03-08-2009, 10:55 PM | #1 | ||
hey guys my au is going through fuel, i fill it up, after i drive 100 kms, it starts to drink it moderatly fast,
i just filled it up last night, and after driVing around today shes already used a quarter of a tank of fuel, last time it did this, was my oxygen sensor which was stuffed, cat was stuffed, my bbm gaskest was stuffed, so any ideas, would help me out if any one is gonna mention, my cat is causing this, i will not reply to that person and ignore them cheers
03-08-2009, 11:05 PM | #2 | ||
Pro Street Au Ute
is it running rough or does it smell fuelly, hows you air filter is your maf connected properly, do i6 have a maf.
03-08-2009, 11:09 PM | #3 | ||
nah she doesent smell, air filter is only 6 months old since i bought it, everything has been replaced in january, i dont no if its the cold weather maybe, ecu is upping the fuel, making it use it quicker in return more throttle responce, or my ecu it self is playing up,
i will have to investigate it, i will change the o2 sensor agian, and se how she goes cheers
03-08-2009, 11:29 PM | #4 | ||
Sales Representative
have you tried restting your ECU? what about enquiring to a tune up?
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
03-08-2009, 11:34 PM | #5 | ||
i had a tune up in january, new plugs, leads, fuel filter, bbm gasket was replaced, o2 sensor was replaced, new stock cat was put in, everything was done,
but i am leading to o2 sensor, as this was the problem before i changed it, so obvisouly its stuffed agian, i will reset the ecu agian and see what happens, ill wait till shes empty, then reset it on a full tank, and see how she goes would the cold weather becuasing this to happen if noting happens, i wll get the car back on the machine to make sure everything is alright full check over is bout 80 bucks, which is quiet good compared to a nother company charging 200 bucks
04-08-2009, 12:12 AM | #6 | ||
plugs? i dont think 6 months is an unheard of time to wreck plugs, especially if its been running rich for a while (before you changed the o2 sensor as you said)
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
04-08-2009, 12:57 AM | #7 | ||
All Bran = Regular Member
It'd help if you can be a bit more specific.
Top your tank up and see how many litres it takes and then do your calculations for kms travelled. In my au a quarter of a tank can be anywhere from 13 to 20 litres - depending on which quarter it is (not all quarters are equal). If it's around 15L/100km city driving that ain't so bad. I average around 14/100km city driving and in my car that could quite easily register as a 1/4 of a tank of fuel. |
04-08-2009, 03:33 PM | #8 | ||
Critical Thinker
sounds like a fuel leak if its ripping thru that much fuel in so little time.
Im thinking the clamp to the fuel line to your fuel filter could be leaking/not done up tight enough?
04-08-2009, 08:05 PM | #9 | ||
im struggling to get 300km out of a tank at the moment, its shocking
i suspect maybe the o2 sensor but im taking it in to get looked at cuz its running like a pig, bogging down sometimes at low revs, missing and stalling when it starts etc... makes me sad
04-08-2009, 08:52 PM | #10 | ||
Lost Boost Gained Class
hmm something isent right im getting about 300K's out of my 60L gas tank i have no idea what i would be betting on Petch
2006 BF Fairmont Ghia
2001 AU Falcon |
04-08-2009, 09:20 PM | #11 | ||
XA GT
The thermostat could be stuffed causing the engine not to get to correct operating temp and the computer pumps more fuel in because its cold. Had this problem in an EB, replaced the themistat and it was like a new car.
--------------------------------------------------- XA GT, 6.848sec 1/8 mile @ 101.68mph |
04-08-2009, 10:06 PM | #12 | ||
www.TUFFCARPARTS.com
I'm betting the standard, good condition, high flow, semi-gutted, but fully tested ok cat is giving heaps of exhaust flow which is making the ECU up the fuel.
The fully reconditioned and fiddled cop chip you've got on it's way will balance that out nicely! |
04-08-2009, 10:58 PM | #13 | ||
LOL nice
05-08-2009, 08:05 PM | #14 | |||
not so stock
Liquid silver AUIII XR6, BA scuff plates with Tickford inserts, proudly displaying AU falcon.com stickers, lowered, K&N panel filter with wide mouth snorkle, 2 1/2 exhaust and hi flo cat, Illusion mags, slotted and drilled rotors. Next mods: extractors |
05-08-2009, 08:13 PM | #15 | ||
****ed myself i allmost fell of the seat
2001 AU Falcon |
05-08-2009, 08:53 PM | #16 | ||
dont start this up agian alright im sick of it, i reset my ecu other night, and now shes alot better on the fuel, i think its starting to lose its tune, cheers
05-08-2009, 08:56 PM | #17 | ||||
Back to Le Frenchy
Do you mean it's "learning" bad habits?
05-08-2009, 09:00 PM | #18 | ||
yeh thats what i mean, learning bad habbits,
05-08-2009, 09:05 PM | #19 | |||
05-08-2009, 09:10 PM | #20 | ||
yeh well the one which is getting redone will be replacing it, so it will be all good
06-08-2009, 12:10 AM | #21 | |||
LOL gold!!! and the response!
06-08-2009, 06:24 AM | #22 | ||
classic
2001 AU Falcon |
06-08-2009, 08:01 AM | #23 | |||
Back to Le Frenchy
Guys, enough.
06-08-2009, 07:52 PM | #24 | ||
shes all good now, will fill her up at some stage and reset the kms and see how much i get out of a tank cheers
06-08-2009, 08:09 PM | #25 | ||
now listen.
cat i have on is old allrighty i said it was touched, you no touched, not hit with a huge dent in it. the exhaust system i have on is only a single baby muffler and thats it, no resonator or other fancy stuff, just 1 muffler, the outlet on the extractors is 3 inch as the pipe from there to the cat, then a 3 inch out let from the cat and bolts up to my 2 and half inch exhuast system, if you dont like it i dont care no more as i will just ignore, as long as i like it im happy plus money is hard to get atm but in the future i will get the cat replaced for my own sake cheers
14-08-2009, 12:21 AM | #26 | ||
well i ran her basically out of fuel, filled her right up, cost me 90 dollars to fill her up with fresh fuel, then i reset the ecu, and to my suprise, she isnt using the fuel no more,
so my ecu must be lossing the tune over time, hmm
14-08-2009, 03:44 AM | #27 | ||
pull the pat turms off every 2 months or so that sould fix it and stop it from happing
2001 AU Falcon |
14-08-2009, 09:17 AM | #28 | ||
i cant understand you, sorry
14-08-2009, 09:21 AM | #29 | ||||
Back to Le Frenchy
The ECU doesn't "lose it's tune" as you say but rather it learns your bad habits over time. A Reset will fix this issue.
14-08-2009, 09:33 AM | #30 | ||
shes all good now any ways, cheers
