Old 18-09-2007, 01:47 PM   #1
private9
www.TUFFCARPARTS.com
private9's Avatar
Default Anyone want a s/h Oxy sensor before it goes in the bin?
Hi All,
I know it's probably useless, but does anyone want a second hand Oxygen sensor for an AU i6? From memory it has about 150k on it, and I did see an improvement in fuel consumption when I changed it.
As I said, probably useless, but thought I'd check if anyone wants it before I chuck it!
Thanks,
Justin.
Old 19-09-2007, 10:24 AM   #2
james22
With da Warlords
james22's Avatar
I'm keen, i'll take it. I'm trying to diagnose a problem with my mrs car, so it'll come in handy. Seeming as we know its rooted, if I put it in her car and the fuel consumption stays the same I'll have found my problem.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 19-09-2007, 10:48 AM   #3
private9
private9's Avatar
No worries mate, PM sent.
Everyone, my highly desirable 02 sensor is now taken!
Old 19-09-2007, 11:23 AM   #4
StealthAu
O2 sensors can be cleaned instead of replaced, they get carbon build up which inhibits there ability to function correctly. A good clean with some throttle body cleaner is as good as replacing them.
Old 19-09-2007, 12:19 PM   #5
private9
private9's Avatar
Good stuff, hopefully James is able to get some use out of it then.
