Old 06-12-2013, 10:34 PM   #1
mif73
CNC fixer guy
mif73's Avatar
Default au irs upper stru mount modification.
Like virtually every au irs, I found my upper strut mounts were loose so when i looked at the price of new ones at $250 each that will fail soon enough I thought I could do something better.
This mod only works if the rubber is only mildly worn (strut moves up and down but not side to side).
I made a spacer out of hdpe (cutting board) about 6mm thick which pushes the aluminium bobbin down which allows the rubber "fingers" top and bottom to grab the bobbin tightly which restricts movement up and down.
For further support I modified some rubber bits from clark rubber to further support the bobbin from sideways and down force.
I can now jump up and down and drive the car without watching the strut move in the mount.
Refer to pics.
Cheers.[IMG][/IMG]
[IMG][/IMG]tml][/IMG]
[IMG][/IMG]
I can supply pics of spacer and part number of rubber part from clark rubber if interested.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2013, 05:10 PM   #2
mif73
CNC fixer guy
mif73's Avatar
Smile Re: au irs upper strut / shock mount modification.
Refer to pics.
Cheers.image]image[/URL]
image]image[/URL]tml]image[/URL]]image[/URL]
image]image[/URL]
I edited the subject name due to a key stroke error.
PS: Not as good as Sox's idea of getting rid of the original stuff altogether, but can work well if only mildy worn (only moves up and down), or you want to increase longevity of a new one.
Old 10-12-2013, 07:38 PM   #3
Sox
RIP...
Sox's Avatar
Default Re: au irs upper strut / shock mount modification.
Some guys have had a pretty good run from doing something similar to what you've done.
I did it myself originally with some washers.
In the end I just wanted to build a better mouse trap as I found other weaknesses inherent in the design.
Oval Everywhere...
Old 27-08-2018, 01:11 AM   #4
TickfordTiger
Default Re: au irs upper stru mount modification.
see this forum also :
https://fordforums.com.au/showthread.php?t=11353903
I have noticed these replacement internal polyurethane bushes are now available for $110ea from wholesale suspension
They also sell complete (changeover) shock / spring mounts also $275ea.
https://wholesalesuspension.com.au (02) 98318825
https://www.ebay.com.au/itm/FORD-AU-...T/272728046549
https://www.ebay.com.au/itm/FORD-AU-...A/272724624580
Falcon Unbelievable !!!
T1 TL50 Build No. 014 - Liquid Silver
T1 TL50 Build No. 017 - Liquid Silver, Sunroof
TickfordTiger is offline   Reply With Quote Multi-Quote with this Post
