Old 22-09-2008, 08:41 AM   #1
XR6_4EVA
Hardcore I6 Enthusiast
XR6_4EVA's Avatar
Default Vibration??????!
Hey guys,
Just started to notice on my XR that when i come to a stop i get a fast vibration through the car. Similar to the strain air con has on a run down moter while stationary...
The vibration gets a bit worse if i turn air con on.
Also noticed if i pump the break once or twice it can increase vibration for a second.
ALSO noticed now when i make sudden movements with my steering my intake makes a loud-ish "breathing in noise" and my revs jump up everytime i turn the steering wheel. Doesnt do it for the whole duration of the turn, just the initial movement
Also getting some odd vibrations sometimes while tight turning at low rmp.
4 weeks ago this stuff wasnt happening! powersteering fluid levels are good by the way!
Thanks guys
2002 AU XR6 VCT III 'ST'
Liquid Silver
Auto
Full Momo and Leather Trim.
Redback exhaust, high flow cat and Pacey Extractors.
SELLING MY GENUINE 18" AZZUROS WITH TYRES.
FRONT TYRES 95%
REAR TYRES 50%
XR6_4EVA is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2008, 08:46 AM   #2
RG
Back to Le Frenchy
RG's Avatar
The steering noise when stationary is normal, they are supposed to do that as the extra load of the power steer would stall it if it didn't. I would still be getting the rack checked though as mine did that when I bought it and it turned out to be a stuffed rack, lucky I noticed it before I picked it up.
With the vibrations when slowing I would dare say it is brake shudder caused by a warped rotor. A quick skim of them should fix that.
Old 22-09-2008, 08:53 AM   #3
XR6_4EVA
XR6_4EVA's Avatar
Thanks Russ but the vibrations are definitly not from brake shudder, i mean real annoying vibrations when stationary like something in the engine bay is spinning very quickly off balance!
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 22-09-2008, 09:16 AM   #4
RG
Back to Le Frenchy
RG's Avatar
Well that's not good.
Look at the harmonic balancer and the engine and gearbox mounts as the most likely subjects for that. My old EL had a similar thing happen and it turned out to be the passenger side mount.
Old 22-09-2008, 09:24 AM   #5
XR6_4EVA
XR6_4EVA's Avatar
Was the EL's vibration an actual vibration or was the car rocking a bit?
im talking phone sms message vibration type, just a bit slower...
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 22-09-2008, 09:27 AM   #6
RG
Back to Le Frenchy
RG's Avatar
It was an actual vibration, enough to annoy you.
From the sounds of what you are saying it is only a very slight vibration correct?
Old 22-09-2008, 09:32 AM   #7
XR6_4EVA
XR6_4EVA's Avatar
correct! if i just bought the car i wouldnt even notice it, but because ive driven with it being smooth as ice, its very noticeable and occasinoaly a mate comments on it.
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 22-09-2008, 09:35 AM   #8
RG
Back to Le Frenchy
RG's Avatar
Well then it may just be a case of checking the plugs and leads and giving it a service. A slight misfire could cause the troubles you are having.
Don't you just love internet diagnostics!
Old 22-09-2008, 09:50 AM   #9
XR6_4EVA
XR6_4EVA's Avatar
Hahaha...Thanks Russ for the quick replies.
In that case ill get it serviced and check it out step by step.
It just hit 100,000 km's, what are the usual things to look out for at this stage?
I heard O2 sensor can be an issue..
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 22-09-2008, 10:06 AM   #10
RG
Back to Le Frenchy
RG's Avatar
O2 sensor at that amount of k's should be replaced and is a very easy 5 minute job with an adjustable shifter. Fuel filter is another to look at, new leads if they are the factory originals, I'd go plugs as it it a good number for new ones, radiator flush since the warmer weather is coming, and change your diff oil too as I doubt that that would have ever been done. Best stuff for that (and others can attest to this) is Penrite Limslip gear oil 85w/140 and Penrite LSD additive. The diff in the IRS AU has a problem with "chatter", you'll hear it at low speeds whilst turning and it is a definite clunk. The heavier than specified oil along with the additive completely got rid of that for me and a few others here that have taken my advice.
Now that's a long winded post.
