26-06-2008, 01:31 PM | #1 | |||
Back to Le Frenchy
I'm almost due for an oil change in the XR and I'm looking at using Castrol EDGE. What would be the best to use, the 0w-40, 5w-30 or the 10w-60? The engine has 50k on it and uses a tiny bit of the Nulon that I have been using but I'm not sold on the fact that it is the engine's fault. I had a problem in my EL where it would lose a bit of the Nulon stuff but wouldn't with anything else.
What do we think?
26-06-2008, 02:06 PM | #2 | ||
Personally I run Castrol Magnatec. Have done for many years. I had an Eb years back that had a top end rattle on cold starts.... only lasted a few secs but drove near batty. (keep in mind this was a brand new engine) I was put on to Magnatech by a young bloke at my local ford dealership and it cured the problem instantly. So needless to say am a big fan of Castrol products.
At the end of the day all you can do is give it a go and see how it performs. |
26-06-2008, 02:13 PM | #3 | ||
Im using Castrol Edge 5W-30 in my 1 tonner at the moment as it was on sale the otherday not noticing any real difference between this and the Nulon I normally use.
26-06-2008, 02:29 PM | #4 | ||
Afterburner + skids =
Hmm. I used Castrol EDGE once and I wasn't overly impressed with it really. I found thatit made the top end nice and rattly on start up. I am currently using Valvoline VR1 Racing in 10w-40 and so far (2000km's) it seems up to the task.
26-06-2008, 03:04 PM | #5 | ||
T3/Sprint8
The T3 is just over 100k and have used Mobil 0/40 for ages....have tried Fuchs after hearing good raps but I kept hearing to many rattles at cold start.
Just put in ELF 10/50 Full Synthetic purring like a kitten will use again.
26-06-2008, 04:05 PM | #6 | ||
I put Valvoline Durablend 10/40 and its the best oil i have used so far. I have never had any funny noises on cold start up, never burns oil and I feel like it is protecting the engine really well.
As far as Castrol EDGE goes i have never tryed that product. What rating is the NULON oil that you got in your car now? Base your next oil change a little thicker then that if its burning a bit of oil.
Current: Built R32 GTR 520Hp ATW AU3 Fairmont I6 Whiteline swaybars, FPV Typhoon Rims, Superlows, Custom Intake Piping, Modified BA XR8 Airbox, Big Stereo Past: 2001 AU2 XR8 220 Manual 1/4 Mile: 13.8 @ 100MPH (161km/h) Ford Falcon AU2 V8 Auto 1/4 Mile: 13.0 @ 107MPH (172km/h) |
26-06-2008, 05:23 PM | #7 | ||
I tried GTX3 and my motor got a bit noisy so changed it to shell helix and motor shut up again. I'm not a fan of castrol anymore after that.
26-06-2008, 06:04 PM | #8 | ||
Sly like a G6
I use Castrol Edge in the I6, in 5w/30 which is the recommended grade in the AU1. I'd go the 10W/60 in a Wheezer as it's old school and probably has looser tolerances.
Unusual to have recommendations for Magnatec and Valvoline here, most AUvians who've tried these swear at them, not by them. But then most of them have 6's. I found my top end was noisy with Valvoline Durablend FWIW and has quietened down with going back to Edge. So maybe what works well in the I6 doesn't in the V8 and vice versa.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
26-06-2008, 06:12 PM | #9 | |||
Back to Le Frenchy
The wheezer may have looser tolerances from factory but this was built well and tight. the Nulon is a 15w50 but the oil burning is the oil, not the engine. Nulon likes to burn a bit for some reason I've found, I use the same amount if I use the 10w40. No more no less.
Bluedriver what was the elf worth for 5l?
26-06-2008, 06:51 PM | #10 | ||
not here much anymore
Russ I used Edge for a bit but didnt like it, Im using Penrite atm but by far the best I have found for mine is Shell Helix 15w50. Trying to convince the boss at Ricerbarn to get more in.
2024 F150 XLT
26-06-2008, 06:56 PM | #11 | ||
formerly PURSUIT-250
Penritre Sin 5 for me guy's.
Used mobile one but a bit rattley on start up, could have been the SHITTY Motorcraft oil filters though. Cheers Mick. |
26-06-2008, 07:51 PM | #12 | ||
MADED.6
i use penrite hpr15 but might go thinner next time.
also i am going to try motul oil its a bit more but apparently really good. and pursuit-250 i got told the motorcraft oil filters were the best flow and filtering rate of any replacement oil filter. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
26-06-2008, 08:23 PM | #13 | ||
Formerly known as TS 50
I'm using Penrite SIN 0 in my stroker at the moment. Its been in for 2000km and hasn't burn't any yet. Bit pricey but she's worth it!!
