Old 21-04-2009, 02:08 PM   #1
InfernoSR
Sales Representative
InfernoSR's Avatar
Question Clunky feeling when reversing...
I have got a weird clunky feeling and noise when i try reversing. I have also started to notice what feels like a bit of play in the backside of the car when going around some corners.
Could this be the diff binding up some how? Otherwise, what course of action should i take?
Old 22-04-2009, 11:36 AM   #2
InfernoSR
InfernoSR's Avatar
No suggestions?
Old 22-04-2009, 12:52 PM   #3
Cookie-XR8
SKID IT
Cookie-XR8's Avatar
turbo it and it will all go away
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba
Where the boost junkies hang out -Forced Ford Forums
Cookie-XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2009, 01:21 PM   #4
InfernoSR
InfernoSR's Avatar
Only 1 turbo? i have 8 cylinders to use here... may aswell go with 2 smaller snails
Old 22-04-2009, 01:30 PM   #5
Mont5.0
Mont5.0's Avatar
check the mounts from the rear arms to the diff hat. Mine used to clunk and this was the cause (also the bushes in the arms may be shot). with mine someone had gutter bashed it and the pin on the diff hat had come away from the casing -so the clunking was the arms bashing against the casing.- hopefully you can understand my description.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2009, 03:01 PM   #6
InfernoSR
InfernoSR's Avatar
Did you also happen to get a feeling that it was binding up a bit?
Old 22-04-2009, 03:20 PM   #7
Mont5.0
Mont5.0's Avatar
not really. just clunky and loose feeling
Old 22-04-2009, 03:49 PM   #8
InfernoSR
InfernoSR's Avatar
Thanks for that... sounds like its time to organise a bush upgrade :P
Old 24-04-2009, 01:24 AM   #9
Stattic
Stattic's Avatar
if i reverse and put my foot in a bit by accident it feels clunky like ABS is kicking in and the tyres start to smoke... im talking not even half throttle
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2009, 09:06 AM   #10
InfernoSR
InfernoSR's Avatar
That i do agree with... i had to reverse up my somewhat steep driveway the other day, and she sure didnt like it... ended up with a nice black skid mark on the ground with a really good tyre imprint profile :
