11-11-2009, 04:18 PM | #1 | ||
Apart from the ovbious and it runs out : , is there a warning light that alerts you that the air con needs to be re-gassed? I have a series 3 XR8, and an AU series 2 Ghia. Also can anyone recommend a South-east Melbourne outlet. I am in Wantirna South. THX guys.
11-11-2009, 04:27 PM | #2 | ||
No light.
With low gas some vents may feel cold while others feel like normal. No gas and all the vents will be the same as the outside temp. Also if the system has no gas in it the A/C pump wont engage.
AU XLS. |
11-11-2009, 04:27 PM | #3 | ||
AU XR6
I've been told that aircon systems are a closed system and therefore shouldnt require regassing. They will only require regassing if there is a leak pressent. Can anyone with more knoweldge confirm this?
11-11-2009, 04:58 PM | #4 | ||
speaking of air con i have a question sorry to hijack sednwol.
My air con is on 20 degrees (climate control) but sometimes it will become so hot that it's cooler to open the windows, then it will cool down a bit again then heat back up, i noticed on auto it heats up but if i set a speed and outlet it cooled down a bit but then got hot again..is this the gas running out or something different? cheers btw same temp through all outlets |
11-11-2009, 07:41 PM | #5 | |||
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
11-11-2009, 08:10 PM | #6 | |||
Blocked TX valve. or needs a regas. |
11-11-2009, 09:58 PM | #7 | |||
12-11-2009, 09:01 AM | #8 | |||
12-11-2009, 09:35 AM | #9 | |||
My compressor has just died, and I was up for $1200 for a new one (plus labour), but found brand newies on eBay for $395 delivered. They will be cheap aftermarket units, but for the price difference I'll be happy if they last even only half as long as the original (which has done 11 years service).
12-11-2009, 11:19 AM | #10 | ||
If you get the system re gassed you should replace the receiver dryer and inline filter while its discharged.
Its a good idea to use your A/C a few times in winter as the sealing o rings can go hard and leak and using the system keeps the oil up to them. My temp gets down to -1 Celsius on some days. Beer Baron ;)
AU XLS. |
12-11-2009, 01:12 PM | #11 | ||
gone fishing
The air con system is a closed system but what JC has said is correct.
I was told that the TX valve/in line filter and the drier should be replaced annually but that can get expensive to do, but it should be done at least every couple of years as the drier doesn't do it job anymore and the tx valve gets blocked from the small shavings from the pump.
Cheers Whiskers |
12-11-2009, 06:21 PM | #12 | ||
Booked my ute in today to be re-gassed and serviced. $300.
FPV GS Ute #370/Brembo brakes |
