02-11-2005, 11:05 PM | #61 | ||
locker king
i ran mine tonight and even when i had my last run at 9:50pm it was still 25 degree's with 80% humidity accorcing to the time slip....
couldnt even get near my PB, best was a 15.125, although my mph was 1 better, but did manage to get in 9 runs even though i didnt get there till 6.30pm.
EBII family wagon, 14.966 @ 90.86, 4lt 5-speed. "WAGON MODS getting you to woolworths quicker!!!" |
03-11-2005, 12:46 AM | #62 | |||
03-11-2005, 04:30 PM | #63 | ||
Smile
Ive been keeping an eye on air temperature here and when I get to run by 10 am the air temp based on the past few days will be around 30-34 degrees...
I actually took my car flat past 2nd to third for the first time today and it went to 6200 rpm and changed gear nicely.So I have a feeling AU 1 02 /99 may be a bit different. My car is pulling well to 6000rpm with no power drop off noticed whatsoever.If it did I would install a grey speedo cog...the next one down.But as I mentioned it wants to keep going.Perhaps Ill upgrade the springs in future so that I can rev it higher.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again Last edited by Stav; 03-11-2005 at 04:36 PM. |
03-11-2005, 08:46 PM | #64 | ||
TL40 Wagon?
useless i don't believe your tacho. I will bet its reading high.
you should get it checked who cares the black gear is good and it goes harder thats the point. Stick it in first and rev slowly till you hit the rev limiter. now if your tachos not reading 5750 or thereabouts its wrong. the limit is hard coded in all the ecus 5800-5900 or thereabouts. not 6200 |
03-11-2005, 08:57 PM | #65 | ||
TL40 Wagon?
Just tested my speed limiter it still works!
The poor car is so modded it doesn't really know where it is but it in third it goes to 5600 rpm and then changes into fourth and stops. My speedo says 197kmh but its reading high of course. Only doing 180 or thereabouts. either way not a big deal for a stret car that runs 145k on the strip anyway |
03-11-2005, 09:31 PM | #66 | |||
Boss for Go, L98 for Show
Quote: Jeremy Clarkson "The fact of the matter is this, from just about any angle this is an impossibly pretty car" |
03-11-2005, 09:46 PM | #67 | ||
Smile
In first gear ..holding it it goes to 6100 rpm and hits the rev limiter.In auto mode I fang it ..it goes to 6000 rpm then changes gear...goes to 6200 rpm then changes gear again. I know your cars hit the limiter at the earlier speeds but mine does not.The AU 2 is quoted from factory to be a slower car than the au1.I believe that this and combined with a different speed gear to the au2 wagons indicates that the au 1 was definatley setup differently to au2.Even the coilpacks were different..
http://www.geocities.com/falconfacts...uiifalcon.html http://www.geocities.com/falconfacts.../aufalcon.html au2 vs au1.The au1 was quoted as being quicker.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again Last edited by Stav; 03-11-2005 at 10:32 PM. |
04-11-2005, 01:47 PM | #68 | ||
I have an AU1 Stav.. hard cutout on the revs is 5750... full stop. It was the same for ALL AU's. Either you have a weird ECU or your tacho is way out.
04-11-2005, 07:53 PM | #69 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
04-11-2005, 08:26 PM | #70 | ||
i was just checking that site out useless has posted and is this a typo or what.
Engines: 4.0L Intech 6 cyl Bore and stroke: 92 x 99 mm Power: 157kW at 4900rpm Torque: 357Nm at 3000rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.6:1 4.0L Intech 6 cyl (XR6) Bore and stroke: 93 x 99 mm Power: 164kW at 5000rpm Torque: 366Nm at 3150rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.6:1 4.0L Intech VCT 6 cyl (Fairmont Ghia) Bore and stroke: 92 x 99 mm Power: 168kW at 5000rpm Torque: 370Nm at 3500rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.6:1 4.0L Intech VCT 6 cyl (XR6 VCT) Bore and stroke: 93 x 99 mm Power: 172kW at 5000rpm Torque: 374Nm at 3500rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.6:1 according to this the xr's had a 1mm bigger bore . so whats the go is this true? |
05-11-2005, 08:04 AM | #71 | ||
Its a typo. Has to be. Given the Fairmont Ghia VCT and the XR6 VCT are IDENTICAL then there is no way there can be a bore difference.
