Old 10-11-2009, 08:35 PM   #1
SSD-85
Default Driver Door Acuator
Good evening all.
My driver side door lock acuator took the liberty of not working after my arm pushed the manual lock down accidentially. It now makes an ugly whirring noise before giving up. Is this something I can fix? or am i better off paying 20 bucks for another one?
Also, does anyone have any experience in their ABS light coming on, but then disappearing after you start the car again?
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2009, 08:40 PM   #2
frd906
have the same problem mate, had 3 of them and they didnt work just better off paying for another one cheers
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2009, 08:45 PM   #3
JC
JC's Avatar
Originally Posted by Scotty85
Good evening all.
You fix the actuator by getting another one; especially if you can get one for $20!
Ford Performance Club ACT
Old 10-11-2009, 08:48 PM   #4
SSD-85
Well that settles it then. Cheers.
Now for that friggin ABS light....
Old 10-11-2009, 11:02 PM   #5
JC
JC's Avatar
Take your rims off, and undo the calliper and pull the disc off, then clean up the ABS sensor ring (wire brush and brake clean should do it). If that doesn't work, replace the actual sensor in the upright assembly that is activated on the ring hub.
Old 10-11-2009, 11:10 PM   #6
SSD-85
Once again, Thankyou JC. Off to do the boring side of car work haha.
Old 11-11-2009, 12:24 PM   #7
Stattic
Stattic's Avatar
i think i paid $50 last time i replaced a door actuator, its just some silly plastic part and be warned, not every series is the same, i believe s2/3 were different from s1 as i remember we got one and it was series 2 and didnt fit and side by side they werent the same, so we bought a s1 and it fit perfect
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2009, 06:05 PM   #8
LPGUTE
LPGUTE's Avatar
dam 20buck thats cheap where are ppl getting their from?
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
