Old 11-10-2010, 07:54 PM   #1
AUIIPURSUIT
pursuit ute baby
AUIIPURSUIT's Avatar
Default Cat 10 wiring into AU2.
hey guys.. wondering if anyone else has wired a cat 10 into their au (series 2)...
ive hooked up the red from the box to the red acc power, the black to the ground,
and as per info on the cat10 site,Brown to vehicle Red/Black trace and CAT10 Green to vehicle Orange/Black trace ..
has anyone else done the install, and are these directions correct? the two cables, that brown and green connected to were on the far right of the connection of the stock loom.. on top of each other..
is this right?
(i bought the unit second hand, so want to make sure theres not something im missing before being ****ed off).
and i plugged mine into the 3.5mm jack on the back of my clarion deck.
thanks.
leigh
my ride : AU xr8 pursuit ute
AUIIPURSUIT is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2010, 08:04 PM   #2
frd906
Whats a Cat 10
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2010, 08:19 PM   #3
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
What......has anyone wired 10xcats to their car?????
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2010, 08:29 PM   #4
ronwest
All Bran = Regular Member
Yeah, I hooked one up a while ago. I can't specifically remember where what goes but I'll still have the instructions down the shed. I'll have a look after dinner.
edit: even easier, all the info is here (install instructions down the bottom of the page http://www.thecat.net.au/cat10.htm )
Old 11-10-2010, 09:27 PM   #5
TheInterceptor
Cruising...
TheInterceptor's Avatar
Originally Posted by frd906
Whats a Cat 10
A device that allows you to use the steering wheel controls (seek, vol + -) with an aftermarket deck.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2010, 09:43 PM   #6
frd906
cheers for that, sounds like a good idea
Old 11-10-2010, 11:27 PM   #7
AUIIPURSUIT
pursuit ute baby
thanks ron. was well aware of the website .. was just curious if the diagrams were correct, as sometimes (ala autopro) they get it wrong.. ill have another suss tomorrow when i have some time.
cheers.
Old 12-10-2010, 02:42 AM   #8
ronwest
Yeah I found the instructions down the shed and they are the same as the website. I'm positive that is the way I hooked mine up (AU3).
They do fail.
I had a CAT09 in mine first and it cacked two weeks before the 12 months warranty was up. No problems at JB's swapping it for a CAT10. (It must be over 12 months since I put the CAT10 in... so fingers crossed)
Old 12-10-2010, 05:04 PM   #9
AUIIPURSUIT
pursuit ute baby
hmmm... might have to take a trip to SA and murder someone.
ill get a decent look at it tomorrow evening.
Old 12-10-2010, 06:33 PM   #10
foxtrot3
foxtrot3's Avatar
Hi. If its not working check that
1. the switching inside suits your car (2 types of steering wheel switches)
2. even if using direct connection plug in IR led and check for output using digital camera/phone camera etc ( I have seen a couple of faulty plugs on cat 10s and dont use those right angle plugs on any of my audio projects any more)
Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 12-10-2010, 06:41 PM   #11
Bobman
Regulator
Bobman's Avatar
Where do you guys find the best spot to put the LED?
I've seen near the handbrake hanging off the console near the dome light. Will be giving the console/handbrake spot a go when I install mine.
Oh yeah, does 'Seek' still work - as in to change tracks to the next or can you only have volume up and down?
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2010, 07:40 PM   #12
ronwest
Originally I had mine in the map light surround (ghia) but the angle was too acute and quite often it wouldn't work.
Then I positioned it in the dome light surround and hadn't missed a beat (until it died, but no probs with CAT10).
Seek and vol up and down. Seek also works to change radio stations.
edit: actually I originally had it in the centre console about centre between the cup holders. PITA, everything got in the way so then up to map lights and finally dome light.
Old 12-10-2010, 08:12 PM   #13
AUIIPURSUIT
pursuit ute baby
Cheers MD
ive jumped the cat 10 to suit AU series 2.. so i dunno why its not picking it up.. also it doesnt have the IR capabilities, as he must have lost/thrown out the other parts, so its direct connect only.
