Old 09-01-2006, 09:03 AM   #61
spope
spope's Avatar
You are using the BBM, yes? If so, have you been able to configure the mega squirt to switch to short runners at 3800 rpm, and it takes the fuel maps (and timing) into account? Or are you still letting the standard ECU do the switch?
Also, how exactly have you wired it up? Intercepting all the sensors from the ecu, and then completely bypassing the ecu outputs direct to the coil and injectors?
I am extremely keen on this now, after seeing your results! The electronics seem fairly straightforward (for such a complex piece of equipment) and seems easy enough to tune.
I'd like to see some 1/4 mile times when you next have a chance to run!
spope is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 09:46 AM   #62
FPV_GTp
FPV_GTp's Avatar
hi
stockstardard vey nice work
one of the best threads i have seen in here
keep up the good work
cheers
Weapon of Choice - EA falcon sedan Twin Turbo V8 351C Bottle feed C10 auto 9 inch diff
ForSale- Heenan&Froude G490EH Engine Dyno
FPV_GTp is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 11:07 AM   #63
ALS008
I'm BOSS
ALS008's Avatar
Location: Where all Fast Fords are From, Northern Melb.
Isnt the o2 sensor out of a BA a wideband unit.
====Past Rides====
'04 BA XR6T 5spd T5: Nizpro Tuned, Valve springs, CIA, Injectors, 256RWKW
'04 BA XR8 4spd BTR:Bluepower Tuned, BPR CAI, Big Boy exhaust, Hi Stall, 4.11s, 248RWKW PB:13.2@105mph
'92 EB Fairmont GHIA 5.0LT 5spd T5:Stock with a cat back exhaust.
'06 BF Fairlane GHIA 230Boss ZF 6spd: BPR CIA, cat back Exhaust.
====Present Ride====
'10 FPV GS Ute ZF 6spd:#108. With all the fruit.
ALS008 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 12:06 PM   #64
ALS008
I'm BOSS
ALS008's Avatar
Just done a bit of research on this unit and it seems to be quite alright for a simple unit. The only thing is i have noticed the VE table is only an 8x8 map which seems a bit restricted in the tunability of the ecu, processor speed abit slow also - 8mhz. Have you been able to get a faily smooth idle and cruise map done yet??
A good thing tho is the auto tune function - this must have made it a bit easier to build a map. To my understanding is it as simple as stating the AFR you like and then just go and drive the car until the ecu/wideband work it out for you. Do you have a screenshot of the autotune function??
====Past Rides====
Old 09-01-2006, 01:09 PM   #65
Matt_971
Regular Bum
ALS008 I think you'll find the Megasquirt 2 has tuning tables of 12x12 and the processor is a 24mhz speed.
check out this.
http://www.megasquirt.info/ms2/
http://www.megasquirt.info/v22manual/mintro.htm
They should clear some things up for you.
The difference between the Megasquirt 1 and 2 are those differences and the MS1 only dones fuel. Plus different features etc etc.
Matt
Matt_971 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 01:18 PM   #66
stockstandard
Yep, using BBM. At the moment the switching is still done by the EEC, and for now I dont see any advantage in changing it over to MS2. It is trivial to do though, same as hooking up the shift light. I also havent done any specific tunes for the short and long runners. It might be becuase im not pushing the limits of timing yet but so far I havent had the need to. AFR's dont cange and there is no pinging.
No. It can be wired up that way but I dont like cutting wires so this install is done completely seperate from the ECU. The O2 sensor signal was split with a Y cable I made. I fitted a new air temp sensor in the airbox, changed to ED lower thermostat housing and used a second temperature sensor, and used an EA twin TPS for throttle position. Then unplugged the fuel injectors and coil pack from the EEC and plugged in the MS2 stuff.
So far I havent cut a single wire that ford put there and it is a 10m job to switch between MS2 and EEC.
I probably wont be taking it to the drags until the new diff is in so its not going to be a fair comparison. I will post some g-tech and dyno results soon though.
Originally Posted by FPV_GTp
hi
cheers
Thanks mate.
Not sure, but the sensor is the cheap part. Its the controller that costs most of the $, and in factory cars the ECU will be doing that job.
They look like the specifications for the old megasquirt. The MS2 is now has 24Mhz cpu and has 12x12 tuning tables (and apparently can support much larger tables in future firmware updates).
Thats it in theory. I found the real time autotuning only helpful in working out cruise points. It seems to (wisely) wait for the imput signals to stabalise before it makes changes to the tune, which means its not suitable for WOT tuning. There is an offline autotune that you feed your datalogs into and it tells you what the VE table should be. I didnt play around with it but that might be better.
