Old 01-01-2008, 04:08 PM   #1
fordman_01
DUB
Default Series 1 to series 2/3 question
hey, i was wondering whether a series 2/3 bonnet and boot would just swap over with a series 1 bonnet and boot. is this possible or will there be too much problems with it. i take it that the boot might not be too difficult but the bonnet might need different parts so it will
has any one else done this to there series 1 falcon?
thanks neil
fordman_01 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2008, 04:35 PM   #2
Chamelion
I would immagine you'll need a bonnet and grille. I don't believe there is any other difference. I could be proven wrong though. ;)
Chamelion is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2008, 04:44 PM   #3
FGII-XR6
FGII-XR6's Avatar
100% correct you just need the right grill and no dramas
Old 01-01-2008, 05:33 PM   #4
JC
JC's Avatar
You need bonnet and latch. You don't really need the grille, as the grille just fills a void, and the AU1 grille will fill 3/4 of it - yes, it would look funny, but it's more of a want than a need. Without the right latch, though, you will never get the bonnet open again once you shut it.
There is no difference between an AU1 boot and AU2/3 boot. The trim attached to the boot is different, but you can change that without needing to change the whole boot.
Why do you ask?
Ford Performance Club ACT
Old 01-01-2008, 07:16 PM   #5
FGII-XR6
FGII-XR6's Avatar
there is no difference in the latches
Old 02-01-2008, 01:22 AM   #6
JC
JC's Avatar
Actually, there is - not the part attached to the bonnet, but the handle attached to the radiator support panel. The AU2 one is taller and a different shape. If you don't believe me, fit an AU2 bonnet using the AU1 latch, and then try opening it. (If you do try this, I would recommend NOT fitting the grille if you ever want to get your bonnet open again)
Old 02-01-2008, 01:57 AM   #7
Chamelion
Latch too then. Learn something new every day.
Old 02-01-2008, 02:07 AM   #8
RG
Back to Le Frenchy
RG's Avatar
This is true, wrecker sold me an AUII one for my XR and I couldn't close the bonnet because of the handle.
Old 02-01-2008, 10:05 AM   #9
fordman_01
DUB
Why do you ask?[/QUOTE]
because i have seen a series 2 falcon for wrecking and was thinking about changing things over. and because i really want a chrome grille
Old 02-01-2008, 10:07 AM   #10
fordman_01
DUB
so JC all i would need to do i swap the latches over aswell? or would i need to modify something? hope its easy
Old 02-01-2008, 10:08 AM   #11
fordman_01
DUB
thanks for your help so far guys
Old 02-01-2008, 10:28 AM   #12
JC
JC's Avatar
Just swap the latches over. The old one is held in with 2 bolts, and the cable clips in - undo the bolts, lift the assembly up and unclip the cable, then install the new one.
Old 02-01-2008, 10:55 AM   #13
fordman_01
DUB
thanks mate, sounds pretty easy...well hopefully. o i got another question how does the new grille fit in after i put the bonnet on, do i just use the same holes as a series 1 grille?
thanks neil
Old 02-01-2008, 01:56 PM   #14
JC
JC's Avatar
thanks neil
Yep - same holes.
Old 02-01-2008, 04:50 PM   #15
fordman_01
DUB
Yep - same holes.
sweet cheers
