17-12-2009, 06:11 PM | #1 | ||
Just wondering how the panel is removed? the round panel with the radio.
17-12-2009, 06:28 PM | #2 | ||
THE Fairmont Ghia 75th
its all clips except u have to remove the head unit first then it has a screw either side that needs to be removed then the 2 behind the ashtray then it should all pop off.
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install. My Ride My Build Thread |
17-12-2009, 10:41 PM | #3 | ||
ok, thanks.
18-12-2009, 12:17 PM | #4 | |||
You can't stop the signal
http://www.fordforums.com.au/showthread.php?t=95787
http://www.fordforums.com.au/vbporta...warticle&id=37
