Old 18-02-2009, 05:35 PM   #91
greenfoam
Originally Posted by last fairlane
Hi all keep this thread going
I just typed in Repco Brabham in Google and up cam pics of Jack and also an engine with Repco Brabham on the rocker cover also a Brabham Buick and who could forget the biggest piece of Crap Holdens made was a Brabham Torana of 1968 with a whole 75 HP although not really a Holden it was a HB Vauxhall Viva with the new name of Torana and had absolutely nothing in common with the "LJ" and so on Toranas that went to bathurst just the name
The LJ just has a longer nose to fit the holden 6 in, still the same basic Vauxhall car as far as I know (but evolved by Holden) : )
greenfoam is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 05:40 PM   #92
Rev28K
re
Location: Victoria - where being slow & incompetent is considered being "safe"
ZR1 LT5 was 32 valve dohc per bank. Designed by Lotus, but they had to use Chevys standard bore spacings which meant that the bore/stroke ratio was a bit out.
Re: Yamaha casting Fords alloy heads. IIRC Bill Tuckey's True Blue book said that it was Honda (not that I have anything against Yamaha they have done hot Toyota engines (and the SHO Taurus V6) for ages)
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ
Rev28K is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 05:46 PM   #93
burnz
VFII SS UTE
burnz's Avatar
EA to AU not the intec (honda deseign) the head, but ford foundry the design.
GO SOUTHS
Old 18-02-2009, 05:49 PM   #94
Paxton
Cobblers!
Paxton's Avatar
¿Qué?
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 06:43 PM   #95
Kieron
Correct. The alloy head was a development of the iron xflow head but cast by Honda in Japan. From a very vague memory, the raw materials were shipped from Alcoa Australia's Pinjarra plant.
Other info, Ford Oz designed a DOHC head for the EA motor, was going to be on the 3.2 motor but only developed similar power to the 3.9 MPEFI so was never used.
Kieron is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 06:48 PM   #96
Nikked
Oo\===/oO
Nikked's Avatar
Originally Posted by xbgs351
Ford designed and made by Yamaha wasn’t it?
Wrong
In 1977 Honda and ford designed it. Honda cast it in japan. Using alloy shipped from australia.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 06:50 PM   #97
Nikked
Oo\===/oO
Nikked's Avatar
dang, beat me!
Funny it is, that xbgs351 was going on about misinformation....
\≡≡T≡≡/
Old 18-02-2009, 06:50 PM   #98
jphanna
jphanna's Avatar
[QUOTE=xbgs351]We are sure getting into grandfather’s old axe territory here.
XBGS351....i recon if we were to have a pub brawl, you would win.
anyway i appreciate your input, especially the first comment...
BMW 125I
Kia Seltos
Suzuki SV650
FG XR6 (son)
jphanna is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 06:53 PM   #99
ebxr8240
Performance moderator
ebxr8240's Avatar
Originally Posted by XR Van
different engine mate
f trucks had the 240 and 300 sixes
these were a canadian built engine not related to the small six
I'm sure when I worked for a builder years ago it had the 250 engine in it..
Not to be confused with D series engines..
What was said to me about Cat and Ford wasn't anything to do with thin wall casting...
Way back diesel engines where made in three separate sections..Like some motor bike engines today ..
They joined forces to design a mono block ..Where crankcase, cylinder section etc was in one cast block to make engines stronger and cheaper to make....
Without being pedantic I'm sure Toyota and other companies have copied .. Not exact copies .. Some of the old Celica motors look very similar to B series Austin motors.. With a little Roots thrown in.. Like the Humber 80 engine..
The old side valve Cadilac and Ford are similar too.. The Caddy has inlet and "exhaust" on centre side of heads..
Daily driver GTE FG..
Old 18-02-2009, 07:04 PM   #100
Nikked
Oo\===/oO
Nikked's Avatar
Cosworth Did build a Motor on the kent, a variation eventually found its way into the RS200.
The Famous YB cosworths are based on pinto blocks.
\≡≡T≡≡/
Old 18-02-2009, 07:17 PM   #101
xbgs351
Originally Posted by Nikked
Wrong
My recollection from when I was a kid was that it was Yamaha. I did a search and some sources stated Honda and others Yamaha. It wouldn't be the first time that a book was wrong, so that is why I asked it as a question rather than stating it as a fact.
xbgs351 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 07:22 PM   #102
xbgs351
The BDT.
