#91 | ||
ok people, how much would I expect to spend on a project like this, 8K?
FTG, how much for your part of the conversion? and I would be looking at running the engine from something like a wolf or motec. Thoughts? |
#92 | ||
You will need the entire engine, a gearbox to suit and an ecu.
Depends if you want to run the VCT or not as to what computer you choose. 10K would be closer to the mark for a turbo motor. Are you fitting everything yourself or paying someone?
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
#93 | ||
If the engine is a straight swap I will be doing it myself, I will be getting someone else to do the ECU though.
#94 | ||
Seems like this is still born at this stage. Great idea, however someway off yet
#95 | ||
Changing the ECU and complete Wiring and complete driveline would surely make this project a goer, wouldnt it?
#96 | ||
How is this project progressing? Haven't heard anything for a month.
. . Rob Ewart Bog standard silver BF Wagon, except for the Elvis doll ![]() Victorian Rock'n'Roll Dance Association www.VRRDA.com.au 2015 Victorian Rock'n'Roll Dance State Championships 23 May 2015, Furlan Club, Thornbury |
#97 | |||
#98 | ||
I think Darren in on leave at the moment
#99 | |||
Commercial Sponsor
the wagon has been scrapped , we know it can be done but time is an issue. i need to concentrate on other stuff at the moment and wanting to build up a focus V8 aswell |
#100 | ||
Kick out tha Jams
a big v8 in a little focus would make for one quick car!
$416.80.......All that cash came from a new (used) car. Check your back seats! |
#101 | |||
#102 | |||
Commercial Sponsor
yep its been done, but i dont know if there is a road registered one in OZ |
#103 | ||
LR or yummy LS V8
#104 | ||
Hey All,
Just looking into this again, there is a problem with getting the AU PCM to use the VCT, wouldn't you be able to simply use an aftermarket ECU like a wolf 3D? |
#105 | ||
yes, wolf 3d can support vct
#106 | ||
So theoretically BA engine + Wolf 3D = working engine in an AU?
#107 | ||
the way i see it if you use a BA engine harness and ECU you should be able to feed the smartshield wire to it then it should be just a matter of programing it . no saying it will be easy but might be a good way to get it running
#108 | ||
I thought you would keep the AU ECU to run the dash/smartlock and whatever else, and then use the BA engine harness on the engine and run a separate aftermarket unit... so you would have 2 ECU's.
#109 | ||
Couldn't you just use an aftermarket ECU to do the lot?
#110 | ||
So is it hard to fit an BA enigne into an AU? Rough costs? How much modding will have to be done?
I could possible do this in the next couple of months or so...Either that or i'll be buying an XR6T motor and dropping that into my AU.... Regards... |
#111 | |||
#112 | ||
I would budget about 6K to 8K to install a turbo engine, I am talking to nizpro about this.
I will be running my whole setup from either a stinger or wolf EMS |
#113 | ||
Works for me..
But the BA computer wont run the smartlock and AU dash.. Well thats what I heard, which is why I posted previously. |
#114 | ||
So will a stinger or wolf run all the accessories in an AU? or will I have to run dual ECU units?
#115 | ||
As far as im aware, from speaking to FTG about this a while ago. Spewing I deleted all the private messages.
You leave the AU ecu as is, then put the BA motor in, run the BA engine loom and run an aftermarket computer to that, the one that was suggested was a Motec.. but im fairly sure a EMS stinger 4424 or an EMS 8860 would do the job. If I had my way I'd go a Haltech, but thats me. The AU ecu needs to be kept because the BA ecu cannot run the smartlock and a few other things. |
#116 | ||
I'd love to fit the F6 motor into mine. But my credit card does not have a limit high enough.
#117 | ||
So i would have to run 2 ecu's?
A haltech or wolf or stinger and the AU ECU? |
#118 | ||
For the money spent on the conversion, it could have you a strong rebuilt force fed motor that you already have in your engine bay.
#119 | |||
#120 | ||
FALSE!!!! there is not very many aftermarket computers that can run the dual vct... most of them only have one input. motec makes one that can handle both but ive been quoted 6500 bucks installed just for the pcm and a MINOR TUNE....
but ive almost figured out all the required inputs for the ba engine. as i want to put one in my eb. oh and im going to be running it on the standard pcm. you need the entire ba engine, wiring loom and the following components. icc, ic, bem, him and a few other modules. so figured how to put an entire ba dash into my car... (helps working at ford) so ill i need is the cash and i will do it.... accepting donations....lol theres still a few problems i havent figured out yet though |
