460hp + manual = fun
hey all. i just bought a hard lid for my au this morning.
it is a genuine ford hard lid. but i got given some brackets buti dont know where/ how they go.what im asking is does anyone have pics of how there hard lid is fitted? mainly focusing on where the locks loch in and where the gas struts screw into tub liner. thanks in advance.
BA XR6 turbo, blood orange, 6 speed , mal wood option 3+ clutch, fg gt style 19's , xr8 bonnet, no spoiler , de-badged , sunroof , leather , premo, fpv wheel, plazmaman 1100hp cooler, plazmaman hot + cold side piping and intake, x force exhaust, 460 rwhp and more.... |
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Kevs home soon i will grab some Picks for you
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
cheers, thanks for that...
#4 | |||
AU DIE HARD
From the rear edge forward the key lock is 300 X 110 in from outer edge. this will determine ware the lock plate is fitted to the tub liner
![]() ![]() Again from the rear of tub looking forward Strut hinge internal on tub liner to center of mounting bracket is 1120.. from the rear of lid to extended gas strut Bracket center is 1330 Note strut does not have to be fully extended to work properly as long as both sides are square ![]() ![]() Front mounting hinge is 290 from outside edge of tub to furtherest edge of bracket . looking at it as a unit as long as lid mounts match tub liner mounts 5 to 10 mm either way wont mater much as long as it is square , Key ways for locks need to be mounted over fastening points ![]() Failing that send me a PM and we can meet up some ware for a look.
Hey mate. I have a document showing all of the locations and measurements for fitting of a genuine hard top if you would like it. Shoot me a PM if you want.
thanks very much. the brackets i got are different :(. so ill have to get the brackets for the locks and gas strut now.
cheers guys.
Hmm if thats the case then the document that I have may not help you then as it is for the brackets shown above.
Flairs - Truckers Delight
2-door sedan anyone?
#9 | |||
#10 | |||
my work ute is a dual-cab ute with a short tray and a hard lid, and it is probably less useful than a falcon sedan, the literage of the 'boot' is possibly similar but you can't fold down the rear seats etc, it's not lit, not lined, not openable by a remote etc. I would imagine a lined au ute would be a fair bit more useful however.
#11 | |||
You can't stop the signal
There are definitely two, possible three different levels of hard lid fitting kit's that I know of.
The one Kev has is the "base model" kit so to speak, and the one I have the is "top model" kit. If I ever get rid of the lid/change mounting ways, Kev's called dibs on the mounting kit. If you need to get some mounts, try to get these style ones Lock mount, goes behind the rear most rope rail kit mount ![]() ![]() Strut mount. Same mount on hard lid for either kit ![]() Hinge mount ![]() ![]() Lid shut ![]() Cheers
#12 | ||
If anyone still has the fitting instructions for the AU/ BA Ford branded hard lid, especially the position of the gas strut brackets to the tub , it would be appreciated.
Thanks |
