Old 21-09-2008, 09:34 PM   #1
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Default recirc-fresh air switch stuffed
Evening people, it seems the recirc-fresh air switch is stuck on fresh (AU1)
Is there any way of fixing this at all?
Holden: If you cant beat them, buy them.
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2008, 09:36 PM   #2
superroo
You can't stop the signal
superroo's Avatar
Define stuck?
The button is stuck down, or it is stuck on one setting no matter which position.
Old 21-09-2008, 10:23 PM   #3
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Originally Posted by superroo
Define stuck?
Stuck on one setting, sorry should have explained better, it will go to recirc if i hold it down but as soon as I take my finger off it it goes back to fresh
Old 21-09-2008, 10:35 PM   #4
superroo
superroo's Avatar
If it's doing that, i would say the micro switch inside of the button is stuffed.
It can be fixed. It should be easy for parts as it's a generic electronics micro switch, so jaycar/dicksmiths should have it.Assuming thats the problem.
As for getting to it, you need to pull the fascia out, then unscrew the heater controls, then pull the heater controls to bits. Then solder in the new switch, and put it all back together.
Just pulling it apart would confirm if it's the switch or something else.
It's tricky to do, but easy if your confident with you hands on skills.
If you need/want a tut for pulling the fascia out, their is one round here i wrote up that i can find.
Old 21-09-2008, 11:21 PM   #5
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Cheers for that, I'll have a look for the tutorial
thanks again!
Old 21-09-2008, 11:45 PM   #6
superroo
superroo's Avatar
Here is the tut, it's part of another write up i did:
http://www.fordforums.com.au/showthread.php?t=95787
Old 22-09-2008, 07:48 PM   #7
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Awesome stuff mate thanks for that
