Old 25-09-2008, 06:54 PM   #1
tezarity
Tezarity
Default Scratched door
Hey Guys.
Had the worst day at work yesterday and just to top things off, as i was parking the car, i was in such a rush i scratched it against a pole.
The only visible damage is on the little panel thing that sticks out of the door about 3 quarters of the way down. The paint is just scratched off.
Does anyone know if there is a risk of rust developing and if it is better to just get a panel beater to paint over it or have the little panel replaced ($70)
Only problem with replacing it is that i would still have to go get it painted.
Terry
tezarity is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2008, 07:48 PM   #2
Marquis 351
Marquis 351's Avatar
wat part is it? is it the door mould? wat sort of car?
Marquis 351 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2008, 07:54 PM   #3
tezarity
Tezarity
Whoops.
It's a 2006 Ford Focus LX
Not quite sure what the part is called.
I explained it to the ford dealer as the strip that runs accross the outside of the door about 2 thirds of the way down. It's painted the same colour as the body as well.
Thanks for the help hey
Old 25-09-2008, 07:59 PM   #4
Marquis 351
that will be a plastic door mould. easy to replace, it is stuck on with double sided tape, If thats all the damage, ur pannel beated could have a new mould painted and replaced in a few hours, it would be a case of u getting the mould takin it to the pannel shop, them colour matching and u calling back to have the old mould removed and new refitted.
Old 26-09-2008, 06:30 AM   #5
melbzetec
Old enough to know better
melbzetec's Avatar
As a temporary fix, go to Ricerbarn and get a spray can of matched paint (they mix it up for you) and spray the scratched area
Old 26-09-2008, 09:47 PM   #6
tezarity
Tezarity
Thanks heaps guys.
Really appreciate the fast responses.
