Old 04-10-2007, 10:21 PM   #91
redranga
Does anyone disagree with the answer that they give for question 41?
Given that force = pressure X area
wouldnt the pressure be one seventh of the 50psi applied?
They have multiplied it by seven when it shouldve been divided.
I think the correct answer would be 7.14 psi
redranga is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2007, 10:50 PM   #92
fmc351
let it burn
If thats the question I think it was,
Did you read it as spreading the force from the small area to the larger area, because it was the other way round.
Old 04-10-2007, 10:56 PM   #93
redranga
The 50 psi of force was applied to the larger area and it wanted to know what if was at the smaller area.
Its the same as the brakes on your car. You master cylinder will be about 3/4 of an inch and the piston in the caliper is about 2 inches. This multiplies the force. Im sure theyve got it all eyed.
Old 05-10-2007, 08:16 AM   #94
xbgs351
Originally Posted by BadMac
100% agree with you.
Q26 As I stated before
Q31 is 1/5 of 300KG = 60 (not an option), weight is centred 1 segment to the left and other is centred 5 to the right. If both were at the end of their respective sides 50KG would be correct.
Q38, I had to think about it when I did it for the same reason. Had to think about what answer they would want as you can't prove them wrong.
Q48 pedantic and I can show a few definitions which would assert this is wrong (I can also show some which say its right), so badily worded question. 2 equally right answers.
Q41 is also wrong. The applied force should be in pounds not pounds per square inch as psi is a measure of pressure.
Q19 Should ask what the mechanical advantage is or what the force would be neglecting friction, as there is a lot of friction in a block and tackle.
xbgs351 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 08:24 AM   #95
xbgs351
Originally Posted by Van D
What was the answer to that? I didn't check it. I guessed A as the pressure build up from the pipe getting smaller/narrower wouldn't allow enough flow and it'd need to escape somewhere. First thought was B because the pipe was narrower and thought there'd be more pressure/speed.. But went with A... Wow i'm tired that probably didn't make sense.
The pressure drops when the pipe constricts, just like a venturi in a carby.
http://en.wikipedia.org/wiki/Venturi_effect which is derived from:http://en.wikipedia.org/wiki/Bernoulli%27s_principle which is basically just a conservation of energy equation. So basically as water passes through the venturi it has an increased velocity and the amount of energy is kept constant by a pressure drop.
Old 05-10-2007, 01:23 PM   #96
Homer1
Homer1's Avatar
No, a smaller surface area will exert more pressure with the same force. The simplest way to explain that would be sharp blade vs a blunt blade...which is easier to cut with using equal force with your hand?
Homer1 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 02:07 PM   #97
FrogInASock
Getahaircutandgetarealjob
94%. Associate Diplomas in Engineering rock. What did I get wrong?
Q28 Parallel batteries, typo!
Q38 Two fans facing each other, yair, I got it wrong.
Q39 Mechanical principle used in brakes. It's friction, stoopid!
So without the typo, would have been 96%.
Te pilos recidene volo et opus solidus capere :
FrogInASock is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 06:59 PM   #98
redranga
I went back through the test and can agree that Q41 is right.
Ill have to disagree with on your example also Homer. A knife doesnt use hydraulic multiplication to cut. It uses friction. The sharper knife has less friction than the blunt one so it cuts easier.
Have a look here: http://science.howstuffworks.com/hydraulic1.htm to understand about hydraulic multiplication.
Old 05-10-2007, 07:48 PM   #99
Blue Oval Mopar Man
Has Blue Blood
Blue Oval Mopar Man's Avatar
I got 88% so I think I got 6 wrong ! I hate wiring and electrical !
Real cars dont wear bowties
I'm not arrogent , Just superior
Blue Oval Mopar Man is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 09:04 PM   #100
mrxy8
I Loove Australia
mrxy8's Avatar
98% got ha retarded #2 wrong :
mrxy8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 09:04 PM   #101
kremmen
kremmen's Avatar
Originally Posted by GreenMachine
79%... But I'm a lawyer, not an engineer.
