Ohio XB. Do you have any further info on how the A/C system functions with this technology? Surely they must use an electric compressor similar to the prius?
Oh yeah, my G6ET eats diff bushes for breakfast! |
08-01-2011, 03:27 PM | #76 | |||
Having these items driven electrically frees up underbonnet room by not requiring to be driven off the crank, reduces fuel consumption as the systems kick in when required, their control systems are often superior too. I like big powerful cars, but added economy is great and narrows the ownership cost down towards smaller cars.
08-01-2011, 03:53 PM | #77 | |||
Walking with God
GK
08-01-2011, 04:25 PM | #78 | |||
SiX_iN_a_RoW
Yeah I totally agree. I have been saying they should run electric compressors, power steering pumps etc ever since our fuel prices shot up and everyone became so worried about fuel economy. It makes perfect sense and has been used on quite a few cars already.
09-01-2011, 12:21 AM | #79 | ||
Hang on a second... Is no one worried about the smaller car factor? I just purchased my first falcon for the very reason it's a big car. I've had 2.0 Litre subaru's, I've had numerous toyota's. A galant! I love my big falcon. If people want a small fuel efficient car get a small fuel efficient car. Id love to pay less on fuel, stop start technology sounds like the best idea since efi if you ask me. But a smaller 2.0l 4 cylinder falcon? It's Mondeo with falcon styling? Grrr maybe it's just I'm young and naive but what is falcon all about? It's the family muscle car right? Ah my opinion anyway.
AUII XR6, AT 22 YEARS OLD, IN NZ. Last edited by Xr6couple; 09-01-2011 at 12:30 AM. |
09-01-2011, 05:10 PM | #80 | |||
Oo\===/oO
The falcon about broad appeal, its going to have a Economic, put powerfull 4cly for one group of people... ...Its going to have its 6 for another... ...then the V8 for the other group of people. When people go to look for a new car, they will; see 2L, 4cyl, and give them an option besides a Camary or cruze.
09-01-2011, 05:54 PM | #81 | ||
i can imagine driving one of these, with the stress included, and then one day lift the foot off the pedal, and it doesnt restart. i hope they do millions of kms of testing this, and seeing how many times it works until it fails. also if they includ this in cars, i hope it is also only optional, and that you can bypass it.
09-01-2011, 06:04 PM | #82 | |||
Oo\===/oO
Car companies don't test new technologies, they just say it will work and sell it.
09-01-2011, 08:06 PM | #83 | |||
Whether it's tested thoroughly enough to replicate real world conditions may be a whole 'nother story, however.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
10-01-2011, 01:54 AM | #84 | |||
Getting it done.....
As for the article its a shame because car advice is one of the better sources in aus. Haven't heard of that bloke before....sounds like a new hire who should have been a no hire.... Contradictory and a misrepresentation of what the ford aus spokesman actually said. Unlike Holden (GM) Ford doesn't claim a bunch of stuff will happen and then not deliver....they give hints and make concrete statements only when when they know it will actually go in the car. I'd be shocked if Ford Aus cars didn't get stop start and other tech over time...it might be delayed up to a couple of years but One Ford means that there is very little reason not to put new tech in a car if its all being shared. Once EB I4 goes in falcon then that makes 2 out of 3 engines fitted in FG that are US sources/designed so go figure.....
Dynamic White 1995 EF XR6 Auto Now with: Pacemaker 4499s Lukey Catback Exhaust Chrome BA XR-style tip Airdam Mounted CAI with modified (bellmouth) airbox Trip Computer install KYB shocks Bridgestone Adrenalin tyres Coming Soon: Exhaust Overhaul..... |
10-01-2011, 07:46 AM | #85 | |||
Oo\===/oO
GFRP Boot floor and Composite Radiator support...
10-01-2011, 08:23 AM | #86 | |||
Compulsive Hobbiest
I don't have any more info on this and that is something I am curious about. I will post it here if I find/read anything. Steve
10-01-2011, 08:49 AM | #87 | ||
Compulsive Hobbiest
Thanks everyone.
Fors has testing facilities in the desert of Arizona and in Alaska to test technology in the extremes of temperature. There has been a start-stop technology on 170,000 cars Ford has sold since 2004 and I have not heard complaint about it. Ford id really big on testing their stuff now, not to say about decades past because I do not know. I do know that their stuff if tested like crazy now. Ford has the most hybrid vehicles available in the US and also offers the most cars that get over 40 MPG in the US. Steve
10-01-2011, 09:03 AM | #88 | ||
Does the start/stop work with manuals too? it says above that the engine restarts when the brake pedal is released. I also assume it is switchable or the or a good oldfashion burnout may be endangered!
10-01-2011, 05:56 PM | #89 | |||
Oo\===/oO
My post should have ended with "/Sarcasm"... ...
10-01-2011, 09:00 PM | #90 | |||