I found that using auto tune to refine the idle and cruise areas of the map, then tuning the rest by hand to be faster and safer.
as for screenshots: you cans see the autotune checkbox at the bottom of this window. Thats it, just tick the box and go driving
Originally Posted by casper
Old 09-01-2006, 01:46 PM   #67
ALS008
I'm BOSS
ALS008's Avatar
Cool - sounds pretty good. And well done on an extreamly detailed post. Keep the updated coming.....
====Past Rides====
Old 09-01-2006, 02:43 PM   #68
old_mate
Smash the Boost
old_mate's Avatar
awesome.
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 07:41 PM   #69
stockstandard
Today I got the ford IAC working. I used an ED IAC as they have wires comming off so are easier to work with. Wiring it up was simple, red wire to 12V, other wire to MS2 F-Idle, and a 1N4001 diode between the two. I closed the throttle stop so the IAC was in complete control. With the duty cycle at 100% the engine stalls, and at 0% it revs at about 2100rpm. Set to about 60 to 70 makes it idle in the 600-800 range. No more putting up with crappy cold starts for me
So I can now confirm that the IAC on the Ford I6's work with the MS2 as well.
Old 11-01-2006, 07:44 PM   #70
hornet
hornet's Avatar
Is an IAC the same as an ISC?
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 07:53 PM   #71
stockstandard
Yep. Same thing, different names.
Old 12-01-2006, 11:11 AM   #72
ALS008
I'm BOSS
ALS008's Avatar
What do the above stand for??
====Past Rides====
Old 12-01-2006, 12:41 PM   #73
stockstandard
Idle air controller/idle speed controller
and my ford book also calls it an ISC-BPA (idle speed control - bypass air valve).
Old 22-01-2006, 01:36 PM   #74
chich
chich's Avatar
Well done mate.. keep up the good work. That thing sounds fantastic and the way it picks up revs is unbelievable!! Sounds prettty smooth through the rev range too.. my EF sounds like a bloody tractor at 4500!
chich is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 04:38 AM   #75
stockstandard
Thanks mate.
Ive just seen a really cool addition posted on the MS2 forums. This little board converts the EEC4 plug to MS2, meaning you can potentially replace an EEC from EA-ED and EL without any wiring changes at all. The idea is you just unplug the EEC and plug in the MS2 and it all works!
The second plug on the board is there to pass the signals needed to control automatic gearboxes to a new GPIO expansion card for the MS2 currently under development. This would give us the ability to not only retune out engines but also custom tune automatic gearboxes.
Old 25-01-2006, 06:35 AM   #76
yo_stock
What about the guages and so forth? Will the MS2 run these without serious tunning?
yo_stock is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 11:49 AM   #77
EFFalcon
Last warning
EFFalcon's Avatar
holy crap, thats an awesome change.
who developed tha?
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 25-01-2006, 12:48 PM   #78
Voxace
Now with T5
Voxace's Avatar
Jaw hits ground. :sm_drool:
Will someone be making/supplying these?
Voxace is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 01:09 PM   #79
stockstandard
It looks like these boards are in final testing and should be available soon.
I dont know how close to plug n play they will be on our ecus. If someone from the club wanted to contact the maker he might send a couple down for testing on australian EEC's. I would try it but these are no good to me, EF's have a different ECU plug :(
Old 25-01-2006, 03:08 PM   #80
Matt_971
Regular Bum
I might get in contact with Scott n see what he says hey Mark.
Sounds VERY interesting.
I just need some more money lol.
Also with this new development might get some more interest in the group buy.
But this time maybe someone could give me a hand at organising and CHASING ppl.
Matt
Old 28-01-2006, 12:36 AM   #81
triple8nitro
Alternator
Talking ms2
I have been reading nothing but megasquirt forums for the last 3 days and it looks very promising , got to pay my bills so i can spend some money although matt have you had any interest in group buy yet : ?
Special Vehicles for special people. ing_sm
triple8nitro is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 01:38 AM   #82
XRated
Shoot.
XRated's Avatar
The plug and play sounds interesting!! I wouldn't attempt a DIY job, but you know your stuff.
20V Turbo
Old 28-01-2006, 08:37 AM   #83
Matt_971
Regular Bum
Hey mate
Nah have gone off the idea of group buy. To much hassle. And we only get 10 dollars off the actual MS2 unit. And I found the TechEdge WBo2 DIY Kits (that are pretty advanced I hear) to be cheaper than the one in the US.
So yeah.
Matt
