Old 27-03-2008, 10:29 AM   #1
james22
With da Warlords
james22's Avatar
Default Au - MAP sensor removal
Hey ppl. I ran a search, but its near impossible to find matches for MAP lol.
What I need to know, is how the hell do you remove it? If its what I think it is (small box, prob half the size of a smoke packet, directly under the t-body / butterfly) Its near impossible to get to. I cant' get a ratchet onto it because of the fuel rail, and you'd need to be a Japanese monkey to reach it from underneath?
Any ideas?
I want to pull it off and clean it out, as I'm now sure after 15months of looking, that this is the cause of the problems with the car.
Eg,
Hard to start
Too rich all the time, especially startup.
Hesitation and flat spots
Extremely poor fuel economy - worse than my v8
Cheers,
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 27-03-2008, 10:39 AM   #2
InfernoSR
Sales Representative
InfernoSR's Avatar
Any ideas?
Eg,
Hard to start
Cheers,
I thought the part you are refering to is the throttle positioning sensor... :
Old 27-03-2008, 10:57 AM   #3
james22
With da Warlords
james22's Avatar
Buggered if I know, Anyone got a pic of the MAP? According to my Haynes manual, its placed directly under the t-body?
Windsor Warlords
AU III XR-8220
Old 27-03-2008, 10:58 AM   #4
JOSH
JOSH's Avatar
you have to remove the upper half of the inlet manifold, very easy job.
JOSH is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2008, 11:10 AM   #5
james22
With da Warlords
james22's Avatar
Thats what I thought lol, but didn't really want to do it. Was a bit lazy that day.
Is that the only way about it, or has someone else got a bright-idea :
Windsor Warlords
AU III XR-8220
Old 27-03-2008, 11:11 AM   #6
InfernoSR
InfernoSR's Avatar
A new engine?... wait... thats hardly a bright idea... but neither am I today :P
Old 27-03-2008, 11:38 AM   #7
james22
With da Warlords
james22's Avatar
Actually lol. I've got a brand new XR6 Engine sitting there ready to go for ages... 3 years+
Windsor Warlords
AU III XR-8220
Old 27-03-2008, 11:55 AM   #8
InfernoSR
InfernoSR's Avatar
yet i moved close by and wasnt offered in order to clean out your shed? :togo:
Old 27-03-2008, 01:03 PM   #9
sly
Sly like a G6
sly's Avatar
Eg,
Hard to start
Cheers,
I don't know if cleaning it out will give you much joy. I had exactly the same symptoms after an LPG backfire and eventually had the computer scanned for DTC's which indicated the TMAP was dead. I got the workshop to replace it with a new one, which involved, surprisingly, removing the top half of the BBM.
If it's been running rich for 15 months, that's probably stuffed your O2 sensor and cat as well.
As I've said in numerous other threads, get the PCM scanned for DTC's if the plugs, leads and filters are all good.
Sleeper, anyone?
Old 27-03-2008, 01:24 PM   #10
james22
With da Warlords
james22's Avatar
I read in another thread, that they cleaned theirs out, and noticed a difference immediately. If it does improve, Then I will know this one's shagged and will just replace it and my 02 sensor, Problem solved.
Windsor Warlords
AU III XR-8220
Old 27-03-2008, 01:51 PM   #11
b2tf
not here much anymore
b2tf's Avatar
Is this on the 6 or 8 Jamie? I didnt think 8's had a MAP?
2024 F150 XLT
Old 27-03-2008, 02:09 PM   #12
InfernoSR
InfernoSR's Avatar
Its a I6
Old 27-03-2008, 03:06 PM   #13
james22
With da Warlords
james22's Avatar
Yeah mate, Mrs I6. My old falcon lol hence the MAP not MAF
Windsor Warlords
AU III XR-8220
Old 27-03-2008, 03:07 PM   #14
sly
Sly like a G6
sly's Avatar
Fair enough. Just means having to get it out twice.
Sleeper, anyone?
Old 27-03-2008, 05:08 PM   #15
JC
JC's Avatar
Remove the TB, and then you'll have easier access to the MAP. I did mine without removing the upper half of the BBM, and I have big hands.
Oh, and the new MAP sensor is a wallet lightener too!
Ford Performance Club ACT
Old 28-03-2008, 01:33 PM   #16
james22
With da Warlords
james22's Avatar
Cheers, thats even easier. Like I said "lazy mood" . As for the wallet lightener, so I've heard. I might try the wreckers instead.
Thanks all
Windsor Warlords
AU III XR-8220
Old 28-03-2008, 01:53 PM   #17
TwistedEL
TwistedEL's Avatar
Thanks all
Get a new one... there is no guarantee one from a wrecker will work - you'll be in the same position you're in now (unsure what the problem is, maybe it's the MAP sensor?)
Old 20-11-2009, 07:19 PM   #18
sly
Sly like a G6
sly's Avatar
As a matter of interest, is the AU TMAP sensor fitted to the top half or the bottom half of the BBM?
The answer to this question and where it leads to next, may well be helpful to anyone considering boosting their AU...
Sleeper, anyone?