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
27-06-2008, 11:16 AM | #14 | |||
I used to swear by them till they started to import the other Motorcraft Thailand filters wich costed much less( the workshop used any where between 30 40 filters a week), know there is only the Thailand filter available. There are better filters out there, with greater quality paper and relief valve. It is a buyer beware market as motorcraft DO NOT make there own filters. Ryco made them for Motorcraft, not any more as it is cheaper to sorce them else where, And more profit $$$$$$$$$$$$. Cheers Mick. |
27-06-2008, 12:38 PM | #15 | ||||
Back to Le Frenchy
27-06-2008, 07:36 PM | #16 | |||
Back to Le Frenchy
I ended up going with the Penrite SIN 5. See how that goes, now to find me an oil filter...
27-06-2008, 07:55 PM | #17 | ||
I use pentrite 10w oil and K&N oil filter. The filters cost a little more..$18 from Autobarn. Figure K&N make good air filters so the oil ones shouldn't be to bad...also Autobarn lock them away in a glass case..so they must be desirable..lol
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD |
27-06-2008, 10:03 PM | #18 | |||
27-06-2008, 10:05 PM | #19 | ||||
Back to Le Frenchy
I think someone was trying to mis"lead" you
28-06-2008, 08:49 PM | #20 | ||
T3/Sprint8
Yep I use the PureOne (top Purolater filter) for ages so has Shaynet (both of us had bought them in qty) and a few other TSeries guys have, just harder to get nowadays.
Russell I'll check up what the Elf costed can't remember right now. Using the T3 today each time I started I thought how smooth she sounded with this Elf oil.
28-06-2008, 11:09 PM | #21 | |||
No help to you Russell, but I bought Castrol Edge 5W30/40 when it was one sale at Supercheap a few weeks back. It was just on half price (around $25 or something for 5 litres). Bought it for the Exploder, but may just use it as top up oil, as I also have a bottle of the Penrite 5W40/50, so might use that for the fill. I usually use Penrite HPR 10 in both my 6s and V8s, and I've never had any (oil related) issues at all.
29-06-2008, 12:50 PM | #22 | ||
AU3 Winged Windsor
what do people think of the valvoline oil filters?
29-06-2008, 04:10 PM | #23 | ||||
Back to Le Frenchy
29-06-2008, 07:16 PM | #24 | ||
I have been using the Castrol Edge 5W30 in the Territory ... works pretty good.
And especially I need 2 bottle of the stuff to change the oil in the Territory ... I took advantage of the 50% off like JC mentioned.
30-06-2008, 12:44 AM | #25 | ||
I was told that if you have the details of the clearances your stroker was built to, you can give that info to an oil company and they can tell exactly what viscosity oil you need. theres a big difference between 5w-30 and 10w-60. I reckon you'd want to know what you actually need rather than guess.
I was planning to start using Redline once my engine's run in properly. It costs a bit but apparently lasts 40000km+ between changes. you can get analysis kits too and just change filters at the normal interval and grab a sample of the oil to get analysed and they'll advise if you're getting close to needing an oil change. the analysis doesn't cost much either I think it was around $35 all up and gives you an indication of the condition of your engine too... |
30-06-2008, 09:35 PM | #26 | ||
Castrol Edge .......... just use it, very happy with results from this lube
Raptor VL & VLB (Billet compressor wheel) |
01-07-2008, 12:18 PM | #27 | |||
K&N , FRAM but make shure it is FRAM RACING, also Purolator but there are 2 types. Also as a guide hold a Z89 standard filter in your left and pick up eather one of these filters that i have mentioned in the other hand, and you will notice the weight diffrence. Cheers Mick |
01-07-2008, 02:32 PM | #28 | |||
With da Warlords
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
01-07-2008, 02:47 PM | #29 | ||||
Back to Le Frenchy
01-07-2008, 06:56 PM | #30 | ||
t i c k f o r d
I used to put in Castrol Edge and when new it was good stuff but I found it 'deteriorated' a lot quicker than other oils. By 5,000km the engine was more rattly than usual, I wouldn't have wanted it in much longer. Went back to Penrite with no dramas.
AUIII XR6 VCT Liquid Silver / Manual / Leather / Momo Wheel & Shifter / Premium Sound / Lovells Superlows / Koni Reds / T3 Pursuit Rims / Pacemaker 4499s / 2.5 Inch Exhaust |
