Old 02-03-2012, 09:45 AM   #1
shayne93
66 Mustang
shayne93's Avatar
Default Front tyres chewing out plastic inner guards
I've got a problem with my ute.
I had factory XLS wheels with 215/60R16s on them, never had a problem with them eating the plastic inner guards.
I've now got FG XR6 wheels with 235/50R17s on them and they have eaten the front of the inner plastic guards.
Does anyone know how I can fix this issue...? I believe my ute came factory with 215/55R16s which would directly equal 235/45R17s.
Would putting the 235/45s on stop this eating of the guards?
Keeping in mind I need two new tyres soon, but I would still have the 235/50s on the back, Can I do this?
shayne93 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2012, 11:51 AM   #2
madmelon
Default Re: Front tyres chewing out plastic inner guards
235/45R17 is the closer to the right size I think. THe others will probably fit on the back but they muck with your ABS system due to different wheel speeds. Probably best to get them all changed to the right size...
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2012, 12:34 PM   #3
shayne93
66 Mustang
shayne93's Avatar
I don't have ABS so that's not a drama. I see your point of changing all four tyres, but the good ones are quite new (never roaded when I purchased the wheels)
Old 02-03-2012, 01:33 PM   #4
brownieXR8
brownieXR8's Avatar
Maybe I'm missing something here, but the issue is likely more to do with the extra 20mm in width.
You have only increased you overall diameter by 2.4mm, but you have brought the inside edge of the tyre further inboard due to the increased width.
http://www.miata.net/garage/tirecalc.html you can use this link to play with tyre size comparisons.
HIS: AU III XR8 220, 5 speed manual, short shifter, MSD coils, ACRON CAI, Front 330mm brakes with C4 calipers and braided lines
HERS: BA Fairmont, vapour injected LPG
I reject your reality and substitute my own!
brownieXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2012, 04:20 PM   #5
shayne93
66 Mustang
shayne93's Avatar
Just to add aswell, when I bought it, it had 18 inch wheels with 235/40R18s so I am stumped
If it helps. The 18s were 18x8, 35mm offset
These 17s are 17x8 with 36.5mm offset
XLS 16s are 16x7 with 38.5mm offset
Old 02-03-2012, 04:36 PM   #6
Reaper8
Reaper8's Avatar
have you had a wheel alighnment done since changing from the 18s, probably wouldnt do it but was a thought
Reaper8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2012, 04:44 PM   #7
shayne93
66 Mustang
shayne93's Avatar
Yeah has had three, one for the 16s, and two for the 17s
Old 02-03-2012, 09:34 PM   #8
naddis01
naddis01's Avatar
The 18's were sitting 1.5mm further out towards the guards and were also 23mm smaller. So quite different really.
Do you have any pictures of where it is rubbing?
If it were me I would use the 235/50/17 on the rear and get the correct size for the front. Then eventually get the correct size all around.
naddis01 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2012, 09:58 PM   #9
BHDOGS
Just take the plastic things of there crap anyway
Old 02-03-2012, 10:07 PM   #10
Day-mow
rexnet
Day-mow's Avatar
its only plastic. im about to ditch my rears cos my 265's scrape on them
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