92% and probably couldn't put much of it into practice....
I'm surprised you didn't argue that 21% of the questions were incorrect then... :
Not finishing projects since 1992.....
kremmen is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 09:11 PM   #102
Van D
Van D's Avatar
So it was A? :P
I think i've got my head around it.
Originally Posted by irlewy86
Holden made the decision to make thier utes for pretty boys years ago. Wannabe tradesman drive them. If my son came home and told me he bought a holden ute I would struggle to come to grips with the fact he is a homosexual.
Van D is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 09:44 PM   #103
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
I got 80%.. Stuffed a few ratios and the suction cylinder Q.. plus a few here and there..
Im a structural engineer so Im not used to things moving ;P
Cars:
- Ford Ranger Wildtrak
- XY GT Replica
- XB Coupe Project
BOOSTDEF is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 10:28 PM   #104
XR6Dan
Why??
XR6Dan's Avatar
90% Yeh baby
XR6Dan is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 10:57 PM   #105
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
New apptitude test. HOW MANY OF YOU ARE LYING ABOUT YOUR SCORES ?
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 11:11 PM   #106
tapeworm
tapeworm's Avatar
56% from my corner. Am I semi retarded : ? lol.
tapeworm is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 11:50 PM   #107
blk_frmnt
ẶЦ ╒ǻІґмΩאַâ€*
80%
Haven't seen any of this since high school physics, and I was feeling pretty good about my result until I saw this:
Originally Posted by Fantome
My 13 year old daughter did the test and got 84%. Smart girl!
blk_frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2007, 12:53 AM   #108
EX-Y494
EX-Y494's Avatar
88% I'm happy with that.
Proud member of the All Ford Club of QLD
_____________________________________________
98 AU FORTE-Congo Green
C2R body kit, 2 1/2 cat back Exhaust, Red Diamond 2800rpm stall converter
BA front brakes, BA air box with pod
http://www.aufalcon.com.au/cgi-bin/i...act=item&i=326
EX-Y494 is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2007, 01:30 AM   #109
DDXR6T
DDXR6T's Avatar
90%, nobbad for no special education ...
DDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2007, 02:24 AM   #110
prof-rabbit
I got 76% but still didn't pass, bummer.
prof-rabbit is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2007, 01:43 PM   #111
T3man
T3man's Avatar
heheheh ... 92%, I can live with that BUT, there is a trick question or two in there that are ambiguous.
Old 06-10-2007, 01:52 PM   #112
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Did this the other day when GreenMachine emailed it to me... 100%.
Sweet. I'm smart enough to become a diesel mechanic.
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 03:39 PM   #113
blackers10
blackers10's Avatar
74 percent
didnt take too much time on it
id say i got most of the ratio ones wrong(ie how much weight does B require to be moved etc
Old 07-10-2007, 04:01 PM   #114
Debzilla_108
Debzilla_108's Avatar
i got 54%
im proud of my self lol i got more then half...
New project ZJ fairlane
My Build Thread
"When there's nowhere left to turn...........turn right!"
Debzilla_108 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 05:56 PM   #115
Perun
SSith Lord
Originally Posted by Yellow_Festiva
80%... yay.
Not bad for a person who dropped out of physics after 2 weeks in yr 11.
Ok, but I also taught "Simple Machines" term 2, and electronics term 3 lol.
Same score, similar situation. I bludged at the back of the classroom until the end of year 11. hehe
Perun is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 05:59 PM   #116
blownba
LPG Forum Moderator
blownba's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all his assistance helping members with their LPG issues.
Hey EX-y494. have you noticed that the little guy in your avatar is standing infront of a clutch pressure plate????
Or did you notice and did it for a reason???
blownba is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 06:00 PM   #117
JBomb3000
78%, I failed
JBomb3000 is offline   Reply With Quote Multi-Quote with this Post
