Old 13-03-2007, 11:25 PM   #61
snypereb
[EBGLT]
snypereb's Avatar
Yeah went very nice I want mine to feel like yours.
[EBGLT]
Old 14-03-2007, 01:59 AM   #62
mark_TD
XR6 Turbo FTW
mark_TD's Avatar
Originally Posted by snypereb
Cant believe your cars didnt come with them?
Mine did but the rubber was worn and it made the stick slopping and hard to get gears
02 BA XR6 T U R B O - 232rwkw @ 6psi
Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit
96 EL XR6 - (Daily)
Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors
mark_TD is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 03:19 AM   #63
Rmyers
Does Steve have a car?
Rmyers's Avatar
Originally Posted by bomber
Your left leg is going to be the same size as the hulks soon with that damn clutch. I dont think that clutch is brass button its just a normal clutch as it has some slip in it but the clamp load must be dam high. Goes a lot better than the auto. What did ya think about the AU when ya took her for a spin???
It is a brass button, well technically it's a cusion button as it has the same clamping surface as a brass, only difference is that it has a flexi layer running through the middle of the plate to give it a little slip. Clamping pressure is meant to be rated to about 500hp if i remember correctly....
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 08:10 AM   #64
bomber
bomber's Avatar
ahhk do you remember what the clamp load was in Kg's. Im a little worried that clutch might start doing some damage to the rised section in the firewall where the cable enters as it is so heavy and also the entry point is a lot thinner around the walls than that in the AU
bomber is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 09:35 AM   #65
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
The clutch shouldn't be heavy. The extreme clutches are renound for being light.
You sure the rest of the setup is spot in? cable isn't stuff? Thrust bearing new?
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 09:49 AM   #66
Steady ED
Steady ED's Avatar
It looks to be an exedy, no at an extreme.
Steady ED is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 10:29 AM   #67
LTDHO
The one and only
LTDHO's Avatar
Not sure how heavy it is myself as I haven't used it.
Both the cable and bearing are second hand. I didn't check the cable but the bearing is fine.
It's an exedy but not sure of the spec, Rmyerz should know, he bought this new.
Tuned by CVE Performance
Old 14-03-2007, 11:47 AM   #68
Christiaan
Christiaan's Avatar
Yeah it is an excedy. I know they are heavy.
Oh well.
Old 14-03-2007, 11:49 AM   #69
EDXR6T
Its a button clutch, get over it shaun!
If you want il swap you my PBR;)
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 12:12 PM   #70
bomber
bomber's Avatar
Ha ha I wouldnt even want a clutch that heavy stuff driving it in traffic. Button clutches are usually light as a feather so not sure what makes this one so bad.
Old 14-03-2007, 08:19 PM   #71
bentles
bentles's Avatar
speaking of reflections... after inspecting myself in the mirror, peeling on the neck, forehead, ear, and cheek
hooray for ukrainian blood!!
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 08:21 PM   #72
snypereb
[EBGLT]
snypereb's Avatar
That slight adjustment last night bomber has made heaps of difference it feels alot better driving home and on the way to work today.
lol bentles you got so burnt.
[EBGLT]
Old 14-03-2007, 08:23 PM   #73
EDXR6T
I love being black. :
So whats the secret then??
Old 14-03-2007, 08:25 PM   #74
bentles
bentles's Avatar
neck was the worst cos the day before i was at carcity for like 4 hours too lol
Old 14-03-2007, 08:56 PM   #75
snypereb
[EBGLT]
snypereb's Avatar
Just another clutch adjustment.
[EBGLT]
Old 15-03-2007, 09:01 AM   #76
Sundeep
Sundeep's Avatar
Shaun you stooged me bro I thought you were cool. I went to all that efford of getting a fuel pump out of a mangled *** rear end of a car and you didn't get back to me!!!! :(
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