Old 22-09-2008, 01:27 PM   #11
XR6_4EVA
XR6_4EVA's Avatar
Thanks mate!! will have a look at all those things.
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 22-09-2008, 03:40 PM   #12
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
XR6_4EVA, mine does the exact same thing. Especially at night with lights on. It's so annoying.
"Any Color You Like As Long As It's Black, Matt Black, With Flames, And A Bit Of Pinstriping".
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2008, 04:10 PM   #13
XR6_4EVA
XR6_4EVA's Avatar
really!? its just a odd vibration which doesnt seem to effect the cars performance true? it drives normal and seems normal in every way.
The fact that the car vibrates more when the lights are on or air con is on could only leave me to believe one of the bits and pieces of the engine is on its way out!
Im 75% its power steering related as the vibration, and odd noises occuring at the beginning of each turn, started at the same time and didnt happen previously!
Can any one explain why the car makes a hissing noise from the intake for a split second when i turn the wheel?
Sounds like a vacuum leak!
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 22-09-2008, 05:30 PM   #14
brad`
The Monty
brad`'s Avatar
hey my car was doing it a few months back, i got it looked at and it cost me $100 odd to fix i had to get the IAC valve changed and T/B cleaned as well.
i think its called IAC, its the sensor thing just besided the T/B buterfly, sliver in colour,
she did tell me it can be cleaned out 8/10 times with some spray and a wipe
runs fine now no vibrations at the lights
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2008, 06:13 PM   #15
RG
Back to Le Frenchy
RG's Avatar
ISC, Idle speed Controller.
Old 22-09-2008, 06:19 PM   #16
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Yep, drives normal and everything just when a load is put on ie: Headlights, Rear demist etc etc is when mine vibrate's. I dont have the issue when the wheel is turned as you do but.
Cheers brad, i will have to give it a go. Thanks.
Old 28-09-2008, 06:23 PM   #17
mik
mik's Avatar
i`m just thinking out side the box here, if its a momentary bit of rough idle and usual wear and tear stuff has been checked, i would also check for cracked vacuum hoses lose air intake/manifold bolts etc, its probably not these but odd things crop up occasionally and can be missed by a service.
Old 28-09-2008, 10:57 PM   #18
brad`
The Monty
brad`'s Avatar
how did ya go Nostalgia ? any luck
Old 29-09-2008, 08:24 AM   #19
JMO
JMO's Avatar
Whereabouts are the vacuum hoses that should be checked? There are hoses everywhere :P
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2008, 08:44 AM   #20
james22
With da Warlords
james22's Avatar
Sorry dude, but he was right. It's IAC - Idle AIR CONTROL Valve :alien2:
Idle air control valve (IAC)
1. On a fuel injection vehicle, a valve that allows air to bypass the throttle plate(s), increasing idle speed. The valve is operated by an electric solenoid or motor. The vehicle computer controls the amount of opening to regulate idle speed for varying conditions such as cold string and air conditioner compressor load
2. An electronically controlled device that controls idle speed on fuel injected vehicles by controlling bypass air.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 29-09-2008, 08:52 AM   #21
RG
Back to Le Frenchy
RG's Avatar
Originally Posted by james22
Sorry dude, but he was right. It's IAC - Idle AIRSPEED Controller :alien2:3
Have a look at what Ford calls it. Depending on where you look it will be called an IAC or an ISC. HA!
Old 29-09-2008, 08:54 AM   #22
james22
With da Warlords
james22's Avatar
Try page 10.1.49 - in the Technical service bulletins. Ford own word HA HA, but yes your quite correct lol. Either way you corrected a guy that really didn't need correcting ey? ISC, Idle speed controller, IAC Idle air controller, Idle air speed controller, you know if you say that enough, it doesnt make sense anymore... Nevermind i'm just confusing myself
Windsor Warlords
AU III XR-8220
Old 29-09-2008, 09:00 AM   #23
RG
Back to Le Frenchy
RG's Avatar
FORD - Confusing the people since 1901
Old 29-09-2008, 10:47 AM   #24
XR6_4EVA
XR6_4EVA's Avatar
Thanks heaps guys, will get this stuff sorted next pay check!
Appreciate the responses
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 29-09-2008, 03:21 PM   #25
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
I'm yet to have a crack at it brad.
