Sales Representative
Is it worth installing a sub into the factory location with the same sort of sub factory came out with? I'm pretty sure its a Free-Air styled one and probably around 8". I'm not after huge bass, but some nice quality sound.
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
Formally FairmontPom
Hi Blueprint,
My AU2 Ghia has the premo sound system, and I would say "don't bother" to the idea of adding an free air 8" subbie ! From what I can gather, it adds more 'depth' rather than thump or rumble to the music I listen to (dance/house/tech etc), and can easily be made to distort on higher volume levels. A small boxed-up sub tucked by the rear seats in the boot will be 100% more effective. Just my 2 cents worth anyway.... Cheers |
Okies... i wasnt going to use a factory sub, but an aftermarket in the some location and type... but maybe not... My biggest problem is the LPG tank.
Fair enough, maybe if more depth and weight to the music is all you're after (I re-read your first post by the way!), then the parcel shelf is the way to go !
ok ok... i kinda lied i spose... i like dance music aswell as old rock and stuff... i'm not after 2 sub type power bass, but some real clear omph in the dance tracks would be great...
www.TUFFCARPARTS.com
Yeah, pretty much no free air sub is going to give you nice bass. If you just want a bit of nice clear bass, just go for a 10 in a small sealed box.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
Righto... any threads/sites on AU sub setups that include designs and drawings?
acclaimed user
you can fit a 10" free air sub if you use a spacer, and private9 I don't think you have much experience with free air subs. you can get good bass from them but don't have expectations that they can extend as low as a 12" sub.
You will find that sound deadening the parcel shelf will also increase the bass noticeably as well as help reduce rattles. The stock 8" sub is crap though, it's not because it's underpowered as I tried running it off a much bigger amp, it's just a cheap sub and really only cancels out road noise than add much to the music |
Audi S3
i reckon the stock premo sound is alright. i love driving my mums 'lane with premo sound cause the music now has some added bass. i listen to heavy metal, and the 8 inch is still punchy enough to keep up with crazy fast double kicks too.
#10 | |||
I need to do some more research before i do anything... i have a 10" sub and 2 channel amp i want to use, but am restricted in room. I want to use the cavity on the drivers side wall of the boot, as i have a LPG tank in the way behind the seats.
#12 | ||
You can always get a decent aftermarket 8" and build a small box around it on the underside of the shelf. My dad has this setup in his AU Ghia and its sounds pretty impressive. Not very intrusive at all, you can hardly notice it with the boot open. I would say it would fit with a lpg tank in there also.
Evan |
The centre shelf is ok for a small sub,providing it's well fitted and has plenty of dampening when fitting,otherwise that shelf area vibrates something wicked when even medium volumes are applied!
Or you could do what I have done-(and before anyone flames me,it actually works damn well!) and use the cars built in,ultimate 100% portable sub box-the spare tyre! I am not kidding.I have 2 grunty Alpine SLR's as my parcel shelf speakers and was about to fit a small sub into the 8inch centre hole,when my mate showed me his portable sub in his beamer's spare wheel. I have a 12 Alpine sub,with a spacer made of MDF that I cut to match the size of the inner wheel well of my spare.It simply sits flush in the back of the spare. Pop the carpet back over thats it! And the tyre kills any vibration.Best damn speaker box I've ever had,and sounds great! Good luck. |
#14 | |||
#15 | ||
one could EASILY make a fibreglass box or even MDF box that sits on the side in the cavity between the tail light and strut tower..
for a 10" or 12" sub if anybody in QLD is after a stock sub.. i have one here they can have for $20 or somthing
#16 | ||
This is the area that i can use... not enough room for a small sub under the parcel shelf either
#17 | ||
a 10 or 12" sub will fit in a box made to follow hte contours there perfectly!!
just needs to be around 1 cubic foot..
#18 | ||
Thats what i was hoping... I want it so it can be removed without to much hassle via a couple of clips and a loom.