Old 18-02-2009, 07:33 PM   #103
xbgs351
And they were started by petrol donkey engines that where started by a cord. Can you find any photos of these diesels?
The Toyota T series motors look nothing like the Austin B series motors.
Old 18-02-2009, 09:12 PM   #104
ebxr8240
ebxr8240's Avatar
It was said by an old cat tech while working charter boat in Bay of Islands..
My bothers Cat motor at the time was 250 h.p V8 N/A.. Power was possibly restricted being being a charter boat, drive shaft size etc..
Easy... the 18RG does ..Very heavy motor..
I didn't mention T series??
Old 18-02-2009, 09:16 PM   #105
last fairlane
last fairlane's Avatar
Talking Alloy heads
I always thought it was Yamaha that did the work on the XD heads
just something in the back of my mind
This is getting very interesting even if the facts are just old memories and sometimes the memory fades a bit
thanks JP or starting it off
I do remember reading back in 1963 that there was a Falcon 170 CI with a super charger and fuel injection that was making 200 horse power some thing incredible from a motor that ran 100 HP in standard form
Also what about the Falcon of Pritchards in Bayswater in Melbourne that ran a Steam Engine
Just getting off track a bit here
Does anyone remember Norm Beechys S4 EH Holden they were always painted in a salmon (pinky) colour
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2009, 10:01 PM   #106
xbgs351
You mentioned Celicas, and hence I assumed you meant the T series.
Old 18-02-2009, 10:26 PM   #107
ebxr8240
ebxr8240's Avatar
Yea I swear the 1UZ is lighter than than original motor !!
Old 19-02-2009, 08:47 AM   #108
aquahead2001
aquahead2001's Avatar
On both those comments, the alloy material was supplied by Alcoa Point Henry Smelter as it was the only smelter in Australia capable of producing Alloy material back then, all others at the time produced straight alumium un-alloyed. Also Pinjara is an Alumina refinery and not a smelter.
Finally, I had a neighbour who was the Product Engineering Engine Guru for Ford back in the EA development days. The DOHC Engine was going to be used as an XR engine but if you remember back then, the finances were pretty slim and the EA was a bucket of goop and every thing looked terminal.
I've always wondered how much of that engine was used as the basis for the Barra Engine...
aquahead2001 is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2009, 03:31 PM   #109
Kieron
Thanks for the correction aquahead. I knew it was most definitely Honda that did the castings and the raw materials came from Alcoa Aus.
I had a black and white picture of an engineer working with the DOHC EA head somewhere, if I find it, i'll post it up. From memory, it used fingers/buckets and no bearing shells, (same as the SOHC head).
Old 19-02-2009, 04:14 PM   #110
BlackLS
yum
xbgs351 you really know your stuff!
2005 LS Focus LX
250,000kms.
Old 19-02-2009, 09:22 PM   #111
ebxr8240
ebxr8240's Avatar
RS1800 was designed around the Kent engine.. Though much much stronger!!
The alloy block above is similar to 1600 engine..
I remember guys like Brian Hart, Don Halliday bros racing Comaro's around Bay Park at the mount..
His ATS spell was the start of a successful designing career, spent mostly in the US. Founded, and still head of Halliday Technologies and also BLIS technology, and now a engineer for Paul Newman's Champ Car Atlantic team. Also helps nephew Matt and daughter Liz in their respective series.
I bought his rally 1600 and latter 2000 Heatway rally engines..
Old 19-02-2009, 10:27 PM   #112
Bossxr8
Peter Car
Bossxr8's Avatar
Twin cam EA engines were built as prototypes, but the SOHC engines made good power and were cheaper to make. DOHC would only have been used if the SOHC heads couldn't provide the power Ford wanted.
I was lucky enough to have a look around Fords engine lab a few years ago, and its pretty amazing how they use high speed cameras to view engine internals when they are running on the dyno. The rocker covers have a section removed and replaced with clear perspex, and the camera films what the rocker gear is doing. I think they may even be able to film the combustion chamber to see how the fuel air mix is burning.
