Old 12-07-2007, 04:12 PM   #1
hammers90
Default wagon
hey guys,
im thinking of lowering my AUII wagon. DOes anyone have a reason for me not to do this??
How much would i be looking at to pay for it??
cheers
hammers90 is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2007, 06:01 PM   #2
falzoony
Rockin '67
falzoony's Avatar
No reasons not to do it just dont go lower than 1.5 inches. If you go lower it will most probably scrape as soon as you have weight in the back. I don't have a wagon but mine cost$500 and it has king spring superlows.
BA XR6 Turbo
'67 XR Wagon
falzoony is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2007, 07:00 PM   #3
JC
JC's Avatar
I lowered mine using 38mm (1.5") lowering blocks in the back, and massaged XR8 ute front springs. Sits nice, handles well, and even with a full load, is still comfortable. I did all the labour myself, so the whole job was under $200.
This is it fully loaded on holidays earlier this year:
To get reset leaf springs (stage 1 Pedders is a good height), and new front springs is around $600 in parts, plus labour (probably around $400).
Ford Performance Club ACT
Old 12-07-2007, 07:14 PM   #4
Gilesie
You gotta pay to play
Gilesie's Avatar
I lowered mine
super lows up front
rear springs reset
front brakes replaced at the same time
it cost me about $1000 (mechanic did the work)
the rear is a little higher than the front which allows for loads or towing
From memory I think he said the reseting of the springs was about $300
Regards Gilesie
AU I Forte Wagon 4.0
Dodge D5N Twincab (Project)
2003 Mazda Bravo (work truck)
1979 F100 Ambo
Gilesie is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2007, 07:29 PM   #5
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
if you dont want to reset the stock leaf springs, you could use lowering blocks. If you take a look on eBay, you can get the front springs and blocks for under $200.
Problems depends on how low you want to go. symptoms could include scraping over bumps, up driveways, or rubbing on the guards around corners.
Lower suspension will generaly give you a firmer (harsher) ride, but thats contrast with improved handling and a lower center of gravity meaning less body roll - this is something to keep in mind if using lowering blocks, as they wont firm up the ride so can make it easier to bottom out as opposed to resetting the leafs.
If you plan on towing heavy boats, caravans, horse floats, trailers etc, dont go too low, or you may find you cant tow anything!
Other then that, the lower you go, the better you look, but the more you attract the boys in blue.
$416.80.......All that cash came from a new (used) car. Check your back seats!
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2007, 07:44 PM   #6
bodes-sh
^^also, depending on what size wheels are on the car, you can't go too low with lowering blocks as the lower suspension bolts hit the wheels, i think that's the problem people have encountered anyway......
Old 12-07-2007, 09:17 PM   #7
rag top
rag top's Avatar
In terms of cost, can you do some of the work yourself??
If you are interested, I've got a set of reset leafs from my wagon sitting in the garage.
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2007, 10:10 PM   #8
hammers90
nah, unfortunately i havent got a clue what to do.
Old 12-07-2007, 10:37 PM   #9
rag top
rag top's Avatar
Do you have access to tools and space??
Old 13-07-2007, 09:12 PM   #10
au adam
au adam's Avatar
Im interested but im(sorry you)are in the wrong state.
au adam is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2007, 09:13 PM   #11
private9
www.TUFFCARPARTS.com
private9's Avatar
Originally Posted by Gilesie
I lowered mine
super lows up front
rear springs reset
At that height do you have many issues with scraping things? Particularly with a load in the back?
Old 13-07-2007, 09:30 PM   #12
Gilesie
Gilesie's Avatar
no it was done not to
that was the thing when I got it done I told him that it is the family car
Regards Gilesie
1979 F100 Ambo
Old 13-07-2007, 09:42 PM   #13
private9
private9's Avatar
Got any pics of it side on? How much higher is the back? I was thinking of going super lows, and then get the back sitting level, but am worried it's going to struggle with loads.
Old 13-07-2007, 09:49 PM   #14
schuldiner
hey there, got an au s2 ute will those reset springs suit mine? i dont see why they wouldnt. i would like to lower mine (not too much though) more so if price permits. if so what state are you in? and how much would you part with them for?
Everything always works out when you just do whatever you want and don't worry about the consequences.
see my ute here
AU parts for sale
schuldiner is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2007, 09:54 PM   #15
Gilesie
Gilesie's Avatar
I will try to post some over the weekend
Regards Gilesie
1979 F100 Ambo
Old 13-07-2007, 10:02 PM   #16
private9
private9's Avatar
Still got the luggage & roof racks on?!
Old 14-07-2007, 08:24 AM   #17
au2sw
Blown 5L coming
au2sw's Avatar
at stock hight, the rear of the wagon sits about 1 1/2" higher then the front. how low you go also depends on what roads you travel frequently and what (if any) kit you have on the car. i found at stock hight, my TS50 front bar scraped on a few things if you didnt get the right angle over the speed bump/drive way, so im only lowering the rear 1 1/2 to level her up a bit. i dont do any towing, and if theres heavy loads, i have a ute
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2007, 10:07 AM   #18
waggaclint
waggaclint's Avatar
does anyone know about SR serIII WAGONS ive got one and its already lowered a bit from the factory the front seems alright....ive just put 18in wheels on it and id like to lower the rear just a bit to level it out...can you get 1/2 in lowering blocks i only want lower it about 3cm hey....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2007, 10:50 AM   #19
GK
Walking with God
GK's Avatar
I was quoted by a Pedders to lower the wagon front and rear to XR height all up was $600.
Hope that helps.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 15-07-2007, 07:50 PM   #20
rag top
rag top's Avatar
I'm in the ACT, so freight would be a killer. If you are interested, send me a PM.
